Injectors, Injectors, Injectors !!!
5150
PostPosted: Fri Dec 24, 2004 9:09 am    Post subject: Injectors, Injectors, Injectors !!! Reply with quote
Guys,
I am now looking into injectors for the ED V8
Std is 19lb / hr isn't it? What colour are they?
Would see a gain in performance if I go to 24lb / hr with the correct MAF set up on a standard cam? What colour are they?
For someting like a crane 2020 / 2030 or similar ... should I consider bigger than standard? If so how much?
Finally. with a 392ci in the pipeline .... should I consider 30lb / hr or maybe 36 lb / hr?
Cheers,
Waggin
Site Admin
PostPosted: Fri Dec 24, 2004 9:09 am    Post subject: Reply with quote
The Ford Motorsport 24lb/hr injectors are Blue icon_smile.gif
MrLandau
Commercial Sponsor
PostPosted: Fri Dec 24, 2004 9:44 am    Post subject: Reply with quote
Standard Ford 19lb/hr injectors are orange tops
24lb/hr injectors are blue tops
30lb/hr injectors are red tops
42lb/hr injectors are flouro green tops.
Changing injectors alone on a standard motor won't make you power - but if you upgrade from the HO intake/E7 heads to Explorer/GT40 or better and change cam and exhaust - the 19lb/hr injectors will start maxing out on their duty cycle and lean out (which is why the Sprint's, GT's and later AU's had 24lb/hr injectors)
Shane
Waggin
Site Admin
PostPosted: Fri Dec 24, 2004 9:47 am    Post subject: Reply with quote
Out of interest, where do the Black Top EB-EL 4L injectors fit into the equation ?
PostPosted: Fri Dec 24, 2004 10:01 am    Post subject: Reply with quote
I was always under the impression the 4L ran a 19# injector....
Waggin
Site Admin
PostPosted: Fri Dec 24, 2004 10:36 am    Post subject: Reply with quote
Me too, although someone has raised doubt in my mind recently.
I've heard a few people refer to them as 21lb/hr. If they were 19, why aren't they orange tops like the V8?
One Drone
PostPosted: Fri Dec 24, 2004 12:16 pm    Post subject: Reply with quote
I'd like to know also as I've been told the black ones are 21 or something like that.. A bit odd.
EBXR8380
PostPosted: Fri Dec 24, 2004 2:46 pm    Post subject: Reply with quote
I can only assume the 6's are from Aussie as the V8's have U.S backing...
When flow rates are measured always check the fuel pressure they where tested at , most Ford injectors are run at 38 Lb but other manu at 40 Lb...
XR8Chic
PostPosted: Fri Dec 24, 2004 9:48 pm    Post subject: Reply with quote
I only recently upgraded to 30lb injectors, they look more of a maroon colour than red.
When I was running the 19lb injectors, my car was happily making 185rwkw, but started to lean out when I got the new heads.
If you have big plans for your motor, get bigger injectors, if you are just going to do exhaust, cam and chip, leave the 19's.
[36 queries :: 0.03509 seconds ]
