ea_5_spd Fordmods Stock as a Rock
Age:22 Posts: 184 Joined: 01 Sep 2005 Location: kadina SA, Australia
Posted: Tue Jan 09, 2007 8:03 pm Post subject: lpg turbo falcons |
what is needed? ie lpg side of things
type of converter and how 2 hook it up 2 boost applications |
Slabz Fordmods - Getting Side Ways
Posts: 426 Joined: 26 Jan 2005 Location: Adelaide SA, Australia
Posted: Sun Jan 14, 2007 9:02 am Post subject: |
| i'll be interested to know this too. i've been asking around if any converter can run boost (even if its only very small ammounts) just by fitting a balance line. |
gryph Fordmods - Getting Side Ways
Age:28 Posts: 702 Joined: 11 Nov 2005 Location: Geelong VIC, Australia
Posted: Sun Jan 14, 2007 10:23 am Post subject: |
| Get a gra setup with 2 converters u can flow 300rwkw or thereabouts. |
Age:21 Posts: 2403 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Sun Jan 14, 2007 11:31 am Post subject: |
| Yep possible with GRA converters and throttle bodies. You need to drill and tap, and screw in a fitting (about 3/8 from memory per converter was sufficient for my bosses supercharged HQ) that connects to manifold pressure, so that the converter sees manifold pressure, not atmospheric. Other than that, i think its all reasonably simple? |
Age:24 Posts: 2926 Joined: 05 Nov 2004 Location: Mornington Peninsula VIC, Australia
Posted: Sun Jan 14, 2007 9:10 pm Post subject: |
that sums it up basically.
thats all i've done.
still hasnt had a tune  |
Posts: 1497 Joined: 30 Apr 2006 Location: Melbourne VIC, Australia
Posted: Sun Jan 14, 2007 11:11 pm Post subject: |
| EFFalcon wrote: | that sums it up basically.
Have you got yours intercooled? |
Posted: Mon Jan 15, 2007 11:48 am Post subject: |
| Private9 wrote: | | EFFalcon wrote: | that sums it up basically.
yes |
ltd351T Fordmods Stock as a Rock
Posts: 169 Joined: 10 Nov 2005 Location: Canberra ACT, Australia
Posted: Wed Jan 17, 2007 9:49 pm Post subject: |
Both GRA and impco mixers (200/225/425) will work fine, the GRA mounts nicely onto XF injected intake manifold.
The impco mixers are far easier to tune and many more dyno shops will tune them, GRA mixers are hard to tune and its expensive to get the different metering rods, and even then a lathe may be needed to fine tune.
The GRA mixers come with a T/B in them and are easier to mount/package into most setups, the impco mixers are just that, a mixer only.
The impco VFF30 vacuum lockoff is far better than any elec lockoff.
Electric lockoffs can be modified slightly for more flow.
You need to boost refference the converter by putting a tapered fitting in front of the throttle body so that it picks up the incoming air/boost.
If you use a VFF30 you also need to plumb in to that.
GRA converters use different spring kits to impco and they are not really compatible with each other, although they will work if you fit a GRA converter to an impco mixer it will use excessive ammounts of gas.
One B2 converter is rated at 280hp continuos flow, the impco model E converter from memory it shares the same internals as the B2 but is rated slightly higher as its heat trasfer properties are better/ie its bigger and can boil off more gas.
One std s**t electric lockoff generally doesn't flow above 130rwkw.
Tank flow can sometimes be poor depending upon the weather and the mixture of butane/propane in the tank.
Tanks can be modified to flow more, by removing the lockoff from the outlet valve, but thats not something I'd call safe, although many do it.
With a modified siphon tube and removed lockoff and bigger feed line a single 80lt tank will give out 550rwhp of fuel, but it won't sustain that flow rate for long. Some people have pulled big HP with only single tanks, I'd love to know how they did it, or if the tank is modified.
The easiest legal way to acheive better fuel flow is to fit twin tanks if possible, twin lines, twin lockoffs, twin converters, etc. |
Blu Falc Fordmods - Getting Side Ways
Posts: 1540 Joined: 27 Apr 2005 Location: Perth WA, Australia
Posted: Fri Jan 19, 2007 10:55 am Post subject: |
| can someone post a pic of two mixers in an engine bay with a turbo setup please |
Posted: Fri Jan 19, 2007 1:01 pm Post subject: |
converters where airbox used to be.
Twin B2's.
Posted: Fri Jan 19, 2007 11:01 pm Post subject: |
cheers, would you mind posting up another pic showing the right side more from above  |
Posted: Fri Jan 19, 2007 11:16 pm Post subject: |
| thanks, that was exactly what I was after |
TURBOTAXI Fordmods Parts Gopher
Posts: 51 Joined: 19 Mar 2006 Location: Dubbo NSW, Australia
Posted: Sat Jan 20, 2007 6:57 am Post subject: |
Can be done with a complex convertor and ring (simple) mixer. The Landi Renzo SM+P is rated for over 300hp and is only $220 to buy new from the importer. This is my AU I have travelled about 36,000k's in. With no other mods (ecu, timing, etc...) it pulls 162rwkw and has heaps of torque. |
Posted: Sat Jan 27, 2007 11:39 pm Post subject: |
| If anyone here knows is it possible to run more boost on a gra setup than 6psi with no aftermarket ecu???? Ive heard u can but the source was a lil untrustworthy so id rather hear it from sum1 else first. |
Posted: Sun Jan 28, 2007 11:38 pm Post subject: |
| gryph wrote: | | If anyone here knows is it possible to run more boost on a gra setup than 6psi with no aftermarket ecu???? Ive heard u can but the source was a lil untrustworthy so id rather hear it from sum1 else first. |
mine has seen 8-9 psi, but only at part throttle.
WOT sees boost drop abck to 5-6psi due to exhaust restriction. |
Posted: Tue Jan 30, 2007 12:09 am Post subject: |
| What size exhaust u running on it? Interested to see if say 10-12psi is possible with the right setup. |
Posted: Tue Jan 30, 2007 2:12 am Post subject: |
| mines got 3" dump pipe, goes into 2.5" into cat, back of cat has 2.25" flanges (the restriction) then 2.5" for the rest (press bent over the diff) |
Posted: Tue Jan 30, 2007 2:35 pm Post subject: |
Hmm im gonna go 3" all the way through so hopefully would not encounter the same problems so early
Thanks mate |
