Ignition wire - where to get power? (head deck install)
mystery
PostPosted: Thu Jun 05, 2008 6:18 pm    Post subject: Ignition wire - where to get power? (head deck install) Reply with quote
xf falcon, all wired up except for the red wire (ignition)
has to connect but don't know where to connect it to. should go to wire so that when ignition is turned on the thing gets the power.
thanks
outlawxr6
PostPosted: Thu Jun 05, 2008 6:47 pm    Post subject: Reply with quote
The factory wiring should contain the ignition supply.....
mystery
PostPosted: Thu Jun 05, 2008 7:08 pm    Post subject: Reply with quote
yeh but it has came off (person before had hooked it up to a 6 stacker and i don't know where the wire went)
so basically i need to know where to connect the wire so i get the ignition supply
any help please
mr_sperm1
PostPosted: Thu Jun 05, 2008 8:52 pm    Post subject: Reply with quote
ciggy lighter? anything that comes on when the key is in the ignition.
or, you can hook it to permanent power and just make sure you turn it off everytime you leave the car!
vrblou02
PostPosted: Fri Jun 06, 2008 12:22 am    Post subject: Reply with quote
easiest way would be to just splice into ur power wire from your cigaretter lighter
its generally the square plug wire which is pos as they have neg and pos
so if ur not sure
and want to be sure not to short anything
just use a power tester
or as quoted already aswell u could also run it to the same wire as ur yellow wire
soit runs permanent but its not recommended at all
where abouts in sydney are u located mate
good luck
Drifty
mystery
PostPosted: Fri Jun 06, 2008 12:38 am    Post subject: Reply with quote
yeh mate did a bit of reading on the net and i'll go at the ciggy lighter tomorrow. to the positive right?
vrblou02
PostPosted: Fri Jun 06, 2008 12:53 pm    Post subject: Reply with quote
yea mate
the positive on the ciggy lighter cus its switched power meaning when u turn ur key to accesorys it will power up which is wat u want
mystery
PostPosted: Fri Jun 06, 2008 7:02 pm    Post subject: Reply with quote
thanks for the advice mate.
the car is a mates, i have put everything in, all wired up EXCEPT the ignition wire.
put it into the smoke lighter, nothing happens so i thought bloody hell i gotta rewire the whole thing cos i made a mistake.
but the cigarette lighter doesn't work in the first place he said so thats why... (i removed the positive from the lighter and replaced it with my ignition wire - this is right yeh? or would i need to splice them together?)
so basically i'm after another source for the ignition wire. i have read that the ACC fuse can be used, anyone know where i can tap into it?
vrblou02
PostPosted: Sun Jun 08, 2008 9:19 pm    Post subject: Reply with quote
yes thats right
using the power wire from the cigarette lighter
should work
reason being the lighterdoesn work is probably the lighter itself
[36 queries :: 0.04623 seconds ]
