mr_rx7_ Fordmods Tyre Shredder
Age:21 Posts: 333 Joined: 10 Jan 2005 Location: Broadmeadows (Melb. North) VIC, Australia
Posted: Mon Apr 03, 2006 3:14 pm Post subject: HOW-TO Remove Glue After Debadge-Desticker |
After reading a few threads on how to get rid of the glue residue left over from debadging or removing stickers, I decided to write this simple thread.
REQUIRED
Oomph Glue Remover
2 Cloths
Bucket With Water
METHOD
After prying off your badges, or removing a sticker, you will notice sticky residue left over which can be really tough to remove.
1. Get your bottle of Oomph Glue Remover, spray a couple of little squirts onto the sticky residue (make sure the nozzle is set to SPRAY).
2. Allow the spray to soak into the glue by waiting about 1 minute.
3. Get your cloth and wipe the residue away.
If any glue is left over, repeat the three steps again but let the substance soak into the glue a little longer.
4. Dunk a clean cloth into your bucket of water and thoroughly wipe your car where the Glue Remover had contact with.
DONE.
Enjoy your debadged car with 100% of the sticky residue removed.
Oomph Glue Remover is absolutely fantastic, this product took away the glue that remained after I removed the FALCON GLi badge, white stripe stickers and the 4.0i OHC stickers from the black moulding.
Oomph Glue Remover is located in your kitchen cleaning product section at your local Safeway/Woolworths supermarket (I don't think it is found anywhere else but I could be wrong). It's in a smallish 250mL bottle and it is about $5 (between $4 and $7...not 100% sure)
Thanks to TwinturboBMX for recommending the product because it is absolutely fantastic! |
smiley235 Fordmods - Getting Side Ways
Age:22 Posts: 4655 Joined: 19 Feb 2005 Location: melbourne VIC, Australia
Posted: Mon Apr 03, 2006 3:38 pm Post subject: |
| I don't suppose it would work on the left over crap on my ea's door after i pulled off the weather guard, well, one way to find out, ill let you know how i went. |
Posted: Mon Apr 03, 2006 3:45 pm Post subject: |
| Give it a try mate. For $5 you cant go wrong lol. If its gluey/sticky residue, this will remove it! |
DjeMz Fordmods Tyre Shredder
Age:20 Posts: 389 Joined: 12 Sep 2005 Location: Melbourne VIC, Australia
Posted: Sun Apr 16, 2006 11:20 pm Post subject: |
yeh i wanna try on where my windsheild was.. looks like its been there for so long, its perm..
ill buy this stuff and let u know |
TwinturboBMX Fordmods - Getting Side Ways
Age:19 Posts: 3874 Joined: 05 Nov 2004 Location: Back in Newcastle! NSW, Australia
Posted: Mon Apr 17, 2006 5:31 pm Post subject: |
| Guys i use this product and its absolutely brilliant. Ive got a bottle, and ive used it alot, and the bottle is still over 3/4 full. So it goes a long way. And smells good too. |
Cav Fordmods Parts Gopher
Age:58 Posts: 50 Joined: 14 Sep 2005 Location: Primbee NSW, Australia
Posted: Fri Apr 21, 2006 4:24 pm Post subject: |
Yeah well it may get the glue off, but what about the scratches I put in the duco?  |
Posted: Fri Apr 21, 2006 4:49 pm Post subject: |
| Haha lol, um yeh Oomph Paint Reparier anyone? |
Bazzo Fordmods Stock as a Rock
Age:21 Posts: 140 Joined: 10 Nov 2005 Location: Gladstone QLD, Australia
Posted: Wed May 10, 2006 5:46 pm Post subject: |
id like to add something to this. When i debaged my ute, i had glue that had gone hard and was almost impossible to remove. i used a carmel wheel. its like a rubber wheel(carmel colour) and u just put it into a cordless drill and away u go. this worked a treat. then just used the glue remover to clean the area up. jus thought id add that incase someone was in the same situation as me.
