Is my radiator alright?
Goto page Previous  1, 2
One Drone
PostPosted: Sun Jan 16, 2005 10:10 pm    Post subject: Reply with quote
Do you have an 8 bowsaw?
bowsaw
PostPosted: Sun Jan 16, 2005 10:23 pm    Post subject: Reply with quote
Na, does this make a difference? havent 8s got less coolant capacity? by a litre or two,
One Drone
PostPosted: Sun Jan 16, 2005 10:28 pm    Post subject: Reply with quote
I believe it does. The Windsor motors run a bit hotter than the I6s and when running fine they hover around the L. In the V8s I've found they tend to stick around M and A.
PostPosted: Mon Jan 17, 2005 9:13 am    Post subject: Reply with quote
Dunno about the I6 but windsor + cooling system takes 15L.
About all this "halfway between O and R" etc. - bring up the diagnostic on the odometer and get a specific reading. So if you know roughly what your boiling point is (let's say 100*c for water - add a few degrees for coolant and then add a few more for pressurised system) you can know exactly how close to disaster you are.
Going up steep hill @ 100km/hr for 15min on a hot day, mine would get to 110*c with a fairly shagged radiator. Any more than that and i would have bailed.
For recommended replacements - the ones yobbo has suggested sound like a good deal - everywhere ive seen em they about $320. Std replacement around 190
johnsxr6
PostPosted: Tue Feb 01, 2005 1:57 am    Post subject: ME TOO Reply with quote
I HAD THE SAME PROB, NO DIFFREIPPED INTO NATRAD, GOT A NEW ONE (RAD) NO NO AVAIL, STILL DOES THE SAME THING, SHOULD OF GOT THE LARGER RAD, 2 STANDARD RADS 5.0LTR FOR SALE, ONE WITH WARRENTY, ANY OFFERS?
madmax
PostPosted: Tue Feb 01, 2005 8:58 am    Post subject: Reply with quote
I'd say the guys are right with the radiator, most likely blocked. However before you spend a s**t load on a new one, have you checked your thermostat? You'd feel a right mug if you changed your radiator and still had the same problem.
FPRXR8
PostPosted: Tue Feb 01, 2005 9:24 pm    Post subject: Reply with quote
I have a EBXR8 which has pretty much the same set up and ive just replaceed my clutch fan as it was leaking oil and not working. After this is was still overheating so i returned it to motor radiators which is a Natrad dealer and they clean my engine out and the radiator. It was 50% blocked and i havent had any trouble since. I also replaced the fan-belt as it was severely cracked.
In your case i would say that it would be blocked and in need of cleanout and system flush. At the moment i use castrol anti-frezze anti-boil this works a treat. Whatever you do, do not use the red ford coolant as it eats at your rubbers inside your radiator and therefore creates unwanted leaks. Ideally your ride shouldnt run any higher than half on a 30-37 degree day with or without the air-con on
Good luck with the beast
95fairmont
PostPosted: Wed Feb 02, 2005 6:48 am    Post subject: Reply with quote
I would agree with this one. Just recently I observed that my temp has hovering around "M" which was a bit strange for me coze I usually have it between "A" and "L". I replaced the thermostat (although for another reason), and now it hasn't touched "M" eversince (hotday, aircon on, long idling, etc.) I recon my old thermostat wasn't opening fully.
Page 2 of 2
[35 queries :: 0.03901 seconds ]
