Waggin Site Admin
Age:25 Posts: 6757 Joined: 18 Dec 2002 Location: Sydney NSW, Australia
Posted: Sat Apr 02, 2005 11:24 pm Post subject: |
| Bert wrote: |
99% of the cars on the street don't need sequential. All it does pretty much is tame big injectors at idle, clean emissions, and give about a bees d**k more power. |
I need all the help I can get at idle to 1000rpm.. its a bit rough there. |
Posted: Sun Apr 03, 2005 5:43 am Post subject: |
i dont know much about the motec, but with mine i found the best way to get a lidle is to turn the idle controll off(isc goes to sleep) and get a nice rpm idle.
then get eveything else to atch the revs on decel or lower then idle. works better for cold start too
dont listen to me too much coz im p****d  |
Age:26 Posts: 516 Joined: 20 Dec 2004 Location: S.E. Melbourne VIC, Australia
Posted: Mon Apr 04, 2005 5:01 pm Post subject: |
You should really use two sensors on the front wheels otherwise you will get different responses when turning left or right. The rear ABS sensor would be more accurate but hooking it up to the gearbox speed sensor will probabily be just as good and easier.
For some tuning tips make sure you calibrate the sensors accurately. The motec help file has heaps on how to set the calibration factor. We found the best one was to measure how far the car went after 10 rotations of each wheel. (do seperately for the front and the back) Work out the number of pulses for 1 revolution of the tyre and then apply the formula.
Then drive a bit and watch you slip angles. They will never be 0 but should be always within +- 5% when driving normally. Try doing a full lock turn in a carpark, record the slip angle and make sure you set your activation threshold above this. Ater that it's just tuning. If you give a wide range on the throttle table, ie you allow alot of slip at full throttle the car will feel more responsive to your inputs around corners but you will get excessive spin in a straight line, just tinker untill it 'feels right'.
There is an optimum slip ratio for tyres where they make the most grip, it depends on lots of factors but it is generally between 8% and 15%. Try some internet research |
MRE-50L Fordmods Junkie
Posts: 2267 Joined: 05 Nov 2004 Location: West Ryde - Sydney NSW, Australia
View User Gallery (50)
Posted: Sat Apr 09, 2005 11:13 pm Post subject: |
lol we have good news and bad news !
Brad can tell ya's later or when he logs in again  |
Age:24 Posts: 3111 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
View User Gallery (36)
Posted: Sun Apr 10, 2005 1:50 am Post subject: |
good news = its runnig
bad news = i gotta spew ive had toomuch to drink tomight haha
Waggin Site Admin
Posted: Mon Apr 11, 2005 10:09 am Post subject: |
Hi All,
Time for another dose of Monday morning show and tell
It was a pretty darn big weekend. Lots of quality hours spend kneeling on the grass next to the waggin sorting s**t out.
After organising the additional pins, and the crimping tool to crimp the new pins and wires, I was ready to roll saturday afternoon. First up the additional Ignition Outputs were wired up, plus Idle Control, Lambda and probably some other stuff I cant remember doing.
With a bit of testing we found there was no spark.. this was put down to a small error in wiring up the igniters (ie, totally wrong). Next time i'll remember that OUT COIL means the wire goes to the coil, not the ECU
Once that was sorted, we were ready for ignition! Turn the key - bam.. starts straight away. Dave and I were both quite shocked. With a bit of playing to get mixtures to a reasonably sensible level, she was happy to idle (with the assistance of daves right foot @ 20% throttle). Happy with that accomplishment, we called it a night and headed off to the club to celebrate
-Day 2-
I was under instruction from Dave to get over early on Sunday morning.. so sure enough i bust my balls to get there before 9am, and he's still in bed. Doh!
Anyway.. another successful day. Lambda is hooked up and configured, idle control stepper is hooked up, and after a couple of hours of playing it is also working. Also sorted were thermo fans. After a bit of playing we had to go and fetch a jerry can full of PULP.. I was dry out of fuel
By late afternoon we were doing laps around the neighbourhood, dave as the test pilot, myself trying to tune the beast from the passengers seat.
