Age:37 Posts: 2464 Joined: 25 Nov 2004 Location: Sydney Australia NSW, Australia
Posted: Thu Jul 24, 2008 10:48 pm Post subject: |
When i replaced the blown gasket on the 5.0 I used Felpro for all the top end gaskets. Give Rare spares in Homebush a call and ask for Dean. He sorted me out on the intake to head gaskets for about 20 each from memory. Last time i checked genuine ford they wanted 80 a side.
Brett |
castlegreyskull Cruise Moderator
Age:25 Posts: 3973 Joined: 14 Dec 2005 Location: maryland, newcastle NSW, Australia
View User Gallery (34)
Posted: Fri Jul 25, 2008 6:05 am Post subject: |
Yep, 1" spacer will be going in.
Timing cover gasket should come with rollmaster kit.
I will be doing a bit of ringing around today, got rare spares up here i will call, also try and sort out rocket quote. They are bloody hopeless there, they dont want to help you one little bit.
And that quote from fraud, was only to supply the head gasket.... maybe he f**k up, but we both had a good laugh together. |
Posted: Fri Jul 25, 2008 11:30 am Post subject: |
| i am having a brain f@rt...... our engines are equivilent to the mustang 93-94 arent they? |
EL2XR8 Fordmods - Getting Side Ways
Age:30 Posts: 475 Joined: 04 May 2005 Location: Wollongong NSW, Australia
Posted: Fri Jul 25, 2008 12:02 pm Post subject: |
| i thought 86-93 for most items? |
Vic Cruise Moderator
Posts: 5589 Joined: 05 Nov 2004 Location: Melbourne VIC, Australia
Posted: Fri Jul 25, 2008 6:06 pm Post subject: |
| EL2XR8 wrote: | | i thought 86-93 for most items? |
Yep, that's our range. |
351EL Fordmods Stock as a Rock
Age:37 Posts: 161 Joined: 07 Jan 2006 Location: Innisfail QLD, Australia
Posted: Fri Jul 25, 2008 6:42 pm Post subject: |
| Vic wrote: | | EL2XR8 wrote: | | i thought 86-93 for most items? |
Except for timing cover, water pump and pulleys. |
Posted: Wed Jul 30, 2008 6:46 am Post subject: |
Cheers fellas, muchly appreciated.
Now... i have been trying to track down some bolts for the inlet manifold with the 1" spacer, and they do not sell the bolts the length that i need by themselves. Am i better off going to a bolt shop and ordering them through there? or does someone know where i can get them from?
This is what i have ordered:
Head gaskets
Head bolt kit
timing set
exhaust gasket
t/b to manifold gasket
manifold to head gasket
vave springs
valve spring reatiners
valve spring keepers
Stem seals
Lifters
Is there anything that is not needed or anything else that i will need, as i really dont want to be doing 2 orders, so i can save on postage and so i am not a*** around with parts.
But i can tell you this, i am as broke as i have ever been in a long long time. Didnt predict the parts was going to cost this much.
Cheers fellas
BEN |
steven13 Fordmods Stock as a Rock
Age:39 Posts: 156 Joined: 27 May 2007 Location: frankston VIC, Australia
Posted: Wed Jul 30, 2008 7:59 am Post subject: |
| I had to nuys 7in allen bolts for my 3/8 spacer as that was all I could get. Other than that they suggested I make my own. |
banarcus Fordmods - Getting Side Ways
Age:34 Posts: 496 Joined: 29 Nov 2004 Location: Kurri Kurri NSW, Australia
Posted: Wed Jul 30, 2008 11:10 am Post subject: |
| Call KC Harris in East Maitland. They stock everything or if they don't, they'll make it. If you want somewhere closer, try Blackwoods at Wickham or the bolt shop near the United servo on Industrial Dr. |
Posted: Wed Jul 30, 2008 3:37 pm Post subject: |
I got some threaded rod the same thread as the intake, then cut it to size and used that. SO i essentailly have studs with bolts on top. Not as tidy, but does the job
Brett |
Posted: Wed Jul 30, 2008 5:15 pm Post subject: |
Yeah i will try mullings at cardiff, as i only work just around the corner. see what they have, and if not i shall try a few other places.
What size are they 3/8? not a big fan of the threaded bar idea, i will work around it. |
chooka Fordmods - Smokin em up
Age:37 Posts: 266 Joined: 04 Jun 2005 Location: Northern NSW, Australia
Posted: Fri Aug 01, 2008 10:16 pm Post subject: |
| TerroristGHIA wrote: | I got some threaded rod the same thread as the intake, then cut it to size and used that. SO i essentailly have studs with bolts on top. Not as tidy, but does the job
Brett |
I used this option as well but I welded the nuts to the rod and cleaned it up to look neater.Never had any problems. |
[39 queries :: 0.05235 seconds ]
