ebxr8 Fordmods Parts Gopher
Age:22 Posts: 55 Joined: 19 Nov 2004 Location: Sydney - St Clair NSW, Australia
Posted: Thu Dec 30, 2004 5:50 pm Post subject: legal/illegal?? |
| i didnt exactly know what forum to place this topic in but never the less... i was just curios as to the legalities of car ride height front and back...i'd love to be sure of the law in times of need. cheers |
Age:22 Posts: 2432 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Thu Dec 30, 2004 6:04 pm Post subject: |
Depends where you live, but you need 100mm of clearnace from the lowest part of your car, generally the exhaust. Nothing is allowed to protrude below the height of your rims, except for fleible mudlfaps in the event of a tyre blowout. You also need either 2/3 or 3/4 of your original suspension travel.
generally, superlows are considered low enough for most people, and even these will get you scraping everything in sight. Superlows in most brands are between 45 and 60mm lower than standard. What sort of car do you have?
Edit: Silly question, an EBxr8  |
Posted: Thu Dec 30, 2004 6:23 pm Post subject: |
| i have an EB xr8, its been lowered, not by me, so that the back end sits roughly level with the front end. it scrapes slightly on some speed bumps. as a P plater i asked this question so i would know my rights when the pigs pull me over and give it the once over. |
Age:27 Posts: 4855 Joined: 24 Nov 2004 Location: Canberra ACT, Australia
Posted: Thu Dec 30, 2004 7:56 pm Post subject: |
| I've got whiteline superlows all round. perfectly legal. And scraping isn't MUCH of a problem, it does happen. But only if I'm not paying enough attention. |
Age:23 Posts: 2346 Joined: 07 Nov 2004 Location: Perth WA, Australia
Posted: Thu Dec 30, 2004 8:02 pm Post subject: |
| my ea had superlows on it. It was still legal although for me (living in country NSW) scraping was a problem at times. |
Posted: Thu Dec 30, 2004 8:03 pm Post subject: |
I'd recomment having a look at your states transport office website. http://www.rta.nsw.gov.au/ for NSW.
But Andrew J was correct to the best of my knowledge. 100mm minimum ground clearence, and must maintain 2/3 original suspension travel. The real catch is its ment to be 100mm minimum ground clearence with 4 adult passengers and a full tank of fuel.
I have exactally 100mm ground clearence with no on in my car, So I could be screwed. I have Kings Superlows all around. |
drazull Fordmods - Getting Side Ways
Age:25 Posts: 780 Joined: 05 Nov 2004 Location: Adelaide SA, Australia
Posted: Fri Dec 31, 2004 1:20 pm Post subject: |
Dont do that, fastest way to get a redneck cop to give you a hard time. Just explain that you have recently got your P-plates and as your first car you wanted something cool. The previous owner was a mechanic/cop/politician/soldier hence being the prudent (and hard working) bloke you are you were sure it was a safe bet. Will get it checked asap.
Thank him for his good community work, apologize again and wave him goodbye. |
uglybob Technical Contributor
Age:24 Posts: 5807 Joined: 05 Nov 2004 Location: Leederville WA, Australia
Posted: Fri Dec 31, 2004 1:24 pm Post subject: |
| hornet wrote: | The real catch is its ment to be 100mm minimum ground clearence with 4 adult passengers and a full tank of fuel.
s**t... i think i'll be in the same boat as you! mine is 110mm with NO weight in it!  |
