Bassfreak55 Fordmods - Getting Side Ways
Posts: 533 Joined: 11 Nov 2004 Location: Canberra ACT, Australia
Posted: Fri Feb 18, 2005 7:51 pm Post subject: Instrument Clusters.. |
| Just wondering what clusters will fit an el xr8? |
uglybob Technical Contributor
Age:24 Posts: 5831 Joined: 05 Nov 2004 Location: Leederville WA, Australia
Posted: Fri Feb 18, 2005 9:50 pm Post subject: |
| any EF/EL Gli/Futura/Fairmont/Ghia/XR/ex-chaser without a worry - not too sure on the higher specs (eg DF/DL ones) i'm sure they'd take a bit of extra wiring though... |
Posted: Sat Feb 19, 2005 6:59 am Post subject: |
| uglybob wrote: | | any EF/EL Gli/Futura/Fairmont/Ghia/XR/ex-chaser without a worry - not too sure on the higher specs (eg DF/DL ones) i'm sure they'd take a bit of extra wiring though... |
Thats all i needed to know!
Cheers mate!  |
Posted: Sat Feb 19, 2005 9:09 am Post subject: |
Oh by the way, seeing that my car is an 8cyl, the new cluster doesnt have to be from an 8 does it? Ie. it can be from either a 6 or 8 cyl cant it?
Cheers. |
Posted: Sat Feb 19, 2005 3:00 pm Post subject: |
| Cant see why not as its running from the same reading points. Tacho might be different might need extra wires for the more cylinders. Everything SHOULD be the same (obviously you need extra wiring for a mid or high series cluster) |
raiki Fordmods - Getting Side Ways
Age:33 Posts: 450 Joined: 21 Dec 2004 Location: Adelaide SA, Australia
Posted: Sun Feb 20, 2005 12:55 pm Post subject: |
A six cylinder cluster will bolt straight in but your tacho will be wrong.
Your tacho is basically a freqency meter. At 3000rpm a six is 150hz and an 8 is 200Hz. |
Posted: Sun Feb 20, 2005 4:19 pm Post subject: |
| raiki wrote: | A six cylinder cluster will bolt straight in but your tacho will be wrong.
Thats for the info man. That'll come in handy..!  |
Matti Site Admin
Age:33 Posts: 519 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Tue Feb 22, 2005 5:33 pm Post subject: |
Actually an 8 cluster will work for a six, and a six will work for an eight !
Im running a EF LTD V8 Cluster in my I6 Fairmont, and there are no problems !
You might want to read this doco for changing instrument clusters.
http://www.fordmods.com/phpBB2/documents.php?doc=14
If you have an EL XR8, then the only higher model clusters out there are the police pack, and the High Series Ones.
Police pack allows you to adjust the speedo, which is good for diff conversions and rims size changes.
The high Series requires a whole lot of wiring changes, which isnt very friendly.
Anyways, everything is detailed in the doco |
