JAYSON Fordmods Parts Gopher
Age:41 Posts: 64 Joined: 20 Nov 2004 Location: PENRITH NSW, Australia
Posted: Mon Jan 17, 2005 6:23 pm Post subject: KING SUPERLOWS |
| I have installed superlows into my EB back looks to be lower than the front is it the same for everyone ????????????? |
Timmeh Moderator
Posts: 6424 Joined: 06 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 17, 2005 7:21 pm Post subject: |
| Yeah I have king superlows fitted to my EF and the back is lower than the front by 10mm. |
e-falcon Fordmods Newbie
Posts: 12 Joined: 06 Dec 2004 Location: BRISBANE QLD, Australia
Posted: Mon Jan 17, 2005 7:31 pm Post subject: |
| Yeah, I put king springs in my EF Fairmont. If you look at the tyres to the wheel arch, the back looks lower. If you look at the sill panel to the ground, it looks level. They will settle a bit after a couple of weeks. |
Timmeh Moderator
Posted: Mon Jan 17, 2005 9:05 pm Post subject: |
Mine is actually 10 mm higher at the front measured from the running board (or sill). Its also visible by looking at the difference between the tyre and the arch.
Maybe they got the V8 springs and fitted those to the 6 cylinder. Being not as much weight at the front of the car the springs arent compressed as much. I'm just guessing though.
I'll just live with it. |
Posted: Mon Jan 17, 2005 9:17 pm Post subject: |
| yes sills are the same oh well just have to live with it |
Posted: Mon Jan 17, 2005 9:18 pm Post subject: |
| Mine is the same as e-falcon's. It looks a tad lower at the back but measure the sill to ground distance and its dead level. |
azza Fordmods - Smokin em up
Age:22 Posts: 261 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 17, 2005 10:42 pm Post subject: |
| yeh same with mine..... btu i noticed on frasers car his front sits lower but back sits higher.... i believe he has lovells all round |
cArSiK Fordmods Newbie
Posts: 19 Joined: 10 Nov 2004 Location: Sydney NSW, Australia
Posted: Tue Jan 18, 2005 12:55 pm Post subject: |
| same , even with just lows , the back was still lower... |
EF 4.9 Fordmods Stock as a Rock
Posts: 139 Joined: 08 Nov 2004 Location: Meeka, Coonland WA, Australia
Posted: Tue Jan 18, 2005 1:06 pm Post subject: |
yearh i have superlows and the rear tyre is futer in the guard than the front, however the car is dead level.
If it bugs you, you can install a nolathane 10mm spacer under your rear spring.
it is a lower spring seat, nolathane part# 47299 (EA-EL).
mate did it to his car and it looks level now. |
uglybob Technical Contributor
Age:24 Posts: 5800 Joined: 05 Nov 2004 Location: Leederville WA, Australia
Posted: Tue Jan 18, 2005 1:20 pm Post subject: |
| azza wrote: | | yeh same with mine..... btu i noticed on frasers car his front sits lower but back sits higher.... i believe he has lovells all round |
yeah when our cars were next to each other, mine seems to sit lower at the front than at the back - mine is fitted with KYB shocks & lovell springs all-round... |
