install of Profec B
Tocchi
PostPosted: Tue May 13, 2008 9:54 pm    Post subject: install of Profec B Reply with quote
got a Profec B (series 1) for the EF.
all the PDF manuals ive found for this are corrupted.
the controller
the motor
which vacuum do i connect to the top of my wastegate (tial 44mm) ?
IN or OUT (on the motor)
and what do i do with the remaining vacuum line?
does the controller vacuum line connect up to the vacuum line that goes to the EMS8860 and boost gauge and such?
(it runs off the vacuum port on the inlet manifold)
Tocchi
PostPosted: Wed May 14, 2008 12:36 am    Post subject: Reply with quote
Quote:
this should sort you out
http://www.xspeed.com.au/manuals/Greddy_Profec_B_manual.pdf
so yeh, it confirmed
- the controller vacuum line goes to the EMS vacuum line
- "OUT" goes to top port on wastegate
but "IN" goes to a fitting on the intercooler piping, between the turbo and FMIC
... is that normal???
oh and also, my lower wastegate port isnt connected to the intake manifold, mine goes from turbo (front) housing to the wastegate port
ebs_4l
PostPosted: Wed May 14, 2008 9:40 am    Post subject: Reply with quote
nothing should be fitted in the same line as your map sensor... having the boost gauge and bov in the same hose is a bad idea, becuase you need the cleanest map reading possible..
you can tee into the line going to the bottom gate port from the comp cover and connect that to IN on the solenoid
Tocchi
PostPosted: Wed May 14, 2008 11:13 am    Post subject: Reply with quote
i actually havent had a good look at if the Map sensor, boost gauge & BOV are on the same line.
(the line was already there due to car being turbo a few years back, and then going back to NA)
... ill have a look after this coffee. lol
yep im doing that with the comp cover/gate port
ive got teflon/stainless braided line for mine, so ill get a t-piece and ill screw in a barb fitting for the hose icon_smile.gif
thanks
[31 queries :: 0.03112 seconds ]
