Posted: Sun Nov 28, 2004 6:31 pm Post subject: Installing temp gauge |
Just bought a splitfire temp gauge and it is a mechanical gauge with a capillery cable, Installed it all, BUT... the cable doesnt reach to my temp sensor underneth the thermostat. Is there a temp sensor on the back of the head on efs?
Has anyone done it a different way? My gauge is located on the pillar. |
Age:22 Posts: 10375 Joined: 15 Nov 2004 Location: Hobart TAS, Australia
Posted: Sun Nov 28, 2004 7:39 pm Post subject: |
| When I was doing my gauges, everyone I spoke to said mechanical gauges are illegal inside the cabbin. |
Posted: Sun Nov 28, 2004 7:57 pm Post subject: |
not that big a problem with water temp
the problem with oil and fuel pressure gauges is that they have a fluid line full of an (obviously) flammable liquid running into the cabin
with the temp gauges, they run a sealed sensor bulb that is immersed in the oil or water, and the sensor is run thru a pressurised line into the gauge, meaning no fluid is actually entering the cabin, making mechanical temperature gauges safe |
Posted: Sun Nov 28, 2004 8:19 pm Post subject: |
| so is there a way to hook it up besides the temp sensor under the thermostat? any gauge on the pillar is illegal in n.s.w |
Disco Frank Fordmods Junkie
Age:29 Posts: 13474 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Sun Nov 28, 2004 9:16 pm Post subject: Re: Installing temp gauge |
| XCH45R wrote: | Just bought a splitfire temp gauge and it is a mechanical gauge with a capillery cable, Installed it all, BUT... the cable doesnt reach to my temp sensor underneth the thermostat. Is there a temp sensor on the back of the head on efs?
dude u have mechanical gauge hence u cant hook it up to the temp sensor on the thermostat. the bulb at teh end has to be immersed in the coolant for it to work.
imy advice is mabye mount it under the dash ie above your knees or even on the side of the centre console
or take the gauge back and buy a electric guage and u can make the lead as long/short as u want and open up heaps of mounting options! |
Posted: Mon Nov 29, 2004 5:18 am Post subject: |
| true, although where would i get a correct temp reading ? |
Posted: Mon Nov 29, 2004 5:57 pm Post subject: |
what ya mean and for what gauge?
the mehcanical gauge cna be put anyware as long as it is at the "hot" side of the rad ie b4 the water has flowed into the rad hence why the thermostat housing is used |
Timboxrute Fordmods Parts Gopher
Age:25 Posts: 54 Joined: 12 Nov 2004 Location: campbelltown NSW, Australia
Posted: Mon Nov 29, 2004 6:03 pm Post subject: |
| correct me if i'm wrong but isn't there a coolant line running through the inlet manifold you could always run it from there ????? |
Posted: Mon Nov 29, 2004 7:32 pm Post subject: |
| yes frank, the mechanical gauge. the furthest the gauge cable reachs is my header tank, which wouldent give a very accurate reading. hence the reason i was asking if there was a temp sensor on the back of the head, pretty sure AUs have one there. |
Posted: Mon Nov 29, 2004 7:52 pm Post subject: |
no temp sender on the back of my au..
and the temp sender is for a electronic gauge not mechanical |
Age:22 Posts: 2432 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Mon Nov 29, 2004 8:01 pm Post subject: Re: Installing temp gauge |
| Disco Frank wrote: | | XCH45R wrote: | Just bought a splitfire temp gauge and it is a mechanical gauge with a capillery cable, Installed it all, BUT... the cable doesnt reach to my temp sensor underneth the thermostat. Is there a temp sensor on the back of the head on efs?
But Frank! Cant he just screw the mechanical sender (ie the bulb part) into the spot where the electrical sender normally goes? I cant see any reason why not, it has contact with the coolant, and its before he radiator  |
Posted: Mon Nov 29, 2004 8:03 pm Post subject: |
| yes he can i think that is what he has done but the caplilary tube is not long enough to reach to were he wants to mount the guage |
Posted: Mon Nov 29, 2004 8:05 pm Post subject: |
yeah i can do that but it wont reach, the bulb has like a thread on it to screw into somewhere? lol |