"Hows that? s**t. How about that.. yep!.. Wow.. lots of black smoke.. [stall]... [crank for 20 seconds.. start].. thats better!.. more timing, less fuel... yep, [stall]" You get the idea
After about 20 laps around the suburb, we were reasonably happy with the tune and decided to take it for a drive to Hurstville... Probably more drivable than it was with the EEC-V. Idle is much more confident, a few flat spots throughout the range, and lacking in power up top.. not brave enough to go for tough tunes until i've got a wideband sensor up the a**.
Sadly driving back from Hurstville the brake booster died - that made for an interesting drive home
Anyhow, the goal of being able to drive the car to the dyno has been reached, so no more time will be wasted tuning on the road - to the Dyno soon! [Calls Crescent motorsport]
Stay tuned for more news ! |
4.9 EF Futura Moderator
Posted: Mon Apr 11, 2005 10:26 am Post subject: |
| Waggin wrote: | "Hows that? s**t. How about that.. yep!.. Wow.. lots of black smoke.. [stall]... [crank for 20 seconds.. start].. thats better!.. more timing, less fuel... yep, [stall]" You get the idea
In other news, there have been numerous reports of noxious black smoke clouds in several inner-sydney suburbs....
Sounds awesome brad. Sounds like the install was the easy bit.... u expecting to take much time on the dyno? |
Waggin Site Admin
Posted: Mon Apr 11, 2005 6:22 pm Post subject: |
| 4.9 EF Futura wrote: | | Sounds awesome brad. Sounds like the install was the easy bit.... u expecting to take much time on the dyno? |
Install wasn't too painful. Lots of wire hunting, cutting and joining.
The actual configuration of the engine parameters were easy after lots of research.. its just knowing the right numbers to put in there. The other small challenge was learning that I needed ignitors between the ECU and the Coilpack. One big learning experience!
Lots of dyno time coming up. Booked in for Wednesday night at Crescent for an after hours dyno session (Thanks Joe!!). I guess it'll take a couple of hours to get it reasonable.. |
Hyena Fordmods - Getting Side Ways
Age:29 Posts: 1518 Joined: 06 Nov 2004 Location: The Shire, Sydney NSW, Australia
Posted: Tue Apr 12, 2005 8:49 am Post subject: |
Sounds good Brad. I've been keeping an eye on your adventures because I'm going to be going down a similar road when I finally fit a MSII (altho they're not available until August now ) I will no doubt run into all the same problems! I didn't know the magna EDIS6 module was compatible so that's good! Does that actually replace the existing ford coilpack setup or work in addition to it ?
How is the software set up ? Like are there basic/generic fuel/spark maps to get you started or do you have to start from scratch ? |
Age:24 Posts: 3045 Joined: 05 Nov 2004 Location: Mornington Peninsula VIC, Australia
Posted: Tue Apr 12, 2005 8:58 am Post subject: |
awesome
good work guys, can't wait to see it all tuned up  |
Nicko Moderator
Posts: 11055 Joined: 05 Nov 2004 Location: SE Melb VIC, Australia
Posted: Tue Apr 12, 2005 9:23 am Post subject: |
OMG
THE WAGGIN IS ALIVE!
about time brad!
Good work Dave and Brad! |
Waggin Site Admin
Posted: Tue Apr 12, 2005 3:46 pm Post subject: |
| Hyena wrote: | Sounds good Brad. I've been keeping an eye on your adventures because I'm going to be going down a similar road when I finally fit a MSII (altho they're not available until August now ) I will no doubt run into all the same problems! I didn't know the magna EDIS6 module was compatible so that's good! Does that actually replace the existing ford coilpack setup or work in addition to it ?
With the ignition, I have retained the original ford coilpack, however to fire the coils, you need appropriate ignitors. These are inbuilt in the EDIS6 module, which for most US cars is external, however for the EEC-V EF/AU's, they reside inside the EEC-V ECU!. So the only work around is to either purchase a Bosch 3 Channel Ignitor or 3x Bosch 1 Channel ignitors. Sadly these items live on the Bosch Motorsport parts listing, and work out VERY pricey. The work-around - using Bosch J121 ignition modules, commonly found in EFI V6 Magna's and Pajero's from the Late 80's and Early 90's. Bung 3 of these guys between the [motec] ECU and the coil pack and she's fine.
