IT'S PERFORMANCE ENGINE DEVELOPMENTS
Goto page Previous  1, 2, 3 ... 16, 17, 18, 19  Next
Shugg
PostPosted: Tue Jan 24, 2006 8:11 pm    Post subject: Reply with quote
IT'S PERFORMANCE wrote:
Hi guy's the Au conversions are much more expensive over the earlier models Au conversions are $2200 plus fitting.
Cheers Mark
And worth every penny. Mark done my conversion. Big difference.
Shugg
mr_rx7_
PostPosted: Thu Feb 16, 2006 2:01 pm    Post subject: Reply with quote
Hey Mark..very interested in a Stage 1 rebuild (I'm very cash strapped :S).
A quick question...I'm going for a Snort Stage 2 turbo kit running very low boost (5psi or so)...would a Stage 1 rebuilt engine be okay for this setup?
Car is a bonestock automatic EF Falcon 6cyl with bout 290,000kms
IT'S PERFORMANCE
PostPosted: Thu Feb 16, 2006 8:07 pm    Post subject: Reply with quote
Hi mate i definatlly wouldn't recomend it. Remember horsepower doesn't come cheap.
Molloy
View User Gallery (23)
PostPosted: Thu Feb 16, 2006 8:12 pm    Post subject: Reply with quote
anywhere in aus for 200, thats gun just need a lil more and im set, you guys do gearboxes 2?
mr_rx7_
PostPosted: Thu Feb 16, 2006 8:39 pm    Post subject: Reply with quote
I been saving for a while and I pretty much know that I will be needing about $10,000 for the turbo kit. I just want to know how the Stage 1 engine will handle very small boost (bout 5psi)
Ace
PostPosted: Wed Mar 29, 2006 2:42 pm    Post subject: Reply with quote
Actually I'd be interested to know if you can work a setup to work best with a snort kit.
ATM Im thinking ITS Stage 3 or 4 + Snort Stage 4 + Manual conversion icon_biggrin.gif
Course this isnt going to be for some time as im still saving.
If I came to you when the time was right and handed you a snort kit and asked for a rebuild would you be able to fit the turbo and everything?
EB V8
PostPosted: Wed Mar 29, 2006 4:11 pm    Post subject: Re: IT'S PERFORMANCE ENGINE DEVELOPMENTS Reply with quote
Hi everyone glad to be back on board,
Here is some of the lost info on my stages or kits available i will repost info as i go
STAGE 1 115RwKw - $1,550.00
STAGE 2 130RwKw - $2.100.00
STAGE 3 145RwKw - $3,225.00
STAGE 3PS 160RwKw (A NEW PRODUCT) - $4,100.00
STAGE 4 170RwKw - $5,100.00
STAGE 5 180RwKw - $6,700.00
STAGE 6 OPEN RwKw (HOW MUCH DO YOU WANT TO $$$$$)
ALL STAGES ARE FULL ENGINE REBUILDS
ALL OF THESE PRICES ARE FOR FORDMODS MEMBERS ONLY !!!!!
EVERY STAGE 1 & 2 FORDMODS RECIEVES A $50.00 DONATION
EVERY STAGE 3 & 3PS & 4 FORDMODS RECIEVES A $100.00 DONATION
Remember all of these stages are FULL ENGINE REBUILDS not just head and cam kits because IT'S PERFORMANCE WITH RELIABILTY AND WARRANTY not just performance. Other products and specialties are:
Manual conversions from $1250.00
Auto conversions from $1250.00
LSD Diffs from $750.00
HI FLO intake mods
Muiltiple THROTLE BODY set ups ( twins - triples - six pack on the way )
Twin Throtle Bodies $1200.00
So lets get out there and smash some HOLDEN a**
HOLDEN stands for:
Holes
Oil
Leaks
Dents &
Engine
Noises
Any one who has any quiries can contact me on 0415 727 951 or (02) 46214178
or email me at itsperformance@aapt.net.au or post reply
look forward to talkin to you all i will post new prices and products and enhancments on a very regular basis.
HERE IS ALL THE INFORMATION ON ALL OF THE KITS;
STAGE 1 - 115RwKw
Genuine gaskets only
Genuine chain guides
Full reco head (std spec)
Xr spec cam
Chem clean block
Block skimmed
Brass welch plugs
Thermostate & O'ring
Race bearings
Black rings
Close & hone rods
Hone the bores
Linished or Regrind crank (depending on condition)
JP h/v oil pump
Spark plugs
Engine painted
Heavy duty head studs
Pureone oil filter & oil
STAGE 2 - 130RwKw
Same as Stage 1 plus
Sligtly bigger cam
35Thou shave of head
New pistons
STAGE 3 - 145RwKw
Same as Stage 1&2 plus
Larger cam
45Thou of head
Competion head gasket
Over size exhaust valves
20Thou oversize pistons
Rebore & Hone
Higer rated valve springs
STAGE 3PS - 160RwKw
Same as Stage 1,2,3 plus
Larger cam
50Thou of head
40thou oversize pistons (race series)
Mild inlet porting and polishing
Blue printed & Balanced
STAGE 4 - 170RwKw
Same as Stage 1,2,3,3PS plus
Major inlet porting & polishing
Exhaust port polishing
Molly rings
Billit timming gear and chain set
Mega cam
STAGE 5 - 180RwKw
Same as Stage 1,2,3,3PS,4 plus
Mega Monster Billit Cam
Min 60Thou of head (valve clearance check done to determine shaving)
Valve clearance to an absolute minimun
Extream inlet porting & polishing
Stages 3,3PS,4,5 have a number of other enhancement tricks to produce these figures.
