IT'S PERFORMANCE ENGINE DEVELOPMENTS
Goto page 1, 2, 3 ... 17, 18, 19  Next
IT'S PERFORMANCE
PostPosted: Fri Nov 05, 2004 9:57 pm    Post subject: IT'S PERFORMANCE ENGINE DEVELOPMENTS Reply with quote
Hi everyone glad to be back on board,
Here is some of the lost info on my stages or kits available i will repost info as i go
STAGE 1 115RwKw - $1,550.00
STAGE 2 130RwKw - $2.100.00
STAGE 3 145RwKw - $3,225.00
STAGE 3PS 160RwKw (A NEW PRODUCT) - $4,100.00
STAGE 4 170RwKw - $5,100.00
STAGE 5 180RwKw - $6,700.00
STAGE 6 OPEN RwKw (HOW MUCH DO YOU WANT TO $$$$$)
ALL STAGES ARE FULL ENGINE REBUILDS
ALL OF THESE PRICES ARE FOR FORDMODS MEMBERS ONLY !!!!!
EVERY STAGE 1 & 2 FORDMODS RECIEVES A $50.00 DONATION
EVERY STAGE 3 & 3PS & 4 FORDMODS RECIEVES A $100.00 DONATION
Remember all of these stages are FULL ENGINE REBUILDS not just head and cam kits because IT'S PERFORMANCE WITH RELIABILTY AND WARRANTY not just performance. Other products and specialties are:
Manual conversions from $1250.00
Auto conversions from $1250.00
LSD Diffs from $750.00
HI FLO intake mods
Muiltiple THROTLE BODY set ups ( twins - triples - six pack on the way )
Twin Throtle Bodies $1200.00
So lets get out there and smash some HOLDEN a**
HOLDEN stands for:
Holes
Oil
Leaks
Dents &
Engine
Noises
Any one who has any quiries can contact me on 0415 727 951 or (02) 46214178
or email me at itsperformance@aapt.net.au or post reply
look forward to talkin to you all i will post new prices and products and enhancments on a very regular basis.
HERE IS ALL THE INFORMATION ON ALL OF THE KITS;
STAGE 1 - 115RwKw
Genuine gaskets only
Genuine chain guides
Full reco head (std spec)
Xr spec cam
Chem clean block
Block skimmed
Brass welch plugs
Thermostate & O'ring
Race bearings
Black rings
Close & hone rods
Hone the bores
Linished or Regrind crank (depending on condition)
JP h/v oil pump
Spark plugs
Engine painted
Heavy duty head studs
Pureone oil filter & oil
STAGE 2 - 130RwKw
Same as Stage 1 plus
Sligtly bigger cam
35Thou shave of head
New pistons
STAGE 3 - 145RwKw
Same as Stage 1&2 plus
Larger cam
45Thou of head
Competion head gasket
Over size exhaust valves
20Thou oversize pistons
Rebore & Hone
Higer rated valve springs
STAGE 3PS - 160RwKw
Same as Stage 1,2,3 plus
Larger cam
50Thou of head
40thou oversize pistons (race series)
Mild inlet porting and polishing
Blue printed & Balanced
STAGE 4 - 170RwKw
Same as Stage 1,2,3,3PS plus
Major inlet porting & polishing
Exhaust port polishing
Molly rings
Billit timming gear and chain set
Mega cam
STAGE 5 - 180RwKw
Same as Stage 1,2,3,3PS,4 plus
Mega Monster Billit Cam
Min 60Thou of head (valve clearance check done to determine shaving)
Valve clearance to an absolute minimun
Extream inlet porting & polishing
Stages 3,3PS,4,5 have a number of other enhancement tricks to produce these figures.
Last edited by IT'S PERFORMANCE on Sun Sep 04, 2005 8:24 pm, edited 3 times in total
distortion
PostPosted: Fri Nov 05, 2004 10:03 pm    Post subject: Reply with quote
this may be a stupid question but whats the PS in the stage 3 new kit? thanks for the info Mark! Any prices on these??
*sells parents for money for car*
IT'S PERFORMANCE
PostPosted: Fri Nov 05, 2004 10:05 pm    Post subject: IT'S PERFORMANCE ENGINE DEVELOPMENTS Reply with quote
Also i can freight anything around australia an engine for eg: a engine anywhere for around $200 plus insurance if wanted.
Nigel
PostPosted: Fri Nov 05, 2004 10:08 pm    Post subject: Reply with quote
F**k if Id known about the freight Id have an engine of yours in my car now.
