lights on ba cluster
phatba
PostPosted: Tue Apr 08, 2008 11:12 pm    Post subject: lights on ba cluster Reply with quote
just changed my 05 ba xt cluster to a fpv one from a gt-p. i now have a permanent traction control light showing. have heard that ford can re-program the cluster to my cars specs, but that it has to have less than 100km's on it. is this correct? if so is there another way around this?
xpression
PostPosted: Tue Apr 08, 2008 11:52 pm    Post subject: Reply with quote
you can reprogram the cluster at any time, you just cant reset the odometre on the new cluster to match yours if it has more than 100km on it. things like TCS can still be enabled/disabled.
phatba
PostPosted: Wed Apr 09, 2008 12:10 am    Post subject: Reply with quote
cheers mate, thats cool the cluster is only about 10 thou behind the original anyway. so it looks like a trip to fraud is on the cards, any idea on how much it'll cost?
Nicko
PostPosted: Wed Apr 09, 2008 8:05 am    Post subject: Reply with quote
50 bucks
Lukeyson
PostPosted: Wed Apr 09, 2008 8:00 pm    Post subject: Reply with quote
Spend the $50 on an ELM327 USB Scantool from eBay and I'll tell you how to turn it off for yourself. The 1.2a version + FTDI chipset is the way to go.
You do need a PC to do this though - say a notebook, or a computer not far from the car using one or more 5M USB repeater cables (not just simple USB extension cables I'm afraid.)
With an ELM you can also turn on or off Police Mode and Shift Alert and do a bunch of other stuff.
http://cgi.ebay.com.au/Elm327-USB-CAN-BUS-OBD-2-EOBD-Elm-327-OBD2-Scan-tool_W0QQitemZ320237611353QQihZ011QQcategoryZ32053QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Lukeyson
Lukeyson
PostPosted: Wed Apr 09, 2008 8:09 pm    Post subject: Reply with quote
Well, in the Ford Service world that's true, but in the open-a-cluster-up-and-reprogram-the-eeprom world that's not quite right.
It is possible to completely reset the clusters to zero, and then set the cluster to any value you want with an OBD2 tool like an ELM.
However, you will not learn this power from a Jedi.....
Lukeyson
phatba
PostPosted: Thu Apr 10, 2008 12:56 am    Post subject: Reply with quote
ok sounds like it could be interesting, can i do the same thing if i take the cluster out and use that doodah you told me about on my home pc? or does it have to be connected to the car?
Lukeyson
PostPosted: Thu Apr 10, 2008 7:34 am    Post subject: Reply with quote
The ELM327 is an OBD2 tool, so it plugs to the 16pin DLC socket in your fuse box - so the cluster should be in your car. Anything done with the ELM only requires the ignition to be on and a good charge on your battery. This is the port that the CAPA and Herrod guys use to reflash your PCM with a custom tune, and the Ford Diagnostic Tool uses to do it's thing.
It is possible to take the IC out - but you need to provide it power and connect the right pins to the ELM tool, and in the process the IC will start complaining about Open Circuit Fuel Sender circuits, or open circuit indiciators - and these would need to be cleared when it's next in the car.
I am assuming you're not talking about the bit where I said to 'take the cluster out and reset the ODO'. In case you did....
There are many things you can reprogram on the IC with the ELM - and the DSC/TCM light, Police Mode, Shift Alert, Body/Fuel Type - are some of them. The ODO can be changed if the IC has done less than 100km, and can only be changed up to 3 times - this is so a Dealer can replace an IC and set the ODO to the value of the old IC.
To change other things like the speedo calibration or axle ratio when you put on bigger wheels, however, requires reprogramming the PCM. The ELM could do this with the right software application and a bit of extra hardware, but at the moment it can't.
Now, to reset the ODO to 0, or to clear the 'reset counter' to 0, requires the cluster to be removed, the eeprom to be desoldered, reprogrammed, and resoldered. To set it to a specific non-zero value, the easiest thing is to then put it back in and change it with the ELM again. We're trying to do an 'in circuit' eeprom tool to skip the desolder/resolder bit, but at the moment that has been unsuccessful. So the only solution is to get that iron out.
The eeprom is also responsible for things like the stepper motor scaling (Speedo/Tacho), and for determining the cluster type - There are about 20 different cluster part numbers.
