Injector & Fuel Pressure Talk - Turbo Application
CHEF
PostPosted: Tue Mar 15, 2005 3:21 pm    Post subject: Reply with quote
Ah better slip some in then, do they run off the EEC ok? Ive heard they do, but idle could be suss
MarkZE
PostPosted: Tue Mar 15, 2005 3:28 pm    Post subject: Reply with quote
Yeah I would have to agree about bigger is better on injectors for a turbo engine. Don't bother with anything smaller than about 50 lbs injectors. Around about the 550 cc/min minimum otherwise you will end up upgrading them again once you get a feel for the engine and wind the boost up.
I am on my third set of injectors now.
I had 340 cc/min injectors, maxxed them out, got hold of some 440cc/min injectors and maxxed them out so decided I wasn't messing around the third time and got some 750 cc/min Rochestors and stuck them in there.
Don't worry about idle too much unless you are trying to use a standard ECU. My car idles okay and it has a huge cam as well.
Also running high fuel pressures with little injectors is a good way to make a 600 hp fuel pump into a 400hp one.
Fuel flow capability of the pump changes with the inverse square of pressure it is required to supply. If you increase the working pressure you reduce the flow capability of the pump. This is particularly important when using rising rate regulators.
Always trial adjust your regulator up to the maximum pressure it will see in operation (allowing for rate rise if applicable) then flow your pump while the engine is stopped. Measure the amount of time it takes to get a litre or two of fuel returning to the tank or swirl pot and this needs to be able to keep up with your injectors.
Moral of the story is a 600 hp pump is not necessarily a 600 hp pump when it is pumping fuel at 70 or 80 psi into a rising rate regulator. Try to keep base pressures down around the 35 - 43 psi mark maximum especially if using a rising rate reg or you risk fuel line failures and fuel fires etc.
SVO XR6
PostPosted: Tue Mar 15, 2005 3:31 pm    Post subject: Reply with quote
EMS 8860 will run them fine :p
so you think they will do the job?
CHEF
PostPosted: Tue Mar 15, 2005 3:40 pm    Post subject: Reply with quote
depends on how much more air is going in, i belive they ahve been used on low boost set ups so you might find them ok... You'd get a set for next to nothing from a big pick n pay style wrecker anyway.
CHEF
PostPosted: Tue Mar 15, 2005 3:42 pm    Post subject: Reply with quote
just make sure you buy new Orings... I spent a few hours fiddling with leaky orings... I got a petrol stain on the wall...
SVO XR6
PostPosted: Tue Mar 15, 2005 3:47 pm    Post subject: Reply with quote
to go with the other stains too :p
do you know the size of the o rings?
SVO XR6
PostPosted: Tue Mar 15, 2005 3:50 pm    Post subject: Reply with quote
with the same fuel pressure as i tho?
CHEF
PostPosted: Tue Mar 15, 2005 3:57 pm    Post subject: Reply with quote
yeah, stockreg and pump
SVO XR6
PostPosted: Tue Mar 15, 2005 7:20 pm    Post subject: Reply with quote
sweet as, cheers
i look into some wrecked magnas on the weekend
sickd
PostPosted: Tue Mar 15, 2005 8:02 pm    Post subject: Reply with quote
are magna injectors bigger than ef (higher lbs)
SVO XR6
PostPosted: Wed Mar 16, 2005 12:46 am    Post subject: Reply with quote
i believe the EF ones are 19lb and the magna ones are 24lb
pyroay
PostPosted: Wed Mar 16, 2005 6:36 am    Post subject: Reply with quote
THANKS
dcstraight
PostPosted: Wed Mar 16, 2005 7:32 am    Post subject: Reply with quote
sickd
PostPosted: Wed Mar 16, 2005 5:56 pm    Post subject: Reply with quote
why wopuld they be bigger
SVO XR6
PostPosted: Wed Mar 16, 2005 7:47 pm    Post subject: Reply with quote
dcstraight wrote:
sorry, just got carried away
I got my new manifold on today, sexy, and it is maxing out big time now
CHEF
PostPosted: Sat Mar 19, 2005 9:40 am    Post subject: Reply with quote
Whens it hit the dyno man?
SVO XR6
PostPosted: Sat Mar 19, 2005 1:02 pm    Post subject: Reply with quote
when i get injectors :p
its leaning rite out after 3800rpm!!!!
lol
poor injectors, i feel for them chasing all that air.
i rang a magna wrecker, $80 each for thoes blue tops!!!!
f**k that
any other ideas?
CHEF
PostPosted: Sat Mar 19, 2005 9:10 pm    Post subject: Reply with quote
thats a ripoff! Maybe have a look on wogma
SVO XR6
PostPosted: Sun Mar 20, 2005 11:23 am    Post subject: Reply with quote
ive been told that increasing the fuel pressure will work for now.
the fact that injectors are looking expensive and i dont want to buy a set now and then another not too far down the track(for turbo), i was thinking about a ajst fuel reg (which will also be used with turbo). But the old trick of crushing the org fuel reg to crank up the pressure mite be the go.
its cheep and im interested in seeing how it goes... apparantly i should try to increase it by 10psi.
i have to find out the propper way to do it first, so any other ideas or how to's, pls say before i f**k this up icon_biggrin.gif
Bert
PostPosted: Sun Mar 20, 2005 7:16 pm    Post subject: Reply with quote
Use 2 sockets, one to go over the fuel thread and the other the fit in the channel but clear the vac barb. Put it in a Vice and crush it a LITTLE bit, THEN put it on the car and cheack the fuel pressure and repeat if need be.
You are getting ripped for $80 an injector!
Page 3 of 4
[47 queries :: 1.00034 seconds ]