IT'S PERFORMANCE
Distortion not a silly question STAGE 3 145RwKw and
STAGE 3PS 160RwKw PS meaning (Performance Series)
distortion
PostPosted: Fri Nov 05, 2004 10:19 pm    Post subject: Reply with quote
oooh sounds good sounds good! any chance of some prices?
toxxic
Do you have an exact pricing figure on a Auto-Manual swap for a EL and a EF falcon?
Do all the options work after the conversion?
IT'S PERFORMANCE
PostPosted: Fri Nov 05, 2004 10:34 pm    Post subject: Reply with quote
Yes i will put Prices in this time they will be coming shortly for the stages but as for the manual conversions $1250 that includes:
computer
harness
box
flywheel
secondhand clutch and pressure plate
clutch cable
gear stic / boot
pedal box
nuts and bolts
plus $ 400 to fit if you wanted
toxxic
PostPosted: Fri Nov 05, 2004 10:36 pm    Post subject: Reply with quote
computer
harness
box
flywheel
clutch cable
gear stic / boot
pedal box
nuts and bolts
And everything works 100% ?
IT'S PERFORMANCE
PostPosted: Fri Nov 05, 2004 10:44 pm    Post subject: Reply with quote
Sorry forgot that question yes no problems everything works again GARRENTEED
ELfalcon_futura
PostPosted: Fri Nov 05, 2004 11:56 pm    Post subject: Reply with quote
Is there a portion of every Fordmods-based sale that goes into the running of the website? In my opinion it just seems fair that if a business makes money off a free service that has running costs, that something should be given in return for that business.
I may be interested in one of the lower kits (Stage 1 or 2) in about 6 months - nothing too drastic, insurance is bad enough as it is!
Bug
PostPosted: Sat Nov 06, 2004 12:37 am    Post subject: Reply with quote
Where abouts are you located?
1 SLY 97EL
PostPosted: Sat Nov 06, 2004 8:36 am    Post subject: Reply with quote
HOLDEN also stands for;
Heavy
Oil
Leaks
Disturbing
Engine
Noises, which are all the obvious signs of a fair percentage of those renowned Gen 3 V8's. Holden seemed to have prided itself on icon_twisted.gif
Timmeh
PostPosted: Sat Nov 06, 2004 9:34 am    Post subject: Reply with quote
Good to see ITS Performance back.
As soon as I can sell my car to get some money I'll be requiring a stage 5 kit.
Before I go on and ask more questions I'll wait for the money so I'm not wasting anyones time.
LG
PostPosted: Sat Nov 06, 2004 11:56 am    Post subject: Reply with quote
computer
harness
box
flywheel
clutch cable
gear stic / boot
pedal box
nuts and bolts
What sort of gearbox is it? Tremec T5?
Are they all brand new parts, minus the clutch and plate?
And is the computer that goes in like a XR Manual ecu?
Looks like i'll have to invest!
IT'S PERFORMANCE
PostPosted: Sat Nov 06, 2004 3:26 pm    Post subject: Reply with quote
They are all second hand parts and the Tremac are in the late au's and supplied when available. All parts are road tested befor sale to assure quality. The au man conversion's are $2000.
New kits are avaliable from $2500.00 for eb/el and au from $3500
Hyena
PostPosted: Sat Nov 06, 2004 10:46 pm    Post subject: Reply with quote
I had my stage 4 IT'S engine fitted last weekend icon_biggrin.gif It's still being run in and I have exhaust dramas at the moment (no fault of Marks, my cat collapsed and chunks of it are now stuck throughout the rest of the system clogging it up icon_confused.gif ) but after it's all sorted as I mentioned previously I'm happy to give anyone a ride who's looking at getting one of Marks engines.
Jaysen
Commercial Sponsor
PostPosted: Sat Nov 06, 2004 10:54 pm    Post subject: Reply with quote
Good pic mate, btw howd you come up with the name hyena?
Hyena
PostPosted: Sat Nov 06, 2004 11:03 pm    Post subject: Reply with quote
Nickname, long story - basically started in the early days of 'teh interweb' and scavenging MP3s ...and scavenging in general. haha
PS: That pic is from a few months ago, I'm being nice to my new engine Mark icon_smile.gif
mrnasty
PostPosted: Sun Nov 07, 2004 12:48 pm    Post subject: Reply with quote
What sought of intake mods have u got on offer?
Page 1 of 19
[47 queries :: 0.08012 seconds ]
