Bassfreak55 Fordmods - Getting Side Ways
Posts: 529 Joined: 11 Nov 2004 Location: Canberra ACT, Australia
Posted: Mon Jan 31, 2005 10:56 pm Post subject: How do you double clutch? |
| As above..? |
Happy Moderator
Age:35 Posts: 9944 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 31, 2005 11:10 pm Post subject: |
| push your clutch in and change to neutral, let clutch out and tap accel, push clutch in and change to your higher gear. |
chunkz Fordmods - Getting Side Ways
Age:21 Posts: 5314 Joined: 06 Nov 2004 Location: Melbourne, S.E Suburbs VIC, Australia
Posted: Mon Jan 31, 2005 11:12 pm Post subject: |
| and the advantages of doing this is...... |
Happy Moderator
Posted: Mon Jan 31, 2005 11:25 pm Post subject: |
| done to keep your revs up in trucks or bigger engines so when you engage again you are not stressing your gear box |
elXR Fordmods - Getting Side Ways
Age:24 Posts: 407 Joined: 07 Nov 2004 Location: melbourne VIC, Australia
Posted: Tue Feb 01, 2005 1:02 am Post subject: |
heheh i heard this in fast and furious and have always wondered myself...
not to hijack the thread or anything just dont want to start another thread.. but what is flat shifting?? |
nomad1089 Fordmods - Getting Side Ways
Age:24 Posts: 844 Joined: 23 Nov 2004 Location: Nth East VIC, Australia
Posted: Tue Feb 01, 2005 1:30 am Post subject: |
| I think flat shifting is leaving your foot on the accelerator while you change |
Age:36 Posts: 3196 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Tue Feb 01, 2005 1:37 am Post subject: |
Flat shifting is holding the throttle flat out and changing gears.
With "real double clutching it is unusual to use the throttle when up shifting, but with down shifting it is necessary to use the throttle to get the gears to match speeds, when relating to truck crash boxes etc.
I know this only because I have drove trucks and buses for years, and my current job requires me to drive trucks with crash boxes.
In relation to crash boxes you don't need to use a clutch other than for starting off etc in most cases, some engine and gearbox combinations are easier than others and it sometimes takes a bit of practise in each vehicle.
I am lazy and normally don't use the clutch, in most cases up-shifting requires no skill other than taking your foot off the throttle to allow you to pull it out of gear so you can go into the next gear, down shifting requires the same but then revving the engine up until the gears match speed before you can downshift, it isn't hard but even the best driver can make an error in judgement.
There is advantages and disadvantages to using this method, the big advantage for me used to be the shorter delay with Jacobs brakes coming back on, I could make a faster deceleration without needing the brakes as much (could be naughty and use two feet, left on the brake pedal) in a coach and make it an overall smoother deceleration for the passengers.
PS. It is late so this might be hard to understand what I wrote. |
Age:22 Posts: 10375 Joined: 15 Nov 2004 Location: Hobart TAS, Australia
Posted: Tue Feb 01, 2005 2:23 am Post subject: |
Flat shifting if not taking your foot off the accelerator. V8 Supercar style.
Double clutching seems to vary in methods, most are probably made up based on what some ricers saw on Fast and Furious. Some people release accelerator and put in clutch (but most cars can be pulled out of gear without clutch), take out of gear, release clutch (some lazy people leave in the clutch) and give some revs, put in clutch and go into gear, release clutch and give accelerator.
Most people who do it seem to do it because they think there cool, because they saw it on tv or because they think it makes a good noise! But both methods seem to have something to do with keeping the engine revs up. |
Posted: Tue Feb 01, 2005 6:56 am Post subject: |
| The only real advantage of Double-Clutching is that it makes your gearbox and its components last a bit longer. But you end up using more fuel. So advantages might be cancelled out in the long run. |
Age:34 Posts: 441 Joined: 29 Nov 2004 Location: Sydney NSW, Australia
Posted: Tue Feb 01, 2005 7:58 am Post subject: |
Double clutch advantages, none. makes a gear change take longer. something for truck drivers or people in fiats (only god knows why they do it for). Maybe you would do this if you sincro's were rooted.
