HOW TO TURBO YOUR i6 the DIY WAY. with PICS
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8, 9
syko4d
PostPosted: Fri Nov 23, 2007 11:21 am    Post subject: Reply with quote
excellent but the do it yourself on the standard manifold????? how and wat standard manifold do u use the ed does not go on upside down the holes dont line up?
ToranaGuy
PostPosted: Wed Nov 28, 2007 3:42 pm    Post subject: Reply with quote
If i read that correctly, the answer your looking for is either make a " J " pipe to hookup to the std manifold or you cut up the std manifold to fit a turbo flange onto the side of it.
ToranaGuy
Fullyxr6
PostPosted: Thu Jan 03, 2008 8:28 pm    Post subject: Reply with quote
what about a twin turbo set would be more complecated
ToranaGuy
PostPosted: Tue Jan 22, 2008 12:13 pm    Post subject: Reply with quote
This post doesn't make a lot of sense, if i think about it, it's looking like your asking " would a twin turbo setup be more complicated? "....
The obvious answer would be " YES ". More complex exhaust manifold or J pipe, more tubing to hide under the bonnet, 2 x turbos, 2 x waste gates, either int or ext, and so on.
On a motor that is has as much torque as for ford I6, i don't really see the point of twin turbo.
I'm making some small progress with my Turbo Torana project, i hope to have it running sometime later this year, pending time & $$$. icon_twisted.gif
ToranaGuy
syko4d
PostPosted: Tue Feb 05, 2008 7:35 pm    Post subject: Reply with quote
yeah thanx mate i dont know or understand the j pipe bit?
laguna_anugal
PostPosted: Tue Feb 05, 2008 11:38 pm    Post subject: Reply with quote
Hey mate ive jsut gotten a snort kit waiting on arrival now just wondering... How you went about tapping a hole into sump for oil drain line?
Cheer's
vrblou02
PostPosted: Sun Feb 10, 2008 10:11 pm    Post subject: Reply with quote
yes i would also like 2 no how u go about plumbing in the oil feed into the sump
n
as im lookin into a turbo setup
but for now jus in the middle of doing a 5 speed coversion
anyways
im outskeez for now
ToranaGuy
PostPosted: Tue Feb 12, 2008 9:11 pm    Post subject: Reply with quote
Drill a small hole into the side of the sump, above the normal oil line, and weld a return pipe to the hole. Make sure you dump the oil & flush the sump out if your not removing it from the car to do this work, don't want metal shavings roaming around inside your engine.
I've modified the sump for my torana while the engine was out & upside down on the engine stand. Much easier than trying to do it in the car.
ToranaGuy
Page 9 of 9
[35 queries :: 0.04051 seconds ]
