missfire/stall
efmont
PostPosted: Sat Feb 26, 2005 3:33 pm    Post subject: missfire/stall Reply with quote
has anyone had problems with a bad miss and nearly stalling in an auto. i have got an EF 6 which recently had a bad idle but i fixed that with a new set of leads and plugs. when i am at the lights it occasionally want to cut out for a second and stops just short of stalling. any help will be great
MAX
PostPosted: Sat Feb 26, 2005 9:51 pm    Post subject: Reply with quote
Had that problem with my EF Fairmont about 6mts ago turned out to be the Cam Angle Sensor should run a self diagnosis test could be something simple. Also try removing the ISC Solenoid and clean out with CRC there was a artical on FM1 about cleaning the ISC.
WDOGG
PostPosted: Sat Feb 26, 2005 11:00 pm    Post subject: Reply with quote
To the left of your air intake is a small unit known as the idle mixer something like that, it has either 2 or 4 bolts holding it on its situated on or next to the throttle body if you remove it and the plug holding it there and spray it out with crc it should help a bit by loosening up the spring and then of course put it back... lol need more, i'll try and remember what i said last time...
South
PostPosted: Sun Feb 27, 2005 12:52 am    Post subject: Reply with quote
MAX: My Cam Angle Sensor is shagged too. How much did it cost to replace? You do it yourself or take it into a mechanic?
MAX
PostPosted: Sun Feb 27, 2005 8:31 am    Post subject: Reply with quote
SOUTH: cant remember the price got it at trade $100+ esey to fit just followed instructions from the Gregorys repair manual just like fitting a old points distributor.
[32 queries :: 0.027 seconds ]
