LED backlighting in EA-ED trip computer
JOSE
PostPosted: Sun Nov 07, 2004 9:12 pm    Post subject: LED backlighting in EA-ED trip computer Reply with quote
Got my trip comp in the other day (thanks chicken) and i decided i hated the original backlighting, $25 worth of Blue LED's and an afternoon later and its much improved, i took lost of pics, so one day i might write a doco on how to do it. See link for finished pics http://mikejose.tripod.com/Tripcomp.htm
Disco Frank
PostPosted: Sun Nov 07, 2004 9:22 pm    Post subject: Reply with quote
very nice mate well done i say
but why the $25 worth of blue leds? how many u need
voxace
View User Gallery (27)
PostPosted: Sun Nov 07, 2004 9:32 pm    Post subject: Reply with quote
Yeah $25, wtf?
Where did you get the LEDs from?
I got about 40 LEDs and 40 Resistors + some heatshrink tubing for about $30. 8000mcd LEDs too!
JOSE
PostPosted: Sun Nov 07, 2004 9:51 pm    Post subject: Yeh i know, Reply with quote
There are no (that i know of) cheap electronics stores round here, so i had a choice $8.50 for 8000mCD Blue LED's from d**k smith electronics or $3.95 each for the same ones at Jaycar (i chose jaycar - dunno why DSE charges $4.55 for the little bag and info sheet). i used 4: 5mm 8000mCD and 4: 3mm 700mCD, to get a good even strong glow, for both the screen and the buttons, i coulda got away with it with less LED's but i couldnt be bothered having to add more later, plus each string of 4 gets 14.2 odd volts, thats 3.55 each, so they arent overdriven. Next will be the instrument cluster, i will probably use some Electroluminescent wire, or a couple of CCFL's to get that job done.
Jimmy
Donating Member
PostPosted: Mon Nov 08, 2004 9:48 am    Post subject: Reply with quote
how did you get it to be so bright. Voxace did it to his and it only lights up in the middle ???
LTDHO
PostPosted: Mon Nov 08, 2004 10:43 am    Post subject: Reply with quote
The premade ones are expencive. The are a straight swap over from the standard globe. But it saves you soldering, etc
I used them in my digital dash. I have a bag of ultra bright 5mm and 10mm LED's here with LED's. Just need to put them together.
JOSE
PostPosted: Mon Nov 08, 2004 11:09 am    Post subject: Reply with quote
there are 3 5mm ultrabrights (with the tops filed off to create a more even light, and a wider beam angle) about 15mm behind the LCD screen, and i made a reflector assembly out of aluminum foil glued to cardboard behind there too. i had to remove the three plastic light carrier thingo's that light up the buttons to fit this though, hence the 3mm LED's to light the buttons.
na2fairlane
PostPosted: Mon Nov 08, 2004 11:21 am    Post subject: Reply with quote
so this involves no resistors?
how did you know what voltage or whatever to get?
i definatly wanna try this one out
voxace
PostPosted: Mon Nov 08, 2004 12:13 pm    Post subject: Reply with quote
Jimmy remember all I have used so far is a crappy supercheap wedge globe LED.
Shall be bright when it gets a few 'proper' LEDs in...
PostPosted: Mon Nov 08, 2004 12:27 pm    Post subject: Reply with quote
Looks good Jose. Some nice work there!
JOSE
PostPosted: Mon Nov 08, 2004 4:35 pm    Post subject: Reply with quote
i measured the potential difference (voltage) across where the normal filament globe plugs in, i got 14.2 volts, i used 8 LED's in two series circuits 4 in each, therefore each lot of four had a 14.2V volt drop across them, divide this by 4 and you get 3.55V drop across each LED, design spec says nominal is 3.5V 0.05V overdriven isnt gonna reduce their life span by any great amount so its all OK, and just drew the power for them from where the filament lamp goes,
japa62
Donating Member
PostPosted: Mon Nov 08, 2004 7:02 pm    Post subject: Reply with quote
Well done Jose. I have been playing with constructing some wedges, fingers are just to big. Have been playing with the same idea as you have done. Now I know that the wedges are just not up to the job.
The rest of the dash should be a bigger challenge but you have proven that implanting the leds in this manner is the way to go.
Thanx's
na2fairlane
PostPosted: Mon Nov 08, 2004 8:27 pm    Post subject: Reply with quote
so does it still dim with the dash lights and the stereo? i wouldnt want to lose that feature, nothing worce than being blidned when driving at night
japa62
Donating Member
PostPosted: Mon Nov 08, 2004 8:48 pm    Post subject: Reply with quote
Yep
[quote="jose"] and just drew the power for them from where the filament lamp goes[\quote]
Power from the same source.
Bugger, missed that wire. Shall have to think about what I can do with that wire icon_smile.gif
na2fairlane
PostPosted: Tue Nov 09, 2004 1:31 am    Post subject: Reply with quote
another question, does ur dimmer work on them? is that voltage the voltage when dimmer is set to full brightness?
brett351
PostPosted: Tue Nov 09, 2004 5:23 am    Post subject: Reply with quote
Looks pretty, I like it
JOSE
PostPosted: Tue Nov 09, 2004 11:28 am    Post subject: Reply with quote
I dont think the dimmer works, i probably messed something up somewhere, yes the 14.2 volts i measured was with dimmer at full brightness, it isnt really that bright, (unless you have night blindness or whatever they call it).
Can someone (voxace) who got their LEDS for cheap get in contact with me, im planning my instrument cluster mod next, and need about 40 blue and 8 red LED's for it ( 2 in each oil/fuel/temp/volt gauge, 8 in each tacho/speedo, and 8 for the front lightning, with red for lighting the red tacho zone, the odometer, and the text under the gauges
na2fairlane
PostPosted: Tue Nov 09, 2004 3:09 pm    Post subject: Reply with quote
ive posted on this twice since what has shown up and neither of them apeared? whats with that?
ok and now the two previous posts are back.. somthing very strange ..
evil6
PostPosted: Wed Nov 10, 2004 11:12 am    Post subject: Reply with quote
good work mate. i tried to put green led's in my dash but i think coz they wer from supercrap auto they wer hell dim and the orange still came through. so if i get brighter will it f**k off that horrible orange s**t?
e6
JOSE
PostPosted: Wed Nov 10, 2004 3:20 pm    Post subject: Reply with quote
e6
Yeh they will, but you may have to play around with how they are mounted, as the place where the normal filament lamps go is too far away for LED's to light it all up properly. they have to be a lot closer
[47 queries :: 0.07136 seconds ]
