Me monitor, She no workie!
4LEDboy
PostPosted: Sat May 03, 2008 1:20 pm    Post subject: Me monitor, She no workie! Reply with quote
G'day
For some reason my LCD monitor is switching off about 1/2 a second after I press the power button.
I found a service manual for it on the web but all it says is check BD (WTF is the BD?) I pretty sure its not the back light, could it be the inverter? Power supply? The Monitor is a Benq FP91G
Thanks
NAfairlane...
PostPosted: Sat May 03, 2008 1:55 pm    Post subject: Reply with quote
is there a fuse in the power supply?
4LEDboy
PostPosted: Sat May 03, 2008 1:57 pm    Post subject: Reply with quote
Haven't opened it up yet but I assume there would be, can't see it being the problem though, the light comes on and the benq splash screen flicks up for a little bit icon_confused.gif
cooki_monsta
PostPosted: Sat May 03, 2008 2:00 pm    Post subject: Reply with quote
wont be a fuse as the monitor turns on, if you were in vic id help you out, i used to repair plasmas for a living
4LEDboy
PostPosted: Sat May 03, 2008 2:03 pm    Post subject: Reply with quote
Bugger! icon_sad.gif , Have yo seen this problem before? Any Idea what it could be? icon_smile.gif
JOSE
PostPosted: Sat May 03, 2008 4:47 pm    Post subject: Reply with quote
my mums benq monitor had a similar issue, got fixed under warranty (took two goes though) ended up being a f**k inverter board
Shortshift
PostPosted: Sat May 03, 2008 8:47 pm    Post subject: Reply with quote
I had the same problem with LCD monitor. It was the transformer in the back. Replacement cost & labour was about $130.
zxhoon
PostPosted: Tue May 06, 2008 11:37 am    Post subject: Reply with quote
does it go completely off, or does the light go amber?
4LEDboy
PostPosted: Tue May 06, 2008 5:47 pm    Post subject: Reply with quote
zxhoon
PostPosted: Wed May 07, 2008 8:11 am    Post subject: Reply with quote
hmm was hoping it went amber, standby... then it might have just been a bad connection to the gfx card.... sounds like something in the power supply
savage78
View User Gallery (16)
PostPosted: Wed May 07, 2008 11:25 am    Post subject: Reply with quote
i have the same lcd as you 4LEDboy mine did the same thing about a year ago please check your power leads monitor end and wall socket thats all mine was it was out a little it was still getting power same thing happen as yours i all so unpluged all and let sit for about a hour then pluged it all back in so maybe try this and see how you go good luck
Low EL
PostPosted: Thu May 08, 2008 7:35 am    Post subject: Reply with quote
How old is it? Cause most BENQ stuff has a 3 year warranty.
bradysarlo
PostPosted: Thu May 08, 2008 6:59 pm    Post subject: Reply with quote
usualy a fault with the inverter or backlight... but ive worked on a couple benQs that have had faulty capacitors in the power supply, so have a look for swallon/leaky caps....
4LEDboy
PostPosted: Fri May 09, 2008 7:24 pm    Post subject: Reply with quote
Ok cool, I had it apart last night and checked the fuse (argg should have checked the caps icon_mad.gif )
[41 queries :: 0.03906 seconds ]
