daggo Fordmods Newbie
Age:22 Posts: 14 Joined: 08 Nov 2004 Location: Mandurah WA, Australia
Posted: Tue Dec 07, 2004 12:23 am Post subject: Installing turbo |
| Hey is it hard to install a turbo what would be the hardest part is there any website that will show me how to install one on e-series falcon. |
Age:22 Posts: 4799 Joined: 15 Nov 2004 Location: Perth WA, Australia
Posted: Tue Dec 07, 2004 1:01 pm Post subject: Turbo Question |
Depends on the turbo and what you were actually setup up....is it just the turbo as in all the manifolds, housing etc is ready to go or are you talkin the whole works : manifolds, turbo intercooler .... blah blah
Regards
Kev |
Thomas Fordmods - Getting Side Ways
Age:21 Posts: 1680 Joined: 08 Nov 2004 Location: Greenacre NSW, Australia
Posted: Tue Dec 07, 2004 2:01 pm Post subject: Re: Turbo Question |
| Big Kev wrote: | Depends on the turbo and what you were actually setup up....is it just the turbo as in all the manifolds, housing etc is ready to go or are you talkin the whole works : manifolds, turbo intercooler .... blah blah
Regards
Kev |
Naturally....  |
Posted: Tue Dec 07, 2004 7:55 pm Post subject: |
| its a kit with with manifold and piping |
Age:27 Posts: 4732 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Tue Dec 07, 2004 8:14 pm Post subject: |
| daggo wrote: | | its a kit with with manifold and piping |
pictures/links etc - more info would help us help you. |
Age:21 Posts: 2414 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Tue Dec 07, 2004 11:27 pm Post subject: |
Well if youre talking about turboing a naturally aspirated car, then i hope you're thinking low boost.
First things first, you need manifolds and exhaust. If you already have access to these, then these need putting on.
Once these are on, get the turbo sitting right, and make sure there arent anyclearance issues. Next thing would be an oil feed line, which generally comes from near the filter. Then you need an oil return line into the sump. But to do that, its best(needed) to take the sump off so as not to get any filings and such in. Might be an idea to weld the fitting in there so as it doesnt come out.
Then, depending on your turbo, it may need water cooling lines. If so, these need connecting. Once all this has been done, you can fit up the intercooler if you are getting one, then route the intake pipes. Its necessary to decide where you want your pipes to run before getting an intercooler, as the intercooler end tanks may not be suitable. Then just finish off the rest of the plumbing including blow off valves etc. (might i add psssschhht!) Its a fairly involved process, that doesnt just require bolting up.
If you want more information, or to look at some installs in some american mustangs, head over to www.turbomustangs.com Theres some very interesting reads in the forums, including one guy whos currently welding up the hot side with an alternator and little petrol motor. Ingenious, but i have other methods  |
[33 queries :: 0.05163 seconds ]