thanks bazzo |
Samsy Fordmods - Getting Side Ways
Age:34 Posts: 663 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Thu May 11, 2006 5:12 pm Post subject: |
| Prepsol is always good, safe for your paint too! |
fairmont599 Fordmods - Getting Side Ways
Age:19 Posts: 944 Joined: 27 Oct 2005 Location: Port Augusta SA, Australia
Posted: Fri May 12, 2006 7:47 pm Post subject: |
| heh, yea id be careful with this stuff. use it at work to get glue off shelving and it dosnt do ur fingers much good after rubbing it for an hour or so. to the point when i can only just feel them. id be trying it on a place that cant be see before just sprying it on |
get EFd Fordmods - Getting Side Ways
Age:24 Posts: 405 Joined: 18 Sep 2005 Location: CAMPBELLTOWN NSW, Australia
Posted: Mon May 15, 2006 7:03 pm Post subject: |
| I debadged mine yesterday and i just used good old WD-40.Works heaps good.Just make sure u clean it all off afterwards. |
dawall Fordmods Newbie
Posts: 18 Joined: 10 Feb 2006 Location: adelaide SA, Australia
Posted: Thu Jun 29, 2006 7:51 pm Post subject: |
| learnt the hard way to be generous with the heat when taking off a badge, ripped a whole lot of the paint off when i was de-badging mine. |
NiNoPace Fordmods Oompa Loompa
Age:16 Posts: 49 Joined: 07 May 2006 Location: Sydney NSW, Australia
Posted: Sun Oct 22, 2006 12:00 am Post subject: |
NO NO NO NO NO!
ITS CALLED EUCALYPTUS OIL!
as long as you do not leave it on and you wash it off it works the best. Its better than oomph for sure. All you need is a small cloth and the oil and rub it off. Works a treat!!!!
Support Australia........ Buy EUCALYPTUS OIL |
prendii Fordmods Parts Gopher
Posts: 90 Joined: 24 Feb 2006 Location: Melbourne VIC, Australia
Posted: Sat Oct 28, 2006 4:51 pm Post subject: |
| i jus used turps didnt scrub too hard and rinsed imediatly i removed my badges by prying a bit of ice cream container underneith and lifting how did u guys go about it? |
stomper Fordmods - Getting Side Ways
Age:18 Posts: 2983 Joined: 15 Apr 2006 Location: Aberfoyle Park SA, Australia
Posted: Mon Nov 06, 2006 11:54 am Post subject: |
| DE-SOLVE-IT works a treat for taking off the glue when u take pin stripes off |
na2fairlane Fordmods - Getting Side Ways
Posts: 728 Joined: 05 Nov 2004 Location: perth WA, Australia
Posted: Mon Nov 06, 2006 2:20 pm Post subject: |
| eucalyptus oil is pretty good for removing sticky stuff. |
Posted: Mon Nov 06, 2006 9:11 pm Post subject: |
| na2fairlane wrote: | | eucalyptus oil is pretty good for removing sticky stuff. |
Actually its really quite s**t, we used it at work when we were renewing our pricing strips, and the glue was really hardcorly on the shelving on the friges, we tried hot water, then eucalyptus, and it did sweet f**k all. Then we used oomph and it came off VERY easily. Trust me we were aprehensive to use it as we thought, oh waste of time, but hell it worked. |
Freak6 Fordmods - Getting Side Ways
Age:20 Posts: 1051 Joined: 28 May 2006 Location: Adelaide SA, Australia
Posted: Sun Dec 10, 2006 11:28 am Post subject: |
i removed the 4.0l dohc sticker from the side molds on my falcon and cleaned the glue off useing turps...
that worked fine for me... |
superdan Fordmods Newbie
Age:25 Posts: 4 Joined: 20 Jan 2007 Location: townsville QLD, Australia
Posted: Mon Jan 22, 2007 4:27 pm Post subject: |
| Use fishing line just like you would floss ur teeth (if u had them?!). they come straight off and than some bug and tar gel. give him a quick polish and bobs ur aunty! |
