Age:21 Posts: 1523 Joined: 13 Aug 2005 Location: Perth WA, Australia
Posted: Thu May 15, 2008 8:25 pm Post subject: |
| C'mon man, do a search, thats that much info on here about that cam its not funny. |
falcon gl Fordmods Tyre Shredder
Age:19 Posts: 333 Joined: 26 Mar 2007 Location: frankston VIC, Australia
Posted: Thu May 15, 2008 8:45 pm Post subject: |
| thats the crane cam isnt it is the buy it now price ok or is it to much sorry dont know much about cams also 1.6 or 1.7 rollers |
BOTTLEDUP Fordmods Tyre Shredder
Age:29 Posts: 350 Joined: 14 Jan 2007 Location: Perth SoR WA, Australia
Posted: Fri May 16, 2008 10:46 am Post subject: |
It will work with 1.6 rockers, but performs better with 1.7s.
You will need a tune to get it running properly. |
ALS008 Fordmods Parts Gopher
Posts: 60 Joined: 26 Apr 2008 Location: Melbourne VIC, Australia
Posted: Mon May 26, 2008 7:29 pm Post subject: |
Hi all, im thinking of going for a E303 cam in my EB. If i was to use this cam with some gt40p's and 1.7 rockers with i need to anything to the pistons. Will this combo still have valve clearance??
Also will this need a retune to suit the new cam?? What is the most cost effective(cheap) way to get a tune done??
Cheers Alllen |
Posted: Tue May 27, 2008 2:56 am Post subject: |
| ALS008 wrote: | Hi all, im thinking of going for a E303 cam in my EB. If i was to use this cam with some gt40p's and 1.7 rockers with i need to anything to the pistons. Will this combo still have valve clearance??
Cheers Alllen |
As long as you fit a better intake (explorer) along with a 65mm T/Body and the usual exhaust improvements you'll see a nice respectable result. Piston to valve should be fine provided to degree the cam in correctly. You will need to change the springs if you run 1.7 rockers, I'd replace them anyway. It will need a tune, take your pick for how you go with that... twEECer, flashtune or a piggyback ECU, or a full aftermarket ECU. |
