how to add ram
chunkz
PostPosted: Wed Jan 18, 2006 9:40 pm    Post subject: how to add ram Reply with quote
my computer has been running to s**t lately...
how do i go about adding ram?
wtf does that slip in?
or is it like a cd/hard drive to hook up?
Leroy
PostPosted: Wed Jan 18, 2006 9:42 pm    Post subject: Reply with quote
if its anything like it used to be, it should just slip in the little "cradle" for it
haggis
PostPosted: Wed Jan 18, 2006 9:43 pm    Post subject: Reply with quote
There is a slot/port on your motherboard, it'll be thin and long. the RAM will only fit one way, so dont worry about that. just lift up the clips on either end of the DIMM (thats what the RAM slot is called) and push the RAM in until it clicks in and the clips lock down.
cooki_monsta
PostPosted: Wed Jan 18, 2006 10:08 pm    Post subject: Reply with quote
if u have an old mobo careful not to crack it with pressure needed to put in new ram in dimm slots never used, but basically, buy it, unclip the white leavers, push it in till the white leavers lock the ram in place, fire her up n watch her run
haggis
PostPosted: Wed Jan 18, 2006 10:16 pm    Post subject: Reply with quote
Oh also, if it doesn't start, it may be because the BIOS has the settings too fast to accomadate your new RAM, to rectify, you need to reset the BIOS. This can be done by either moving the CMOS reset jumper switch from '1-2' pins to '2-3' pins. When you open up the case, these 3 pins are usually located on the bottom right, near where the cables are that run to thr front of your case.
IF that seems too hard, or you cant find it, just take out the battery, start the computer, computer will chuck a hissy fit, turn off computer, put battery back in, start computer back up, reconfigure BIOS to suit your desires (for most people, simply re-arranging boot devices is all you'll notice, some older machines might require you to select CPU type & speed
Pet_ED
PostPosted: Wed Jan 18, 2006 10:25 pm    Post subject: Reply with quote
Just make sure you get the correct RAM for your motherboard.
SD
DDR etc
As the other guys say, yes it will clip straight in one way, make sure they both clip in on each side and dont pull out or bang any spagetti cables by accident.
Jim Beam
PostPosted: Thu Jan 19, 2006 2:26 am    Post subject: Reply with quote
SD
DDR etc
Yeah i bought some new SD ram (f**k s**t motherboard) and it cost $63 bucks from some semi dodge place in Munno Para.
cooki_monsta
PostPosted: Thu Jan 19, 2006 6:21 pm    Post subject: Reply with quote
yea sd has skyrocketed since they stopped producing it
Jim Beam
PostPosted: Thu Jan 19, 2006 7:12 pm    Post subject: Reply with quote
Hence why i made that other thread.
TFI
PostPosted: Sun Feb 26, 2006 12:49 pm    Post subject: Reply with quote
Forget SD.. DDR is the way to go.. heaps faster.
A_Boring_Username
PostPosted: Sun Feb 26, 2006 2:07 pm    Post subject: Reply with quote
SD ram is cheap as on ebay
[38 queries :: 0.05084 seconds ]
