Age:27 Posts: 4732 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Sat Jan 15, 2005 10:30 am Post subject: |
| If the crossover is in the amp, and non-adjustable, there's nothign you can do, except get a new amp. |
Posted: Sat Jan 15, 2005 2:55 pm Post subject: |
| i went out today and bought a newe head unit. its an alpine cda9831. it has crossover features built in it. i also bought it because the system was sounding s**t have 6 channels running off only one pair of rcas. it is much better now and it blows the old cda 9821. |
Age:34 Posts: 2380 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Sun Jan 16, 2005 4:34 am Post subject: |
There are 2 types of x overs, active and passive. An active x over is fitted pre amplifier and passive is fitted post amplifier.
Majority of good home speaker systems use a passive x over, the main components beingof capacitors and chokes. The capacitors cut out the low frequencies and the chokes cut the high frequencies. Cheaper systems only use 1 bi polar capacitor meaning the woofer delivers low to mid high frequencies.
An active x over is superior as its easily tuned and supplies the amp only the frequencies required for the driver being used ( not like passive=distorted mid because of bass frequency clipping)
Instead of buying a new amp as suggested earlier, a far better option would be to install an active x over if the amps have been factory set at Flat. This means the sub amp can be delivered only low frequencies and the other amp for the 6x9's mid and high frequencies. |
aphexer Fordmods - Getting Side Ways
Age:24 Posts: 657 Joined: 08 Nov 2004 Location: Eastern Suburbs VIC, Australia
Posted: Mon Jan 17, 2005 12:58 pm Post subject: |
i think the myth was a little twisted from the beginning. most people would say "don't bother mixing 6X9's with subs" and with chinese whispers it ended up becoming "you can't mix 6X9's with subs"
there's nothing wrong with it, its just that there's no real point.
6X9's and 7X10's are cheap-man subs if you cant afford subs, u get the biggest speaker you afford to run of ur HU. |
Posted: Mon Jan 17, 2005 2:15 pm Post subject: |
| aphexer wrote: | | if you cant afford subs, u get the biggest speaker you afford to run of ur HU. |
What you saying you can't run a pair of 15"'s of my 4x25W HU ???
(not even if I add a 5F capacitor) |
dunis Fordmods Stock as a Rock
Age:25 Posts: 157 Joined: 10 Nov 2004 Location: sydney NSW, Australia
Posted: Mon Jan 17, 2005 2:35 pm Post subject: |
what?
Im running 4x12's off my deck.... |
Posted: Mon Jan 17, 2005 6:35 pm Post subject: |
yeh, 4 X 15" subs will work, just not very well unless you have a xplod headunit then they'll definately pump full sik |
NOCLAF Fordmods Stock as a Rock
Age:22 Posts: 107 Joined: 01 Dec 2004 Location: Perth WA, Australia
Posted: Thu Jan 20, 2005 9:52 pm Post subject: |
totally off the subject but.. my parcel shelf has been cut to fit my 6x9's... if and when i get a sticker for my cracked windscreen what do i hav to do to get it road worthey again?? im thinkn about putn a bit of carpeted mdf under neath them to cover the whole shamozzle up! |
Posted: Fri Jan 21, 2005 12:00 am Post subject: |
| NOCLAF wrote: | totally off the subject but.. my parcel shelf has been cut to fit my 6x9's... if and when i get a sticker for my cracked windscreen what do i hav to do to get it road worthey again?? im thinkn about putn a bit of carpeted mdf under neath them to cover the whole shamozzle up! |
Hurry and get your windscreen fixed, then you won't get a ticket. |
pyroay Fordmods Audio and Turbo Expert
Age:28 Posts: 2112 Joined: 14 Dec 2004 Location: Traralgon VIC, Australia
Posted: Fri Jan 21, 2005 11:16 am Post subject: |
| aphexer wrote: | ..............there's nothing wrong with it, its just that there's no real point.
And there you have it.
I agree entirley. 6x9's aren't the best sounding speaker but they are a good compromise if you are not going to be running a sub.
If you will be running a sub and highpassing your rear fill at 80htz then there is not point in getting 6x9's however as rear fill you shouldn't notice any difference between them and 6"s because they should be quite anyway.
Ideally you would have rear fill banpassed between 500 - 3k in mono, so it does not draw the soudstage backwads.
In that case a good quality 4inch or 51/4 midrange driver would be ideal. |
Posted: Fri Jan 21, 2005 4:10 pm Post subject: |
What he said ^
or no rears at all, they interfear with your soundstage. |