Flat shift or change, good for pulling 2nds & 3rds if your car dont have enough nuts to spin in these gears. Good for thrashing your drive line. Although some cars are set up with a kill swich mechanism that kills the spark (usually) for a split second when you put the clutch in (so the donk dont over rev), this is of advantage to turbo cars as you dont close the TB slowing up the turbo on the gear change. |
4.9 EF Futura Moderator
Posted: Tue Feb 01, 2005 7:59 am Post subject: |
Double clutching, as above, used when high loads on vehicle and helps match the speed of the gears so they mesh better... very important in the days before synchromesh.
"Granny shifting, not double clutchin like ya should...." never heard of double clutching in drag racing??!? |
Posted: Tue Feb 01, 2005 8:38 am Post subject: |
| 1 SLY 97EL wrote: | | The only real advantage of Double-Clutching is that it makes your gearbox and its components last a bit longer. But you end up using more fuel. So advantages might be cancelled out in the long run. |
I better clarify this, double clutching in a syncro gearbox wont make anything last longer, most likely the opposite as the syncros cop a hiding, real double clutching is of no advantage unless your syncros have failed, saying this a syncro gearbox uses helical cut gears (only used because they are quieter than straight cut) and is much harder to get the gearbox gear speeds matched up, that is what the syncros do (leave them to do their job), real double clutching just wears out the syncros.
Depressing the clutch and revving the engine isn't double clutching, the only benefit from doing this is if going down gears it closer matches the engine speed in which the engine will do when clutch is engaged again, and of course "only V8s sound good doing this". |
Posted: Tue Feb 01, 2005 11:47 am Post subject: |
Double clutching or rev matching is a sound principal to employ when making a down change from an already moderate engine speed. ie 3rd to second at 70 k's whilst driving hard.
By rev matching you limit weight transferance due to more even engine braking and also limit the chance of a compression lock-up.
I have never ever heard of rev matching hurting synchro's at all? You are essentially just assisting them in thier job and as long as you are not placing any pressure on the shifter whilst adjusting revs, how are the synchro's being effected?
My two cents! |
Posted: Tue Feb 01, 2005 11:52 am Post subject: |
| You can rev match your change with out doing the double shuffle, its just meant for really heavy duty (truck) gearboxes. |
Posted: Tue Feb 01, 2005 12:37 pm Post subject: |
| No point in it at all, unless your car weighs 10 tonne, pullin 3 , doin a dollar ten down sesame street., pointless fast and furious crap. |
Posted: Tue Feb 01, 2005 1:32 pm Post subject: |
| bowsaw wrote: | | No point in it at all, unless your car weighs 10 tonne, pullin 3 , doin a dollar ten down sesame street., pointless fast and furious crap. |
Especially in an EF2 Fairmont Ghia Auto!!!!!!!
lol |
Posted: Tue Feb 01, 2005 2:03 pm Post subject: |
| philaddis wrote: | | bowsaw wrote: | | No point in it at all, unless your car weighs 10 tonne, pullin 3 , doin a dollar ten down sesame street., pointless fast and furious crap. |
lol |
Is that why it dont work??? but it says 1 2 3!!! |
Posted: Tue Feb 01, 2005 2:12 pm Post subject: |
| bowsaw wrote: | | philaddis wrote: | | bowsaw wrote: | | No point in it at all, unless your car weighs 10 tonne, pullin 3 , doin a dollar ten down sesame street., pointless fast and furious crap. |
lol |
That's just stupid! We all know that you put the car into R for Racer! |
blackjack_original Fordmods - Getting Side Ways
Age:23 Posts: 3464 Joined: 08 Nov 2004 Location: Adelaide SA, Australia
Posted: Tue Feb 01, 2005 3:10 pm Post subject: |
| AXR88U wrote: | Double clutch advantages, none. makes a gear change take longer. something for truck drivers or people in fiats (only god knows why they do it for). Maybe you would do this if you sincro's were rooted.
People in fiats usually do it because the first geah isn't sincroed. actually i don't know about all fiats, but my 500 and 650 and 126's of my friends you had to do it. If you didn't double clutch you couldn't put it in first unless the car has completley stopped. |
[47 queries :: 0.06227 seconds ]
