Look what I just read
Goto page Previous  1, 2
Jaysen
Commercial Sponsor
PostPosted: Tue Mar 22, 2005 10:56 pm    Post subject: Reply with quote
Waggin wrote:
4.9 EF Futura wrote:
Maybe have to retrain smartlock? Otherwise plug'n'play.
Smartlock learning is only Keyfob -> BEM <- Ignition Barrel.
What do you mean Brad?
data_mine
PostPosted: Wed Mar 23, 2005 7:40 am    Post subject: Reply with quote
The BEM handles security, not the ECU.
The BEM needs to learn the keyfob (remote), and the ignition key cylinder codes.
Mechan1k
PostPosted: Thu Mar 24, 2005 3:34 am    Post subject: Reply with quote
data_mine wrote:
The SA ECU pump out a bit more power too, as SA has less restrictive emmission regulations.
Their fuel is worse than ours though.
excopau
PostPosted: Mon Mar 28, 2005 11:14 am    Post subject: i own an ex cop au Reply with quote
Mine has an alloy tailshaft and not speed limited, have taken it to 220km many times with no problems car now has 200000km on it and all ok.
SVO XR6
PostPosted: Mon Mar 28, 2005 12:53 pm    Post subject: Reply with quote
Jaysen wrote:
its to my understanding that some of the tailshafts on fairmonts and ghias had a large harmonic type balancer just out of the end of the box. Maybe with this you couldnt exceed 180kph but because they use the same ECU in both the fairmonts and the lower models then it would be more economical for ford to make one generic ECU that makes them all speed limited. This would also explain why cop cars could exceed this 180kph because they were only falcons and the like. This balance weight even if it was only slightly out of balance would explain the vibrations that some people get at 180k's, and could literally vibrate its way out of the back of the box at speeds far in excess of 180. Its probably like SWL- 2/3 lower than what it can truly handle but a large safety buffer.
On my ELXR i have a alloy tailshaft. I had that big a** ballancer too. When i got it reballanced, as i dont trust thoes dam single piece shafts, i got the balancer pressed off to, made it a heap lighter too. Apparantly they cause more prob;ems then good.... I have no speed limiter, but would never go over 180 due to the tailshaft. Ive seen a video on tailshafts at high rpm, scary... icon_eek.gif
and ppl i know have been put on their roof due to them snapping at high speeds...not cool
Page 2 of 2
[32 queries :: 0.04738 seconds ]
