Age:22 Posts: 10081 Joined: 15 Nov 2004 Location: Hobart TAS, Australia
Posted: Tue May 13, 2008 4:31 pm Post subject: Is number 1 cylinder closest to the timing belt or the furth |
Anyone know is number 1 cylinder is the one closts to the timing belt or the one furtherst away?
I'm buys doing a timing belt on a VTEC Honda Accord, need to put it at top dead, so I've lined the harmonic balance up, lifted the distributor cap off and it's either point to number 1 or number 4. if it's number 4 i need to rotate the crank another revolution. |
Age:25 Posts: 3474 Joined: 11 Nov 2004 Location: townsville QLD, Australia
Posted: Tue May 13, 2008 6:43 pm Post subject: |
| yes number one is the front cylinder. (the non gearbox end) |
Age:22 Posts: 2323 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Wed May 14, 2008 12:23 pm Post subject: |
| if your doing a timing belt does it really matter? |
Disco Frank Fordmods Junkie
Age:29 Posts: 13089 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Wed May 14, 2008 8:59 pm Post subject: |
| xpression wrote: | | if your doing a timing belt does it really matter? |
thats my thinking
just rip off the belt and change and disconnect battery to make sure u cant accidently attempt to start engine
and btw f**k
ALL CARS are number 1- whatever from the front of the engine ( or water pump side, non gearbox side etc )
unless it is a V engine where it can be different iirc the #1 cyl there is passenger side front ( or front right when looking front to back of engine )
some engines will be differnt of course
ohh did u check the plug leads? they can be numbered |
Posted: Wed May 14, 2008 9:36 pm Post subject: |
| Disco Frank wrote: | | xpression wrote: | | if your doing a timing belt does it really matter? |
thats my thinking
and btw f**k
on a V engine number 1 is still the forward most cylinder. some engines it front left some it's front right |
Posted: Wed May 14, 2008 11:46 pm Post subject: |
Because when you pull the camshaft and crank shaft sprockets off and replace the seals behind them. then tighten them back up. You can check that they along with the 2 balance shafts are all still in there proper position. saves having to go back later if there 1 tooth out etc. |
| Disco Frank wrote: | | ohh did u check the plug leads? they can be numbered |
yes i did and they're not. |
Posted: Fri May 16, 2008 12:08 am Post subject: |
| ive always found that marking the old belt and pulleys etc, and transfering those marks to the new belt always works well too, and serves as a double check that u have the correct new belt. |
Posted: Fri May 16, 2008 6:22 pm Post subject: |
| xpression wrote: | | ive always found that marking the old belt and pulleys etc, and transfering those marks to the new belt always works well too, and serves as a double check that u have the correct new belt. |
That's a decent idea. will use it next timne. |
Posted: Fri May 16, 2008 7:41 pm Post subject: |
it will also help you get the cam timing wrong if the guy befor you didn't get it right.
you'll just be transfering his mistakes |
Macca Moderator
Age:36 Posts: 2975 Joined: 05 Nov 2004 Location: Singleton NSW, Australia
Posted: Sun May 25, 2008 7:28 am Post subject: |
Have you done this yet, did you work out Honda engines run anti clockwise Makes a huge difference when turning over and checking timing marks due to belt deflection is different, if this is anything like most of the other mid 90's Hondas have fun getting the timing marks to line up, you have to make a judgement call and hope for the best. |
Posted: Sun May 25, 2008 12:00 pm Post subject: |
| Macca wrote: | Have you done this yet, did you work out Honda engines run anti clockwise Makes a huge difference when turning over and checking timing marks due to belt deflection is different, if this is anything like most of the other mid 90's Hondas have fun getting the timing marks to line up, you have to make a judgement call and hope for the best. |
Done almost 2 weeks ago now! Yeah, I was aware of the anti-clockwise. She's running fine. |