So in summary, with an ELM, we can step you through fixing your original light problem, (with the cluster in the car) or activate certain features. But for now if you want an ODO reset can I suggest contacting auMatt. He may be able to do it for a fee.
Lukeyson
jlgw70
View User Gallery (16)
PostPosted: Thu Apr 10, 2008 7:46 am    Post subject: Reply with quote
I have done this already.
Not as easy as everyne says it is.
There are restrictions on the FPV dash which cannot be turned off when used in a XT.
I ended up blanking the remaining warning lights out as the features were not in the XT anyway.
Lukeyson
PostPosted: Thu Apr 10, 2008 8:02 am    Post subject: Reply with quote
That's because everyone else is saying to do it at a Ford Dealer. Ford delears don't have access to the FPV bits when the tools sees an XT PCM - especially if it's a BF cluster and a BA PCM. They just can't do some of this stuff.
I'd still be interested to see if we could crack your 'light stuck on' nut with an ELM327 tool.
Lukeyson
jlgw70
PostPosted: Thu Apr 10, 2008 8:37 am    Post subject: Reply with quote
Ford had no chance - VDO instruments ended up doing the programming on the FPV cluster as it is hard coded which Ford dealers cannot do.
The clusters itself is programmed - not the vehicle - I stood and watched them do it (3 hours) to try to get everything working as it should and in the end I had to blank out 3 lights.
Lukeyson
PostPosted: Thu Apr 10, 2008 9:44 am    Post subject: Reply with quote
Yes, you are exactly right, the changes are made on the cluster.
During the initial connection process the Ford IDS tool queries all possible addresses on the CAN and ISO buses to see what modules are installed, but it specifically uses the PCM ID to determine what type of car you have, and builds it's list of supported configuration options from that. I've got the IDS software at home working on a Drewtech Mongoose J2534 tool. (IDS 52, they are up to 54 now)
I've seen some 3rd party tools that can do stuff on BA or BF Falcons. Snapon and Carman spring to mind. And those tools seem to copy the IDS/VCM operation, and as far as I recall, can't do all of the specific bitwise-operations that we're talking about either.
We can address the IC specifically with the ELM. We can tell you the 2 x Byte Offsets that list 8 specific bitwise values that can be changed. And we can tell you how to change individual bits to toggle these settings. The list includes (not in order):
(1) The TCM light
(2) The DSC light
(3) Seatbelt reminder
(4) Police Mode
(5) Hill Descent Light
(6) Shift Alert
(7) ABS via CAN/Hardwired
(8) Brakefail via CAN/Hardwired
Between BA and BF, (1), (2), (7), and (8) all need to be set right, not just (1) and (2) which the std Tools tend to change.
So I still reckon I'm up for the challenge of getting these lights working right on your cluster with an ELM tool.....
Lukeyson
data_mine
PostPosted: Thu Apr 10, 2008 9:59 pm    Post subject: Reply with quote
With Lukeyson's help I've changed various settings on my FPV cluster, namely turning on
4. Police mode
6. Shirt alert
fnp
PostPosted: Fri Apr 11, 2008 2:47 am    Post subject: Reply with quote
What is the shift alert function?
Lukeyson
PostPosted: Fri Apr 11, 2008 7:16 am    Post subject: Reply with quote
Vroom Vroom Vroom - Bing Bing Bing - Snickety Snick.
Only in FPV clusters I'm afraid. We've tried it on XT, BA XR, BF XR, SX Ghia and a few other clusters. It can be enabled as you please in any cluster, but the programming of the onboard 1608 CPU is what does the bing bing bing, and the FPV programming is a bit different to all the others.
Believe me, we've (ie auMatt and myself) tried heaps! Matt's even tried loading a whole FPV map into another Cluster eeprom. He can convert a low series to a high series (it just needs a high series LCD to complete the job) cluster - but not to an FPV Cluster. Yet.
Lukeyson
data_mine
PostPosted: Fri Apr 11, 2008 8:34 am    Post subject: Reply with quote
AS luekyson has said, it provides an audible series of beeps telling you you'd better shift real soon now or end up kissing the windscreen. Factory in manual FPVs, but can be enabled on auto FPVs (or disabled on the manuals if wanted).
