Is my radiator alright?
Bassfreak55
PostPosted: Fri Jan 14, 2005 6:00 pm    Post subject: Is my radiator alright? Reply with quote
Hey guys.
I was driving home from work this afternoon in the rain + heat..
The temperature gauge on my elxr8 was showing about 3/5ths of max temperature. It wasnt quite in the redline, but was only about 4mm off it!
I had the aircon going, but still, the temp gauge shouldnt have been that high i dont think. Should i be worrying? And why could this be happening?
Cheers.
Samsy
PostPosted: Fri Jan 14, 2005 6:03 pm    Post subject: Reply with quote
First check the obvious! hows the coolant level?
yobboford
PostPosted: Fri Jan 14, 2005 6:05 pm    Post subject: Reply with quote
used to happen to mine aswell, my radiator was about 30% blocked. new rad, no probs since.
Bassfreak55
PostPosted: Fri Jan 14, 2005 6:39 pm    Post subject: Reply with quote
Coolant levels are spot on. Bright green aswell - no brownish s**t!
So its still fresh..
So how did you know that it was blocked?
And also, if it needs replacing, ill replace it with a better one..
Any recommendations + prices?
Cheers.
yobboford
PostPosted: Fri Jan 14, 2005 6:57 pm    Post subject: Reply with quote
i only found out when i stuffed my rad recently, when i took it to the rad place they said it was blocked aswell and that was why it was creeping up when on the freeway with the a/c on.
i got a heavy duty rad from superior radiators (natrad) at moorebank, i went for the 2 row heavy duty for $319 inc. brand new, no exchange, they also do a 3 row for the same price. heaps better than the std one, never goes above a 1/4 now, even with a/c on.
Bassfreak55
PostPosted: Fri Jan 14, 2005 7:12 pm    Post subject: Reply with quote
Would the heavy duty 2-row be suitable for a modified engine? As i dont want to modify the thermo shroud with a 3 or 4 core.. Unless there is a kit available to suit the extra rows?
EDXR8
PostPosted: Sat Jan 15, 2005 11:04 am    Post subject: Reply with quote
There is no kit to suit the extra rows so you need to trim the plastic of the shroud if you wan tto fit the larger one. If you do go withe 2 row, there is a high flow core available (as fitted to the XR series which allows slightly better cooling than the standard 2 row. Depending on how many mods you have, a larger one would be useful, I run a 4 row in mine and it runs very cool even on 40 degree days with AC on.
Bassfreak55
PostPosted: Sat Jan 15, 2005 5:09 pm    Post subject: Reply with quote
Instead of modding the shroud, is there any way of actually removing it? Or is it not a good idea. Cos i do have a fair few major plans for the car in the near future..
Andrew J
PostPosted: Sat Jan 15, 2005 5:15 pm    Post subject: Reply with quote
Not a real good idea. The shroud is there to pull the air through the radiator and stop it cavatating. Id leave mine in place
Bassfreak55
PostPosted: Sat Jan 15, 2005 5:17 pm    Post subject: Reply with quote
Bugger!..
EDXR8
PostPosted: Sat Jan 15, 2005 5:46 pm    Post subject: Reply with quote
Modifying the shroud should not be a major job, just have to cut a bit of plastic off the sides I think.
Bassfreak55
PostPosted: Sat Jan 15, 2005 5:54 pm    Post subject: Reply with quote
Hmmm.. I might have a good look at it before i start to hack away at it!
Macca
PostPosted: Sun Jan 16, 2005 8:27 am    Post subject: Reply with quote
Hmm how do you get cavitation from a fan pushing air?
One Drone
PostPosted: Sun Jan 16, 2005 6:09 pm    Post subject: Reply with quote
If it's within normal on the gauge, then it's normal...
Bassfreak55
PostPosted: Sun Jan 16, 2005 7:51 pm    Post subject: Reply with quote
Yeah but compared to every other el xr8 that ive seen or been in with a healthy cooling system, it doesnt get anywhere near as hot as mine does! Mines only a couple of mm's off the redline on hot days with a/c on.. I dont think thats normal man, lol.. Better to fix it now then when it gets worse IMO..
bowsaw
PostPosted: Sun Jan 16, 2005 8:58 pm    Post subject: Reply with quote
Bugger that, if its 4mm off red, definetly something wrong, if it gets over half, i would be looking for something wrong.
One Drone
PostPosted: Sun Jan 16, 2005 9:37 pm    Post subject: Reply with quote
For a relatively hot day and with air con on, sounds fine to me.. However everything that has been mentioned (besides rad replacement) should all be regular maintenance anyway.
Bassfreak55
PostPosted: Sun Jan 16, 2005 9:56 pm    Post subject: Reply with quote
Exactly!
Everything has been maintained & checked more often then needed, hence the reason why it shouldnt be doing this...
NC 5ltr
PostPosted: Sun Jan 16, 2005 9:59 pm    Post subject: Reply with quote
dont buy a new radiator get it cleaned out out for a third of the price of a new one
bowsaw
PostPosted: Sun Jan 16, 2005 10:08 pm    Post subject: Reply with quote
I just drove 600km round trip, in 42 degree heat, with 4 in the car , loaded up, and the gauge never went past M, which was 97 according to climate control. Any higher than M would be something wrong.
[47 queries :: 0.05778 seconds ]