That looks really good, does stage 2 include all labour costs?? where are you based? Ill probably have to freshion up the ghia
IT'S PERFORMANCE
PostPosted: Thu Mar 30, 2006 6:13 am    Post subject: Reply with quote
Hi everyone sorry i have not got back to anyone we are in the middle of moving house's computer will be shut down for a week if you need to talk to me can you please call my mobile number on 041 572 7951 or you can call my girlfriend and she will inform me of your call on 041 422 0630 cheers Mark
estgonXR6
PostPosted: Wed Apr 05, 2006 10:18 am    Post subject: Reply with quote
That all sounds great.... so tell me if I drove up from canberra how long would the job take and was it $400 for the swap....??
do you use a tickford head...?
Big Kev
PostPosted: Wed Apr 05, 2006 4:29 pm    Post subject: Reply with quote
What work were u actually wantin done by mark tho dude....you havent really said much
estgonXR6
PostPosted: Sat Apr 08, 2006 2:13 am    Post subject: Reply with quote
Ture I often leaeveout the important facts... Yeah I was after the Stage 3PS engine. I just need to know how long it takes to do the swap.
These prices fro these engines are awsome.
Is there any other mods that i would need to do, I on a EFXR6.
And the only mods I will have by then which is as soon as Iam back in OZ will be intake and headers and exaughst.
MalXR6
PostPosted: Sat Apr 08, 2006 6:53 am    Post subject: Reply with quote
mmmm, that stage 3ps looks nice
estgonXR6
PostPosted: Sat Apr 08, 2006 8:57 am    Post subject: Reply with quote
Yeah I know I cant wait to get it under my bonnet...
xr Rob
View User Gallery (17)
PostPosted: Sat Apr 08, 2006 9:44 am    Post subject: Reply with quote
yeah the 3ps is nice had mine done a few months back and love it marks a top bloke and knows what hes on about
im pritty shure he dose a swap in a day or 2 but to rebuild yours depending on how much work he has on about 2 weeks i think.
he dosnt come online all that often and hes in the middle of moveing so if your serious bout it ide be calling him
estgonXR6
PostPosted: Sat Apr 08, 2006 9:53 pm    Post subject: Reply with quote
Yeah i prob give him a ring as soon as I get back witch should be early next week... xr Rob do you have the 3PS...???
Was it worth every cent or what.. what car do you have considering you are in the ACT and so am I...
fordfreak ef
View User Gallery (31)
PostPosted: Sun Apr 09, 2006 12:22 am    Post subject: Reply with quote
i have the stage 4 n i can give the thumbs up.... nice n powerful,fuel efficient...
Big Kev
PostPosted: Sun Apr 09, 2006 7:42 pm    Post subject: Reply with quote
Robbo certainly has the ITS Stage 3 PS....goes hard as.... Hes runing a series 1 EF XR6 Manual.....Should see if Rob can take u for a spin in a week or so cause his cars getting some work done to it this week n next....so tee up with him to go for a ride and see what u think icon_smile.gif can recommend Mark tho hes a top dude and knows his s**t when it come to falcon 4ltrs
xr Rob
PostPosted: Sun Apr 09, 2006 9:01 pm    Post subject: Reply with quote
yeah as kev said ef xr6 i love it it hasnt finnished running in and opening up yet but its great
Shugg
PostPosted: Thu Apr 13, 2006 7:29 pm    Post subject: Reply with quote
Hey guys,
Mark is in the process of moving house and will not have an internet connection for about 10 days.
Any questions can be directed to him on his mobile 0415 727 951.
Also the "Clown Mobile is for sale", anyone interested icon_twisted.gif Give him a call.
Shugg
DaisyMaestro
PostPosted: Wed Apr 19, 2006 7:33 pm    Post subject: Reply with quote
Hey guys, (first time poster here).
Some background info: About 15 months ago I purchased a 6cyl '94 EF Fairmont Ghia (a far better ride than my old XD icon_smile.gif ). After a month of cruising around, it blew a head gasket. I got that fixed, and just recently I had it serviced and they said they noticed some oil 'bubbling' out from the head gasket (Nooo, not again!).
Anyways, instead of spending a grand or so getting it fixed again, I thought one of Mark's engines would be a great improvement for not much more. I feel I need a bit more grunt too.
I plan on keeping the standard 4sp auto, and I already have a 2.5" exhaust on it, and was thinking about getting the Stage 3PS.
I should probably be asking Mark these questions, but I just want to get some info before taking plunge.
- Will the Stage 3PS suit my setup with the standard auto?
- If I do the swap, do I need to get it blue-slipped, or can I drive-in and drive-away?
- What sort of affect on insurance premiums have others noticed with these kinds of mods?
Page 17 of 19
[47 queries :: 1.96575 seconds ]
