janek Fordmods - Getting Side Ways
Posts: 413 Joined: 14 Nov 2004 Location: Brisbane Most of the time/Sydney Some of the time QLD, Australia
Posted: Tue Apr 05, 2005 9:53 am Post subject: |
| 72 bucks, send me your account details, ill pay you 80 bucks, get me one and express post it down! you sure thats for the au2 oxy sensor? if it is, check if its the 4 wire suitable for vct, autobarn here quoted me 120 mates rates! |
80crm Fordmods - Getting Side Ways
Age:28 Posts: 1015 Joined: 14 Feb 2005 Location: Atherton/Cairns QLD, Australia
View User Gallery (27)
Posted: Tue Apr 05, 2005 1:02 pm Post subject: |
Sorry but this was for a sensor for my EL.
Repco customer price was $120 but they marked it down to $100. |
Posted: Tue Apr 05, 2005 2:42 pm Post subject: |
| i thought it was a tad cheap :S |
slimjim Fordmods Parts Gopher
Age:25 Posts: 75 Joined: 21 Dec 2004 Location: geelong VIC, Australia
Posted: Tue Apr 05, 2005 8:39 pm Post subject: |
It all good fellas.. thanx for the input..
got a guy who i work with use to work with ford for 15years and we checked me car out..
someone before me had stuffed around with the idle
so we set it at the correct rpm and big vibrations through the car.
tested the ISC and map sensor.. all ok
so he said it deffintly b the ecu...
$170 (trade) from bursons for a brand new one..
so that b fixed tommora.. |
Posted: Tue Apr 05, 2005 11:19 pm Post subject: |
wah, where did talk of a rooted ecu come in!
thats the last thing i want it to be!!!!!!!
i think ill try my oxy sensor and pray... |
voxace Technical Contributor
Age:23 Posts: 3097 Joined: 05 Nov 2004 Location: Ivanhoe NSW, Australia
View User Gallery (29)
Posted: Tue Apr 05, 2005 11:28 pm Post subject: |
Yeah sometimes things go wrong inside the ecu.
I've been frantically trying to trace problems to sensors and I'm almost certain my auto ECU is f**k.
Everything seems to work fine and dandy with my manual ECU. |
Posted: Thu Apr 07, 2005 9:17 pm Post subject: |
well we did tests on all sensors and they all work fine.
put the new ecu in today and noticed the difference straight away.. acctually idels properly..
still wish it waz like a loose connection or a $60 sensor. but hey
gotta be done. :< |
Waggin Site Admin
Posted: Thu Apr 07, 2005 9:44 pm Post subject: |
| slimjim wrote: | well we did tests on all sensors and they all work fine.
gotta be done. :< |
Auto ECU's can be had for around $60-80!  |
weeman Fordmods Parts Gopher
Posts: 65 Joined: 21 Feb 2005 Location: Canberra ACT, Australia
Posted: Mon Apr 11, 2005 11:41 am Post subject: |
| voxace wrote: | OK. here is where it "should" be:
And here is how to test it:
Ignition On: 0.155-0.156KHz
Engine Idling: 0.101-0.103KHz
Engine Revved: 0.90KHz (Approx)
Idling in Drive: 0.105-0.106 KHz
Idling in Drive with A/C on or Steering Load: 0.109-0.111KHz
Of course you are going to need a Digital Multimeter to test this. |
Just went out and tested my map sensor, all the values were clsoe to those above expect when I rev the engine I only get about 0.120 - 0.130KHz. I took the car for a drive with my multimeter setup in the cabin recording max freq, drove around for about 10min under different loads including a lot of full throttle. The max freq was 0.156KHz.
Would this most likey indicate a vacuum leak or a faulty map sensor? The car is an ED XR6. |
Kit Fordmods - Getting Side Ways
Age:39 Posts: 2420 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Tue Apr 12, 2005 5:35 am Post subject: |
Yeah I think my ECU is stuffed too. Idle is just alright if it's set to around 770 to 850RPM. But even then as soon as the air-con goes on, the rev's drop 200rpm, and end up sitting on a very rough and vibrating 500 RPM in drive. I am forced to put it in neutral everytime I stop at a red light. Either that or turn the air-con off everytime I have to stop.  |
Posted: Tue Apr 12, 2005 8:40 am Post subject: |
but i dont have problems with idle
just chewing the fuel, and extremely hot exhaust... i get my oxy sensor this week  |
Greenmachine Fordmods Tyre Shredder
Age:42 Posts: 319 Joined: 22 Mar 2005 Location: Cairns Qld - god's own country QLD, Australia
Posted: Tue Apr 12, 2005 10:27 am Post subject: |
| Extremely hot exhaust can mean the cat is clogged. |
GTBob Fordmods - Getting Side Ways
Age:70 Posts: 1230 Joined: 07 Apr 2005 Location: Tallebudgera, GOLD COAST QLD, Australia
Posted: Tue Apr 12, 2005 10:51 am Post subject: |
There is one thing everyone is NOT checking Engine Temperature! If the thermostat is faulty or INCORRECT range the ECU thinks the motor is not up to correct running temp and richens up the mixture accordingly This has a BIG effect on range, mine was 20l/100 kms After thermostat 14.7 l/100km Hope this helps as it has mine  |
Posted: Tue Apr 12, 2005 10:58 am Post subject: |
| What temperature did you get that fixed it? |
Posted: Tue Apr 12, 2005 11:55 am Post subject: |
| Almost to guage centre approx 95 deg C |
Posted: Tue Apr 12, 2005 11:57 am Post subject: |
Also found ONLY genuine thermostats are any use, aftermarket ones tend Not to be much good
Posted: Tue Apr 12, 2005 12:00 pm Post subject: |
| How much are genuine ones worth from ford $$$? |
Posted: Wed Apr 13, 2005 12:26 pm Post subject: |
Not sure Have been out of the repair business for a while check with your local Blue oval parts distributor Whatever the price for this item it is well worth it as I have had to replace too many aftermarket ones and my repair insurance was getting tired of paying to fix blown head gaskets undar my workshop warranty  |
Posted: Thu Apr 14, 2005 9:02 am Post subject: |
| Greenmachine wrote: | | Extremely hot exhaust can mean the cat is clogged. |
thats the next port of call... i think the cat may well be stuffed as well. the oxy sensor went in yesterday. smoother power, more of it , and consumption has dropped about 10% so far (only 200 kms so far, but still above half a tank, looking good, about 500 out of a city tank im guessing)
im going to get myself a new hiflow cat, pacey 4480's (anyone put these on the au vct yet?) and redback 2½ exhaust, and some sort of pod setup with the madrel intake im getting, along with the tickford snorkel. setting me back a total of just over 1300 thats still a month or two away though :'(
as for the exhaust, i still have the burn mark on my leg. i accidentaly touched the tip of teh exhaust and it sillzed the f**k out of me. first car ive ever seen that happen on.
finally, ecu wise, any easy way of testing it? i really think its fine, but you guys have instilled doubt in my mind! :S |
