Epitome Fordmods Stock as a Rock
Age:36 Posts: 196 Joined: 05 Nov 2004 Location: Manjimup WA, Australia
Posted: Mon Jan 03, 2005 1:20 pm Post subject: |
| 4.9 EF Futura wrote: | | I think that kind of stuff is available innit? I imagine this is how a dry sump would operate. |
Actually dry sump systems use multi chamber belt driven pumps. That is they have three or for pumps in one unit.
Typically two chambers are used for sump scavanging purposes. One chamber is used to feed the motor. And if there is a fourth chamber (V8 supercar teams use 4), it is most often used as a crank case vacuum pump. |
Posted: Mon Jan 03, 2005 1:23 pm Post subject: Re: Militec-1 |
| Overkill EF wrote: | Spotted the add for this in a magazine and are wondering if anyone has used or heard of it before.
The website for it is www.frictech.com |
While I have no experience with Militec, I have heard good reports from other drag racers who have used it. |
Disco Frank Fordmods Junkie
Age:29 Posts: 13277 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Mon Jan 03, 2005 7:29 pm Post subject: |
| Sketch wrote: | *thinks* i know what im doin this weekend,,,,, remote oil filter,,,, with an electric pil pump, similar to dry sump,,,,
but on a 555Timer on the oil pressure sender,,,, ill do a tech writeup when ive done it, but itll basicly be ,,,
when teh ignition is on, and the oil pressure is below a set limit, teh oil will be pumped through the galley's by the pump, then when pressure is up, i.e engine running,,, the pump will freeflow as normal..... |
mm weekend over... so is it done? |
master Fordmods Parts Gopher Donating Member
Age:33 Posts: 88 Joined: 09 Nov 2004 Location: IPSWICH QLD, Australia
Posted: Wed Jan 05, 2005 8:33 pm Post subject: |
| A friend of mine, who has been in to racing in the past, recommended that I use Penrite, he seems to think it is one of the best oils, what would you guys say ? |
Posted: Wed Jan 05, 2005 8:53 pm Post subject: |
We use Penrite and several other drag racers I know use Penrite too. I haven't spoken to any others about what they use.
We buy HPR50 in 20 litre drums.
Posted: Wed Jan 05, 2005 11:53 pm Post subject: |
| master wrote: | | A friend of mine, who has been in to racing in the past, recommended that I use Penrite, he seems to think it is one of the best oils, what would you guys say ? |
PENRITE IS THE s**t i run penrite engine oil, trans oil and theire super think blue lsd oil! |
Sketch Fordmods Parts Gopher
Posts: 75 Joined: 02 Dec 2004 Location: Woodlands WA, Australia
Posted: Thu Jan 06, 2005 11:31 pm Post subject: |
| Quote: | | A further question for you. You will take the oil pickup for the electric pump from the base of the sump, right? |
taking it from the sump drain plug with a screw in hose fitting.
havent done it yet as mates cars died and had to fix em
my weekend was spent
replacing the timing cover and waterpump on a Eb302
fitting a cam on an i6
fitting 3 thermofans
and fising ignition probs on 2 of my mates cars,,,
didnt get aorund to doin my own stuff,, although i did convert from the dodgy AU thermo's to a sweet 16" volvo one,, mmm cooling.. |
Posted: Fri Jan 07, 2005 2:09 pm Post subject: |
Cool, thanx for the advice guys.
I think I'll start using Penrite. The previous owner was using Mobil I think. |
Posted: Fri Jan 07, 2005 10:30 pm Post subject: |
| master wrote: | Cool, thanx for the advice guys.
I think I'll start using Penrite. The previous owner was using Mobil I think. | ohh if he was using mobil 1 from at least 40thou kays kepp using mobile 1
it is actually very very damn good oil expensive yes but if the engine has had it since under 40thousand kays it worth it it actually stops alot of wear! |
Posted: Sat Jan 08, 2005 10:34 pm Post subject: |
I'm getting the car tuned by an expert here in Brisbane, I'll see what he says, I'm not sure if the car has run Mobil 1 since under 40 thousand, because I am the third owner, I'm sure my mechanic can tell me.
Thanks for that advice Disco Frank  |
[37 queries :: 0.045 seconds ]
