stixinc Fordmods - Getting Side Ways
Age:22 Posts: 499 Joined: 06 Nov 2004 Location: Ballarat VIC, Australia
Posted: Sun Apr 24, 2005 3:15 pm Post subject: Is It Possible? |
| G'day guys i was wanting to make my door lock button, fuel release and boot release buttons all light up, just wondering if it is possible to do so? |
Posted: Sun Apr 24, 2005 3:20 pm Post subject: |
| Also is it possible to replace the map reading lights globes with LED's? |
Age:27 Posts: 5006 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Sun Apr 24, 2005 3:36 pm Post subject: |
1. Not really, the 'white' is painted on, not transaprent like the demist button for example.
2. Sure. |
Posted: Sun Apr 24, 2005 4:44 pm Post subject: |
| ok so it is possible, does anyone know how to change my map reading light to an LED |
Posted: Sun Apr 24, 2005 5:11 pm Post subject: |
| If you're electronically minded, it'll be easy. If not pull a bulb out, and check the Repco catalog to see if they have a matching fit. |
Posted: Sun Apr 24, 2005 5:21 pm Post subject: |
| ok i figured out how to get them working now i want to know is it possible to have 2 LED's in the one socket? What do i need to do to get them to work at the same time? |
Posted: Sun Apr 24, 2005 5:40 pm Post subject: |
| Also if i am able to get 2 LED's together is it possible to make them flash at different times? |
Posted: Sun Apr 24, 2005 6:01 pm Post subject: |
To use two wire them in parallel, be sure to recalculate the resistor you need.
Flash???
You can get flashing LEDs, but usually only in red. and their flash rate isn't adjustable, so they'd flash together. If you want diff colours, diff flash rates, you'd need to build a flasher circuit. |
Posted: Sun Apr 24, 2005 6:04 pm Post subject: |
| ok cheers thanks for your help! |
Ryan0001 Fordmods - Getting Side Ways
Age:21 Posts: 743 Joined: 20 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon Apr 25, 2005 6:50 pm Post subject: |
| data_mine wrote: | | You can get flashing LEDs, but usually only in red. and their flash rate isn't adjustable, so they'd flash together |
id go with a flasher circut mate, cos if your never gunna get 2 flashing leds to flash in sync using the built in s**t electrics, thay'll allways fall in and out of sync. so grab what ever leds you want and run em off a flasher circus like mr mine said. good luck |
Happy Moderator
Age:35 Posts: 10004 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Apr 25, 2005 6:53 pm Post subject: |
| any particular reason for wanting flashing led's in you rmap reading lights? |
Posted: Mon Apr 25, 2005 9:03 pm Post subject: |
| Happy wrote: | | any particular reason for wanting flashing led's in you rmap reading lights? |
They're for cooking rice!  |
Mitch_ Cruise Moderator
Age:21 Posts: 5905 Joined: 05 Nov 2004 Location: Streets of Brisvegas QLD, Australia
Posted: Mon Apr 25, 2005 9:07 pm Post subject: |
| madmax wrote: | | Happy wrote: | | any particular reason for wanting flashing led's in you rmap reading lights? |
hahahaha! that'd look cool but and would be handy if you is hugry |
