efLIAM Fordmods Parts Gopher
Age:19 Posts: 99 Joined: 08 Jul 2008 Location: jimboomba QLD, Australia
Posted: Mon Aug 04, 2008 4:02 pm Post subject: looking at turboing my ef 6cyl |
just wondering what internal modifications do i need to do if i turbo my ef 6 cyl? ie. forged pistons, cams, valves or what psi would i be able to run on stock internals?
cheers |
low ghia Fordmods Tyre Shredder
Age:40 Posts: 387 Joined: 21 Aug 2005 Location: perth western australia WA, Australia
View User Gallery (18)
Posted: Mon Aug 04, 2008 4:07 pm Post subject: |
before you cop a barrage of abuse ...
did you even use the search function?????
i did even before i started mine and the hard questions i then asked about..
dont need forgies n that s**t unless ure planning on running big numbers..
stock bottom ends in good cond can handle upto 15psi safely - depending on tune IIRC..
im running 10psi and my motors in mint cond..
you need dollars, and plenty of them. mine ended up at about $8000 -9000 all up ..do s**t yourself and you can save more dollars...
some of the other more experienced turbo boys on here can let you know more..
i forgot to add--- IF YOU BUY CHEAP s**t PARTS THEN THATS WHAT YOU'LL END UP WITH as your sitting on the side of the road with smoke pouring out from everywhere..
Age:24 Posts: 2268 Joined: 07 Feb 2005 Location: melbourne VIC, Australia
| 25 psi. stock internals. |
Posted: Mon Aug 04, 2008 4:10 pm Post subject: |
| Dansedgli wrote: | | 25 psi. stock internals. |
ha ha
ii was tempted to answer like that, but i got help from here so i thought id be nice...  |
Posted: Mon Aug 04, 2008 4:18 pm Post subject: |
lol 25psi. i have worked with turbos before but never on fords thats why i asked. sorry i forgot all about search function, ill go have a look.
cheers |
Age:24 Posts: 3046 Joined: 05 Nov 2004 Location: Mornington Peninsula VIC, Australia
Posted: Mon Aug 04, 2008 4:23 pm Post subject: |
| CAN BE DONE FOR 3K IF YOU KNOW WHAT UR DOING |
Posted: Mon Aug 04, 2008 4:53 pm Post subject: |
| I wasnt joking. Thats what Im going to do. :S |
Age:20 Posts: 895 Joined: 26 Nov 2004 Location: Waroona WA, Australia
Posted: Mon Aug 04, 2008 9:22 pm Post subject: |
stock internals will handle 20psi/400rwkw with good tune.
but stock compression wont allow u to run much more than 15-18psi. after that u will start to go backwards because ignition advance will be to low. |
