Posts: 1955 Joined: 06 Nov 2004 Location: Under the flight path of incoming packpackers NSW, Australia
Posted: Mon Jan 09, 2006 2:29 pm Post subject: |
Your right there tjb45, a tank full of dodgy fuel on a 45 deg day is alot different to when it was tuned on a cool winter day with the bonnet up on the dyno.
I'm reading and hearing about alot of guys with a few different tunes... like a hardcore on edge tune for the track, a low octane freeway tune ect.
Yes, motor is 100% standard ED, 250ish thousand kays... doesnt burn oil, doesnt use oil, but is starting to sound a bit loose which I belive is more from it over reving when the auto was slipping.
I am changing the cooler pipes to alloy, only to save some weight and so I can polish them and start tarting up the eng bay... soon as i have some time for it again...
Engine plans... I'm going to rebuild this motor, but first I want to break it so that I know exactly what handles lots of boost and what doesnt... I'll give it as much boost as I can until the injectors max out, hopefully around 25psi.
I'm not going to over rev it or abuse it, I'd just like to find its boost related weakness... rings for sure, but pistons, rods crank?? Only one way to know for sure  |
SileNceR Fordmods Stock as a Rock
Age:23 Posts: 115 Joined: 09 Nov 2004 Location: Warrnambool VIC, Australia
Posted: Thu Jan 12, 2006 3:49 pm Post subject: |
So long as you don't end up with a piston or rod sticking out of your face
With regards to the knock sensor I was under the impression they used a pulsing signal rather than an analogue signal; ive only got the factory book here to suit an ea, so nothing on knock sensors...
anyone with ef/l or an au book care to fill us in on knock sensor operation (in terms of outputs) |
ebs_4l Fordmods - Getting Side Ways
Age:23 Posts: 820 Joined: 23 Sep 2005 Location: kadina SA, Australia
Posted: Thu Jan 12, 2006 11:56 pm Post subject: |
| they are piezo electric device, when vibrated at certain frequency they make their own voltage output, thats why most sensors have a single wire going to them, they generate the voltage internally... you know, like oven lighter things when you push the button they make a spark |
tjb45 Fordmods - Getting Side Ways
Age:28 Posts: 549 Joined: 05 Nov 2004 Location: Wodonga VIC, Australia
Posted: Fri Jan 13, 2006 7:14 am Post subject: |
| I've also heard they are a piezo device, That’s why I thought it was strange that I got a steady 3 volts from it when the car is idling(also backed up by some technical documentation I've got). I would of assumed that it would generate a very small <1 volt signal when some form of knocking occurred.. The only thing I can think of is the signal is been modified somewhere before it get to the ECU (weird I know). I might try to measure the signal just out of the sensor and go from there. |
Posted: Sat Jan 14, 2006 8:46 am Post subject: |
correct, from memory it is less than 1 volt output when pinging, no output any other time...
if you were probing for it at the ecu you may have been on the wrong wire..??
ill check a genuine ef w/shop manual at work on monday, i work at a ford dealer |
turbotrana Fordmods - Smokin em up
Posts: 201 Joined: 19 Sep 2005 Location: Perth WA, Australia
Posted: Sun Jan 15, 2006 10:11 pm Post subject: |
| Chef what did you do to your front bumper to get your intercooler to fit. |
Posted: Sun Jan 15, 2006 10:45 pm Post subject: |
| good q the trana, i had wondered that, i think he has a 75mm core, i have the 100mm core and it appears my whole pipes n all will be hanging out, to get one to fit, i rekn ud need the 75mm core and cut back the lower member and cut back the side panels going down alongside the condensor... ?? |
Posted: Mon Jan 16, 2006 1:42 pm Post subject: |
I took the bumper off and chucked it into the wheelie bin
Replaced it with a brock ea replica... I cut a fair chunk out of the centre but it covers the cooler and pipes nicely |
ba_xr6turbo Fordmods Stock as a Rock
Age:27 Posts: 118 Joined: 18 Feb 2006 Location: Melbourne VIC, Australia
Posted: Sat Feb 18, 2006 3:44 pm Post subject: |
| I cant believe its stiill going!!! (the post i mean) people love turbo falcons i guess |
Posted: Sat Feb 18, 2006 6:11 pm Post subject: |
| Seems to be a very popular mod these days... there's so many turbo parts around due to huge amount of turbo cars getting modifed now |
ToranaGuy Fordmods Tyre Shredder
Age:25 Posts: 344 Joined: 08 Dec 2004 Location: Werribee VIC, Australia
Posted: Tue Feb 28, 2006 10:24 am Post subject: |
I love reading this thread, it gives me inspiration to mod my EB, and if i had the $$ i'd turbo it. My turbo torana project is behind atm, blew the head gaskit on the ford, so there goes my turbo rebuild funds.
CHEF, will be interesting to see what you break. Judging by the BA turbo guys, i'd say rings, pistons, maybe rods. I'd be suprised if you broke the crank!
Chers
ToranaGuy |
Posts: 2857 Joined: 31 Oct 2005 Location: . QLD, Australia
View User Gallery (28)
Posted: Tue Feb 28, 2006 12:04 pm Post subject: |
how about this.....
one ed turbo falcon
two second hand tires
three minutes of non stop smoke action
Age:26 Posts: 4519 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Tue Feb 28, 2006 4:10 pm Post subject: |
| 3 minutes - shouldn't take that long, "gone in sixty seconds" now that sounds like a better movie. |
Posted: Tue Feb 28, 2006 11:37 pm Post subject: |
It could be somthing like...
Up in Smoke
I plan on destroying a set of tyres when i get my turbo torana running, just for the hell of it..... Real men smoke RUBBER!
ToranaGuy |
killer Fordmods Newbie
Age:58 Posts: 1 Joined: 02 Feb 2005 Location: sydney NSW, Australia
Posted: Wed Apr 12, 2006 10:41 pm Post subject: |
excelent blow by blow description
KILLER |
Blu Falc Fordmods - Getting Side Ways
Posts: 1540 Joined: 27 Apr 2005 Location: Perth WA, Australia
Posted: Sat Apr 15, 2006 2:21 pm Post subject: |
| Chef- How much did the engineer charge you to have it inspected and certified? Also you said that you cannot have a boost controller, do you know if that is for both pneumatic and solenoid systems (as in mechanical or electronic). |
Eu-GenixX Fordmods Tyre Shredder
Age:28 Posts: 353 Joined: 12 Apr 2006 Location: Brisbane QLD, Australia
Posted: Fri Apr 28, 2006 11:47 pm Post subject: |
my first post on these forums.. and it's in this thread...
i found this thread this morning.. before work.. and was itching ALL day to get home and read it.. and i'm glad i did...
so much information in here....
i'm starting to buy all the bits and pieces i need for a turbo setup.. i got a turbo.. and thats the first thing i bought.. a mate of mine will make all my piping for me.. including manifold etc.. and will prolly run a microtech computer...
will certainly refer to this thread for info when i need it.. . |
Posted: Sat Apr 29, 2006 8:34 am Post subject: |
| Good stuf mate, hope it goes well. |
pauly_pizza Fordmods - Getting Side Ways
Posts: 558 Joined: 06 May 2006 Location: cbd melb. VIC, Australia
Posted: Thu Jun 15, 2006 7:19 pm Post subject: |
| Yep same here, and turbos on the falcon motor.. u know ur gaining serious amounts of power and fun. so its almost worthwhile to do it to any falcon.. but cost is an issue for some or most people. |
[47 queries :: 0.05962 seconds ]
