installing Electric windows how hard??
Disco Frank
PostPosted: Thu Mar 03, 2005 11:39 pm    Post subject: installing Electric windows how hard?? Reply with quote
ok i may get some electric windows for my car what i want to know is how hard is it to wire them up in to a car without electrics
i will have all the swicth gear and regs
uglybob
PostPosted: Thu Mar 03, 2005 11:49 pm    Post subject: Reply with quote
haha and you bagged me out cause electric windows you said were for fags! icon_razz.gif
anyways - i'm sure they'd be similar to the e-series ones wouldn't they? check the mods docs - & talk to ugly igley - hes currently doing the conversion to his Gli icon_wink.gif
fuzion
View User Gallery (17)
PostPosted: Thu Mar 03, 2005 11:59 pm    Post subject: Reply with quote
s**t easy
the regs fit in the premade holes
the prick of a thing is runnin cables thru the door rubbers lol
nightstalker
PostPosted: Fri Mar 04, 2005 6:43 am    Post subject: Reply with quote
I noticed the other day when I had the front door trims off that there was a electrical plug hanging inside the door cavity,would this be for the electric windows? I have a EL gli Falcon.
Ugly Igley
PostPosted: Fri Mar 04, 2005 11:09 am    Post subject: Reply with quote
The job is a billion times easier if you pick up the door loom with the power window wiring as well, then all you do is replace the whole lot, instead of trying to push new wires through a b**ch little door rubber.
The most important thing is using bolts that are short enough not to scratch the window when winding it up/down.....
Happy
PostPosted: Fri Mar 04, 2005 11:12 am    Post subject: Reply with quote
and on those bolts make sure you put on a split washer to stop them coming undone, or you'll be in there again after a few bumpy miles!!! icon_razz.gif
madmax
PostPosted: Fri Mar 04, 2005 7:19 pm    Post subject: Reply with quote
Nylocks, much better. IMO
JOSE
PostPosted: Fri Mar 04, 2005 9:44 pm    Post subject: Reply with quote
if the AU windows are anything like ED ones its not all that hard, the hardest part was feeding wires through the door rubbers (especially the drivers side one, was a bit of a prick finding power for them too, there is a spot for the fuse but no power goes to it, so i just found the big thick +12 line coming into the car and tapped into that (with a fuse in series), so far it hasnt drained my battery
Disco Frank
PostPosted: Sat Mar 05, 2005 12:36 am    Post subject: Reply with quote
ppft
mm might grab the loom....
Happy
PostPosted: Sat Mar 05, 2005 12:40 am    Post subject: Reply with quote
you know I was thinkin of them too but just could not for the life of me remember what they were called ... total blank!! icon_redface.gif
[37 queries :: 0.05327 seconds ]