Very handy because the rev limiter is brutal when the BOSS is at full song.
phatba
PostPosted: Mon Apr 14, 2008 12:45 am    Post subject: Reply with quote
ok so is this the tool i should be looking for lukeyson?
http://cgi.ebay.com.au/Elm327-USB-OBD-2-OBD2-OBDII-ELM-327-Elm-tool-Diagnostic_W0QQitemZ220223461881QQihZ012QQcategoryZ32053QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
my understanding is it connects to the pc via usb cable? i dont have a lap top only a desktop pc so might have to get a long usb cord to hang out the window. lol. is it possible to use an ethernet cable to connect to the pc? for some reason i have a 15m ethernet cable here.....
also thanks for all the help guys
Lukeyson
PostPosted: Mon Apr 14, 2008 7:32 am    Post subject: Reply with quote
There are 2 x things you want to check with an ELM327 USB tool.
(1) That it uses the v1.2a chip. Earlier versions can't go faster than 38.4kbps. The 1.2a on USB can go up to 500kbps. The DIL (http://en.wikipedia.org/wiki/Dual_in-line_package) removeable chip is best since you can upgrade in the future, but this is likely to be an SMD (http://en.wikipedia.org/wiki/Surface-mount_technology) version of the chip which is soldered on.
(2) It uses the FTDI USB chipset.
If you check the earlier eBay listing link of mine, you'll see that it says both of these. For that listing of yours I don't see that, so I would ask first if I were you.
I have another USB Scantool device (A j2534, not an ELM) that is sensitive to cable length at only 5m. I had trouble with a dumb extension cable and had to get a repeater. The USB repeaters regenerate the signal rather than just letting it attenuate over the length of the cable - but they are a bit more expensive. It depends on the sensitivity of the USB device, so all I can suggest is the 'suck it and see' approach.
5M USB M/F Dumb Cable: http://cgi.ebay.com.au/USB-2-0-Male-to-Female-M-F-5m-Meters-Extension-Cable_W0QQitemZ250236072373QQihZ015QQcategoryZ31495QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
5M USB M/F Active Repeater Cable: http://cgi.ebay.com.au/USB-2-0-1-0-Extension-Repeater-Cable-5-Meters-16-4-ft_W0QQitemZ200215079035QQihZ010QQcategoryZ31495QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
This last one may be what you're after. It says it's a repeater, but it looks to me more like it's just an extender.
5M USB M/F Cable ends with Cat5 Intermediate: http://cgi.ebay.com.au/USB-HUB-Extender-Coupler-Repeater-Up-50M-With-UTP-CAT5_W0QQitemZ120246449283QQihZ002QQcategoryZ3704QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
Lukeyson
phatba
PostPosted: Tue Apr 15, 2008 1:05 am    Post subject: Reply with quote
ok, well now im not huge in the elctronics market, so thought i better check these first to make sure they all good.
http://cgi.ebay.com.au/Elm327-USB-CAN-OBD-2-Elm-327-OBD2-Diagnostic-Scan-tool_W0QQitemZ220223862890QQihZ012QQcategoryZ32053QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
and this one
http://cgi.ebay.com.au/Elm327-USB-OBD-2-OBD2-OBDII-ELM-327-Elm-tool-Diagnostic_W0QQitemZ320239701724QQihZ011QQcategoryZ32053QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
to me appear to be the same thing and exactly what i need?
and if ive understood all this right, then
plugs into the usb port on the elm, and i can run my 15m long ethernet cable from that to the computer?
sorry to sound like such a dumb a** guys, but electronics isnt exactly my best field, and i want to make sure im getting the right stuff to do the job.
cheers jeff aka phatba
Lukeyson
PostPosted: Tue Apr 15, 2008 7:24 am    Post subject: Reply with quote
Of the ELM links, yeah, they both look the same to me too. Except the 2nd one doesn't say if it's an ELM327 1.2a Chip or not - so ask. Believe me, getting the 1.2a is a much wiser investment because of the speed.
As for the USB extender, it can't hurt to have a go. But the Ethernet Cable plugs into a USB dongle thingo at each end (a female at one end for the ELM, and a male at the other for the PC) - it doesn't just plug into USB at one end and an Ethernet port at the other. I'm thinking about getting one of those myself with a long Ethernet cable just to try it out. I could do with more than just the 5M length my current USB repeater gives me. If it works it would be fantastic.
Lukeyson
[47 queries :: 0.08323 seconds ]
