How too get my TX5 moving?
Post new topic   Reply to topic    Forum Index -> 4 Cylinder Forum
SNAILD
PostPosted: Tue May 06, 2008 10:59 am    Post subject: How too get my TX5 moving? Reply with quote
hey guys just wondering if any of yous know some cheap mods i could do too my 1986 TX5 Turbo too get it moving a bit quicker..... its a basically stock 2L 8-valve turbo except for a Turbosmart Veeport 3 and Exedy H/D clutch....... any help would be appreciated! thanks
GeZza200
Donating Member
PostPosted: Tue May 06, 2008 11:30 am    Post subject: Reply with quote
Screw up the boost a few psi, should make it fly, the TX5 go fiarly well stock dont they?
fordfreak ef
View User Gallery (28)
PostPosted: Tue May 06, 2008 2:15 pm    Post subject: Re: How too get my TX5 moving? Reply with quote
rig up a DIY cold air intake? turbo's love fresh cold air.. aftermarket exhaust??
SNAILD
PostPosted: Wed May 07, 2008 11:08 am    Post subject: Reply with quote
ive been advised too get a better exhaust and intercooler before doing that
OBS35N
PostPosted: Wed May 07, 2008 11:26 am    Post subject: Reply with quote
intercooler, CAI and turbo back exhaust is he go cause it allows everything to run a lot free'er.
GeZza200
Donating Member
PostPosted: Wed May 07, 2008 3:14 pm    Post subject: Reply with quote
Yeah that is a good idea, but 2-3 psi boost wouldn't hurt and you would feel the difference quite alot.
haggis
PostPosted: Wed May 07, 2008 3:36 pm    Post subject: Reply with quote
On what premise can you be sure it won't hurt?
Darkr
PostPosted: Wed May 07, 2008 3:47 pm    Post subject: Reply with quote
Yeah man, lets just run more boost, which will give you more power for nothing.... :/
More boost = more heat, more wear.
You really need to take some precautions before just upping the boost, and make sure when you do to have run on a dyno to make sure you are not leaning out.
GeZza200
Donating Member
PostPosted: Wed May 07, 2008 5:28 pm    Post subject: Reply with quote
alright il shutup then, a mate of mine has a 626 turbo, im pretty sure there the same car. He has his at 12psi its standard.
cooki_monsta
PostPosted: Wed May 07, 2008 5:30 pm    Post subject: Reply with quote
Froudey
PostPosted: Wed May 07, 2008 5:46 pm    Post subject: Reply with quote
Pretty much been said.. need a decent intake setup being it a brand name pod filter or a known to work Cold Air Intake... a decent sized exhaust system a 3" possibly... a decent service from brand name plugs and leads and a 1 > 3 Psi boost increase after previous things have been done.
TROYMAN
View User Gallery (30)
PostPosted: Wed May 07, 2008 5:50 pm    Post subject: Reply with quote
a mate of mine had a tx5 turbo and any boost over 9 psi would cause the ecu to freak out and from 6psi to 9 psi made bugger all difference on the stock engine..
tx5_reaper
PostPosted: Wed May 07, 2008 6:36 pm    Post subject: Reply with quote
if he is running 2/3 psi boost he has a hose leak check that i use to own a 1985 tx5 turbo and they push out 7 psi stock i would be checking vacum hose before turning the boost up and not to mention these little ihi turbo cant handle more then 10 psi with out a intercooler even then i wouldent recamond going past 12psi
tx5_reaper
PostPosted: Wed May 07, 2008 6:40 pm    Post subject: Reply with quote
bty you cant stick a pod in these little beast because where are you going to put it because these have monster air filters in them as the afm is on the bottem of the round container for the air filter
SNAILD
PostPosted: Thu May 15, 2008 9:23 am    Post subject: Reply with quote
i have rigged up a K+N pod filter from the stock airbox and removed the stock filter.... next is the intercooler.... any suggestions on what to get for it? ive been told ill only need a small 1
ferr007
PostPosted: Thu May 15, 2008 10:11 am    Post subject: Reply with quote
put a 2.2l 12 valve from a later model in it much more power
tx5_reaper
PostPosted: Thu May 15, 2008 5:07 pm    Post subject: Reply with quote
nope again wont fit due to engine mounts and it wouldent be worth getting custom engine mounts
tx5_reaper
PostPosted: Thu May 15, 2008 5:38 pm    Post subject: Reply with quote
yes that is true you have 2 ways of doing it
and
if you need any more info go to www.tx5club.co.nr either jessriot or sabbia will help you
fordfreak ef
PostPosted: Fri May 16, 2008 12:06 pm    Post subject: Reply with quote
SNAILD
PostPosted: Wed Jun 11, 2008 12:26 pm    Post subject: Reply with quote
anymore ideas?
[47 queries :: 0.06879 seconds ]
