Low down on Thermo Fans
EDSteve
PostPosted: Fri Nov 26, 2004 10:27 pm    Post subject: Low down on Thermo Fans Reply with quote
Thinking about Thermo fans for my ED. Sprints are selling Ice brand in 10" 12" 14" & 16". Are they worth it? what size do I need? ect... How do you insall them?
Cheers.
Disco Frank
PostPosted: Fri Nov 26, 2004 11:16 pm    Post subject: Reply with quote
go the thermos off au or above
some here on ebay....
AU THERMOS
twr7cx
PostPosted: Sat Nov 27, 2004 1:38 am    Post subject: Reply with quote
AU THERMOS
Hmmm... I wonder who the seller of those is, hey frank?
fordgt290
PostPosted: Sat Nov 27, 2004 7:31 am    Post subject: Reply with quote
why u want thermos for engine fan do work alot better.
Disco Frank
PostPosted: Sat Nov 27, 2004 8:14 pm    Post subject: Reply with quote
god not this again
umm tw2321323 umm i may know the seller.....
XR6turbo
PostPosted: Sat Nov 27, 2004 8:51 pm    Post subject: Reply with quote
My fan on my ED does jack s**t, my car almost always overheats on a hot day. I have had my head done, thermostat replaced and im about to have the radiator checked in a couple of weeks. I think its the fan!
Foulcoon
PostPosted: Sat Nov 27, 2004 11:35 pm    Post subject: Reply with quote
Oi frank moit,
I got an EB II 6 - will these thermos fit?
Disco Frank
PostPosted: Sat Nov 27, 2004 11:49 pm    Post subject: Reply with quote
no idea measure up
ghiawar
PostPosted: Sun Nov 28, 2004 1:11 am    Post subject: Reply with quote
The last two days have been real stinkers in Adelaide, and have had the climate control working overtime whilst driving. My temp gauge seems to be hitting the upper end of the normla range, and the fan for the motor sounds like a turbine. I was told that I needed to get a "gel like" fluid injected into the clutch to fix this, at about $120.00
I think the electric fans might be a bit more reliable by the sounds of it.
Low EL
PostPosted: Sun Nov 28, 2004 8:17 am    Post subject: Reply with quote
FYI guys, thermos from an AU will NOT fit an e series without mods. From memory, they need to be fitted upside down, and a fair bit of the shroud cut away. Best thing to do is get a set from an ef/el, and wire them up. They will fit straight in. You can then use an aftermarket thermo switch to make them operate, or just wire them up to come on with the ignition.
Bozz
PostPosted: Sun Nov 28, 2004 3:33 pm    Post subject: Reply with quote
Disco Frank wrote:
god not this again
Hmmmm it might be because there's quite an element of truth to it.
If your engine is overheating AND the engine fan sounds like a boeing 747, you have some other serious issues.
My old man's ED never, absolutely NEVER has gotten above the "O" on the "normal" mark. This includes towing an 1100kg ski boat on 40 degree days with the air conditioner on, in heavy traffic, with 5 of us fat cnuts onboard and a dozen slabs in the boat.
Bozz
PostPosted: Sun Nov 28, 2004 3:35 pm    Post subject: Reply with quote
Although I'd say its because he religiously changes all fluids and the fluid reseviour still looks brand new, even though its 11 years old.
ghiaman
PostPosted: Sun Nov 28, 2004 4:24 pm    Post subject: Reply with quote
Just fitted a set of EL fans to a V8 Capri. Fitted with just a small amount of shroud cover cut with a air saw. Not as large as the AU's. They work fine with the aftermarket switch. Does a better job than the craig davies ones that were on it. Go the EF/EL ones.
ghiaman
voxace
View User Gallery (27)
PostPosted: Sun Nov 28, 2004 7:13 pm    Post subject: Reply with quote
Yeah you can get the EL ones from www.ozeparts.com.au for $180 and they bolt straight in.
Then you can get a Davies Craig 0404 kit + another relay and get it workin sweet.
Disco Frank
PostPosted: Sun Nov 28, 2004 7:58 pm    Post subject: Reply with quote
thats more the reason than the clutch fan.
id rather have 2 thermos than 1 clutch fan
CHEF
PostPosted: Sun Nov 28, 2004 8:24 pm    Post subject: Reply with quote
Yeah thermos will give you some extra Kw too, dam those old viscus clutch s**t things!
Dr_Hoon
PostPosted: Sun Nov 28, 2004 8:47 pm    Post subject: Reply with quote
I fitted some EL thermo's to my 351 clevo xd and they worked alright. I had some serious over heating problems, but the fans pretty much cleared it up. I had the fans bought new and a davies craig thermo switch. I had them running nearly all the time.
Foulcoon
PostPosted: Sun Nov 28, 2004 9:51 pm    Post subject: Reply with quote
ok, Im a dumb noob with fords, but:
Does the EL thermo fan come with a thermatic switch I just wire into the ignition? (with a relay to avoid voltage drop icon_wink.gif ) or do I need to get meself a davies craig thermatic switch?
And also what/were is the wire I use to connect these fans.
If it comes complete with thermatic switch, I doubt I will have much trouble.
ghiawar
PostPosted: Sun Nov 28, 2004 10:07 pm    Post subject: Reply with quote
Well I have decided to bite the bullet and install the electric fans.
So I now need:
Electric fan set from ef/el
Davies craig thermo switch
relay and wiring loom - where do I get this from, Davies Craig?
Anything else I need to know?
voxace
PostPosted: Mon Nov 29, 2004 8:17 am    Post subject: Reply with quote
You need Davies Craig kit 0404, which has the thermo switch, relay, fuse, some wiring and is about $70 from supercheap. You will also need another relay if you want them to come on with the A/C too (about $7 from supercheap).
[47 queries :: 0.05942 seconds ]
