Help with Cam and Rockers
DaveXR8
PostPosted: Thu Feb 21, 2008 7:50 pm    Post subject: Help with Cam and Rockers Reply with quote
Hi guys,
Just need some help/advice on what cam and roller rocker combo you's would recommend for my car if I was looking at mild cam which will produce a good amount of torque.
Im just going to do the cam and rockers and get the thing re-tuned for now.
I drive the car to work and back everyday but I also want to use it for track days aswell.
Cheers.
Timmeh
PostPosted: Thu Feb 21, 2008 7:56 pm    Post subject: Reply with quote
With an AU3 XR8 you already have 1.72 roller rockers.
Its just a cam you'd be after I reckon.
I'm not up on cams someone else should be able recommend some part numbers.
XH5LWEPN
PostPosted: Thu Feb 21, 2008 10:24 pm    Post subject: Reply with quote
Mate i'd love to see another car with a Crane 2040 (E-303) and 1.7rockers. The torque that combo puts out is unreal. Mid-range is extremely strong and maintains a great top-end, i think it would work well on the track.
DaveXR8
PostPosted: Sat Feb 23, 2008 5:27 pm    Post subject: Reply with quote
ive been looking at the crane cams and they seem to be the go.
I will be most likely going for the 2040 and a set of lifters.
With what Timmeh was saying about the rockers..is it nessassary for me to get a new set to suit?
and should i get a new set of valve springs, retainers and valve locks?
Timmeh
PostPosted: Sat Feb 23, 2008 5:51 pm    Post subject: Reply with quote
Just get a new set of valve springs, retainers and valve locks.
When the heads are off get them serviced and the new springs etc fitted and then the cam fitted.
Will be tough as nails. Don't spend money where you don't need to unless your really going to go all out on the engine.
DaveXR8
PostPosted: Sat Feb 23, 2008 6:10 pm    Post subject: Summit Racing Reply with quote
has anyone delt with Summit racing for their parts?
Just want to know if their reliable and what the delivery is like?
Scaffy
PostPosted: Sat Feb 23, 2008 7:28 pm    Post subject: Re: Summit Racing Reply with quote
I went through Summit to get my top end kit.
They are extremely helpful and I found them to be excellent as far as shipping. They give you a couple of options as far as carriers and whether you want it shipped to your door or you pick it up from a depot.
Give them a buzz once you know exactly what you're after and they'll take you through everything. You'll be able to track it as well once its posted.
DaveXR8
PostPosted: Sat Feb 23, 2008 8:51 pm    Post subject: Reply with quote
will do mate.
ozrunner
PostPosted: Sat Feb 23, 2008 10:22 pm    Post subject: Reply with quote
I have basically a brand new Ford Motorsport E303 if you want. Only did about 1500klm's and then decided to go larger.
$200 plus postage.
JD
fairy v8
PostPosted: Wed Feb 27, 2008 11:57 am    Post subject: Reply with quote
mate IMHO you can do a lot better than an alphabet cam ...try the new Comp or Crane quick ramping cams designed specifically for EFI cars or better still get a custom cam taylor made for your set up
just make sure you get good springs and retainers , locks etc as they get a real hiding
castlegreyskull
View User Gallery (34)
PostPosted: Sat May 10, 2008 9:31 am    Post subject: Reply with quote
I have just purchased the Ford Racing E303 (crane 2040) and some gt40p heads, what should i get to complement them?
1.7 rockers?
anything else? also brands or links wuld be good.
EBXR8380
PostPosted: Sat May 10, 2008 11:19 am    Post subject: Reply with quote
Yes some say that.. They are still good cams though.. With good springs 1:72 rockers . They have quick enough ramps... There is no way you could use std springs with this combo !! Its not the efi that allows quick ramps.. Its the roller cam with its narrow contact which prevent lobe scuffing...
TerroristGHIA
PostPosted: Sat May 10, 2008 12:57 pm    Post subject: Reply with quote
I highly reccomend Summit. Have bought most of my parts from them for at least the last 3 years.
And there prices are awesome even if you include shipping
Brett
TKFDXR8
PostPosted: Sat May 10, 2008 12:58 pm    Post subject: Reply with quote
i got a good result from Comp Cams XE270HR cam. jump on their website for specs
- 202 Rwkw
that was with ported GT40X heads, and ported upper manifold, 2.5" twin exhaust, and a flasher tune. my car is an auto.
it runs nice, and idles fine. a littel lumpy (which is want i wanted!!), and cold start is spot on, albiet a little more rough, until it warms up.
hope this helps
L1STED
PostPosted: Sun May 11, 2008 2:19 am    Post subject: Reply with quote
yeah o say go with comp cam dunt go crow nuffing but bad news comes from crow. . icon_biggrin.gif
fairy v8
PostPosted: Sun May 11, 2008 12:00 pm    Post subject: Reply with quote
na! i was meaning a cam thats designed to suit EFI vehicles as well as quick ramping to take advantage of it being a roller cam (some dont)
i think the next one i do il get a custom one tailored to suit your whole package ....by one of the cam designers in the states
EBXR8380
PostPosted: Sun May 11, 2008 1:35 pm    Post subject: Reply with quote
Yep you can't go wrong with Ed Curtis...
http://www.flowtechinduction.com/customers.htm
fairy v8
PostPosted: Mon May 12, 2008 12:15 am    Post subject: Reply with quote
he seams to have a lot of happy customers on corral!!
EBXR8380
PostPosted: Mon May 12, 2008 8:51 pm    Post subject: Reply with quote
Hahaha he often has the odd debate !! He deff says what he thinks !!!
http://cammotion.com/DesktopDefault.aspx?tabid=69
is another...
fairy v8
PostPosted: Tue May 13, 2008 9:27 am    Post subject: Reply with quote
yep .....not one to step back from a good debate hehehe
[47 queries :: 0.06368 seconds ]
