Posted: Wed May 14, 2008 4:20 pm Post subject: Manual Shifters - Quick/Short Shifts for T5 - interchangabi |
Anyone able to confirm or deny that the the same manual shifters are compatible from XF right through to BA on the T5 gearboxes found in the 6 cylinders?
RipShift (http://www.ripshift.com/rip_ford.html) lists the same part number, RSFT5, for XF to AU - 5 speed they don't discriminate whether it is 6 or 8 cylinder. Then for the BA they have different part numbers depending on 6 cylinder or 8, and T5 or T56. But there is no part number for a standard BA T5 in a 6cylinder (only V8), there is a part number for an XR6T with a T5 - RSFT5T - essentially the same part number as above but with a T on the end.
The Autotecnica have the FT5LS (http://www.autotecnica.com.au/performance_17.html) which suits AU T5's and BA Turbo T5s.
so this indicates that what fits on an AU T5 is the same as what is on the BA turbo T5. Then Ripshift indicates that they're the same from XF to AU, so therefore the BA/AU one from autotecnica should fit pre-AU T5's too...
Then there's also the B&M (http://www.bmracing.com/index.php?id=products&sid=3&cat=3&subcat=15) and Proform (http://www.proformparts.com/mistore/productdisplay.php?sku=407957&hdwt=31101&loc=101&dealer=no&company_id=100719) models from the USA market. B&M's shifter for Ford T5's uses the same part number for a variety of US Ford's with T5's from Mustangs to Cosworths. Any idea if these fit the T5 found in our Falcons? |
Posted: Sun May 25, 2008 12:30 pm Post subject: |
| No one knows then? |
millard455 Fordmods - Getting Side Ways
Age:24 Posts: 770 Joined: 19 May 2005 Location: naracoorte SA, Australia
View User Gallery (29)
Posted: Sun May 25, 2008 12:42 pm Post subject: |
| i was talking to a bloke at the clipsal 500 about the billet shifter for my elxr and he said when i pull out my curent shifter i would have to check if somthing was the same length as the new one before i fitted it because there is a difference but ford couldnt tell them what date the change happend and if it wasnt the same id just have to send it back and they would send me the right one so they musnt be compatible. sory i cant remember what he said was different, it was a big weekend. |
mr_sperm1 Cruise Moderator
Age:21 Posts: 2522 Joined: 28 Jun 2005 Location: Hobart TAS, Australia
Posted: Sun May 25, 2008 8:23 pm Post subject: |
| My Billet shifter was for EA-AU. If you can see BA and AU being the same, it should fit. |
Posts: 1962 Joined: 06 Nov 2004 Location: Canberra - The Nations Capital ACT, Australia
Posted: Sun May 25, 2008 8:54 pm Post subject: |
| AFAIK BA has different hole spacing for the lever but should otherwise be usable. I will be able to confirm this in the next few weeks. |
Posted: Thu May 29, 2008 7:51 pm Post subject: |
| The Herrod sureshift arrived in the post today. Its from a BA XR6T tremec box and I am going to try and transplant it into the T5 on the weekend. |
Age:21 Posts: 678 Joined: 01 Sep 2007 Location: sydney NSW, Australia
Posted: Thu May 29, 2008 8:50 pm Post subject: |
as far as i know, as long as you get a t5 shifter, it'll fit on any 5spd manual from X-BA falcon.
bloody good investment too.
i have a steeda short shifter, much better than stock! |
Posted: Fri May 30, 2008 6:49 am Post subject: |
| SgtBourne wrote: | as far as i know, as long as you get a t5 shifter, it'll fit on any 5spd manual from X-BA falcon.
i have a steeda short shifter, much better than stock! | I have found that at least the BA GT and pursuit have a shorter (by 1cm) shaft which means if used on other T5's the ball will not stay in contact with the shift block in all gears.
See the center shifter. http://www.autotecnica.com.au/performance_17.html |
Posted: Fri May 30, 2008 9:58 am Post subject: |
| twason wrote: | | SgtBourne wrote: | as far as i know, as long as you get a t5 shifter, it'll fit on any 5spd manual from X-BA falcon.
I believe that that is because BA GT's didn't have a T5, they had the Tremec TR-3650. |
Posted: Sat May 31, 2008 10:29 am Post subject: |
| I can confirm the BA T5 and E series shifter are interchangable. I have a factory fitted Herrod Sureshift from a BA XR6T on my EF T5 and I have the EF shifter swapped over to a BA XR6T box I am rebuilding. One could assume that the AU will also work. As twr7cx said the Tremec 3650 is a different story. |
