Posts: 2088 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Mon Mar 07, 2005 7:06 pm Post subject: Leaky diff - Help required. |
Noticed today that my diff has developed a leak from the front bearing area. It does not appear to be the seal but leaks from what appears to be the spline and out through the nut at the front. Is there a seal on the spline for the yoke? If not how do I go about fixing it.
TW. |
Age:34 Posts: 2454 Joined: 06 Nov 2004 Location: Melbourne VIC, Australia
Posted: Mon Mar 07, 2005 10:52 pm Post subject: |
| im not really sure what you mean by a nut on the spline. is this what you mean the mounting plate bolts are leaking, if so the plate has a small gap that acts as a breather when the seal leaks, i think its to prevent the fluid from leaking onto the disc and pads. |
Posted: Tue Mar 08, 2005 6:11 am Post subject: Leaky diff - Help required. |
| joolz wrote: | | im not really sure what you mean by a nut on the spline. is this what you mean the mounting plate bolts are leaking, if so the plate has a small gap that acts as a breather when the seal leaks, i think its to prevent the fluid from leaking onto the disc and pads. |
Sorry, perhaps not explained that well, its actually the Pinion that is leaking not the axles.
TW. |
Age:22 Posts: 2786 Joined: 06 Nov 2004 Location: Sydney NSW, Australia
Posted: Tue Mar 08, 2005 6:57 am Post subject: |
MitchG911 had the same problem, there is a bearing seal as I understood it, and you can buy them from repco, from memory wasn't that expensive, and from what he told me, it was easy to do.
I'll get him to come on here and explain...
Cheers |
Posted: Tue Mar 08, 2005 7:02 am Post subject: |
| justfordima wrote: | MitchG911 had the same problem, there is a bearing seal as I understood it, and you can buy them from repco, from memory wasn't that expensive, and from what he told me, it was easy to do.
Cheers |
Excellent, that may be all the info I need, a trip to Repco might get the rest of the info.
TW. |
Posted: Tue Mar 08, 2005 11:20 am Post subject: Leaky diff - Help required. |
Repco were no help other than to supply the seal.
Ford service were very helpful, they suggest I use blue silicon sealant on the spline and Nut.
I followed there sealant advise and additionally replaced the pinion seal as I had the yoke off anyway.
Replaced the oil with new stuff and tested it, no more leak now.
Thanks for your help,
TW. |
Posted: Tue Mar 08, 2005 3:55 pm Post subject: |
Good to hear mate.
No surprises about Repco lol.
Cheers |
ndroo Fordmods - Smokin em up
Age:22 Posts: 204 Joined: 06 Nov 2004 Location: Kurri Kurri NSW, Australia
Posted: Wed Mar 09, 2005 10:02 pm Post subject: |
how do you replace it ive got the same problem!
damn diffs..glad its not 4 wheel drive with 2 diffs i guess! |
Posted: Thu Mar 10, 2005 6:10 am Post subject: Leaky diff - Help required. |
| ndroo wrote: | how do you replace it ive got the same problem!
The advise I got to reseal the spline is, you need to remove the tailshaft, remove the retaining nut and apply the sealant to the inside surface of the nut and reinstall it. You don't need to remove the yoke as the sealant is forced down the spline. I actually replaced the seal at the same time.
TW. |
Posted: Thu Mar 10, 2005 8:47 am Post subject: |
thanks for that.
I havnt even got under the car properly and looked yet but its good to have an idea before i get going. Noticed the leak when i replaced the fuel filter.
I did the seal on the end of the gearbox myself months back now n was a lil disapointed to find another leak at the other end of the car haha. o well..ive replaced that many damn seals on this car...i guess thats what 260,000kms does to you rubber doesnt last forever. |
[37 queries :: 0.0505 seconds ]
