I second Death
cboz
PostPosted: Wed Jun 25, 2008 5:41 pm    Post subject: I second Death Reply with quote
My EF has a strange thing goin on where if I let it sit and idle in the driveway it runs perfectly except for every 2-3mins or so it almost dies for 1 second then returns to normal. It's like the thing chokes on something almost cutting it out, it sort of makes a venting air type sound at the same time. I know it's a bit vague but it's the best I can do. The prob doesn't really concern me as the car runs very sweet otherwise, but there is obviusly a minor prob with it, any ideas??
FORDom
PostPosted: Wed Jun 25, 2008 5:56 pm    Post subject: Reply with quote
-replace fuel filter
-check fuel pump (put your ear near it and see if it stops making a noise while its almost dieing)
-Clean the ISC
EL__Fairmont
PostPosted: Wed Jun 25, 2008 6:10 pm    Post subject: Reply with quote
Clean the contacts of the ISC plug?
Although I would say it's just the ECU re-learning the idle via the ISC. That venting sound is the ISC. I have been in a few ef/el falcons that do this, it's really nothing to worry about.
I think to fix it you just have to re-adjust the base idle speed with the ISC unplugged. You will need a set of feeler gauges to do it .
relaxed_diplomacy
PostPosted: Wed Jun 25, 2008 8:35 pm    Post subject: Reply with quote
My impression is the ECU has a pre-determined idle speed that it tries to maintain, and there is no provision for adjusting this.
Disco Frank
PostPosted: Wed Jun 25, 2008 8:44 pm    Post subject: Reply with quote
-Clean the ISC
whs ^^^ but in reverse
cboz
PostPosted: Wed Jun 25, 2008 10:55 pm    Post subject: Reply with quote
Thanks guys, you're a pack of legends
EL__Fairmont
PostPosted: Sat Jun 28, 2008 2:26 pm    Post subject: Reply with quote
you can adjust it, just need to short the top and bottom left pins on the diagnostic connector under the fuse panel. Disconnect the ISC plug and put a 0.75mm feeler between the throttle and stop tab and adjust it to your requirements...+- 50rpm from 700RPM.
Cheers............
relaxed_diplomacy
PostPosted: Sat Jun 28, 2008 9:02 pm    Post subject: Reply with quote
Okay. So what knob or suchlike are you actually adjusting? Or are you saying that at a set time during the 'self test' phase the computer will lock in the current operating rpm, and take that thereafter as the idle speed?
[35 queries :: 0.04893 seconds ]