Another work around would be to locate a US style EDIS controller (external from the ECU) and use it to drive the coilpacks.
The Motec's ship with a sample file, but its useless. Its simply trial and error. |
Waggin Site Admin
Posted: Wed Apr 13, 2005 12:19 pm Post subject: |
Myself and the Test Pilot (MRE-40L) hit the streets again last night, just to see if we could get it running a bit smoother, and get a bit more top end power.
The car is now more drivable than it ever was! So smoooooth..
We're also producing stupid amounts of torque around 3500rpm.. causing wheel spin in 1st and 2nd as it comes up the rev range.
To my surprise I was able to advance WOT ignition timing to 45* BTDC before she even thought of pinging.. and even then, I think it was simply leaning out.
Anyway.. off to the Dyno 2nite!!  |
Posted: Wed Apr 13, 2005 12:46 pm Post subject: |
You're leaning out ??
Mine runs rich as with the standard injectors - how are you leaning yours out with 24lb injectors ? Or do the fuel maps need looking at and you're just not supplying enough fuel ? |
Waggin Site Admin
Posted: Wed Apr 13, 2005 4:36 pm Post subject: |
| Hyena wrote: | | Or do the fuel maps need looking at and you're just not supplying enough fuel ? |
Thats the one
Duty cycle at WOT is around 40%. Just not enough time or wide open spaces to tune WOT properly last night  |
Posted: Wed Apr 13, 2005 4:40 pm Post subject: |
Is it possible 45deg BTDC was contributing to the lean condition? Thats an impressive amount of advance... lol, that spark would be firing before you unlock the car
Are you looking at knock sensor feeback?
Good luck with the dyno mate. |
Waggin Site Admin
Posted: Wed Apr 13, 2005 4:46 pm Post subject: |
| 4.9 EF Futura wrote: | Is it possible 45deg BTDC was contributing to the lean condition? Thats an impressive amount of advance... lol, that spark would be firing before you unlock the car
It may have been causing it. Looking at all this sort of data is new to me.. so im really just learning what different conditions really mean to end user performance. Too lean, too rich, too much advance, too little advance, different dwell settings, different injector timing.. lots of things to play with. Also knowing what manifold pressure to expect under what conditions.
Knock sensor isnt hooked up yet.. so the pinging which was noted was audible, it may be happening at 41* without our knowledge. Might hook it up 2nite.
Just about to finish up at work and head off.. been looking forward to this day for many months  |
Posted: Wed Apr 13, 2005 4:56 pm Post subject: |
| Waggin wrote: | been looking forward to this day for many months  |
We all have  |
Posted: Wed Apr 13, 2005 8:42 pm Post subject: |
Ummm, little tip on ignition timing. The truth, not all these old wives tales.
Basically, with spark advance, you need peak cylinder pressure (here-on knows as PCP) to be attained @ about 15 degrees ATDC. Now, different engine conditions affect this.
Lean: You should be running lean, i.e 16.5:1 (I assume you're using wideband O2 and if you are then tuning fuel maps should take you about 20 mins once you get the hang of it) on light engine loads. i.e cruising down the freeway @ 100km/h. or about 10-40 kPa manifold pressure. The problem that this offers to the ignition system is that:
1. Ther cylinders aren't filling very much so the air/fuel density is low
2. Because there is more oxygen than fuel in the cylinder, it takes more time for the flame to advance through the mixture.
So, to counteract this, you must advance the timing and give the mixture longer to burn so that PCP is achieved @ 15 ATDC
Stochiometric: You should be running stoch, or 14.7:1, under moderate loads. Maybe 40-70 kPa. Because under these loads there is the same amount of fuel and oxygen, and because the mixture density is higher, it takes less time for the flame to advance, so you need less advance.
Rich: You should be running rich, 12.5:1 for best safe power or 11.5:1 for rich best torque, under high engine loads. 70-100kPa. Again, because the amount of fuel is more than oxygen, and because mixture density is at its highest, you need the least advance because the flame advances very quickly.
Now, add to that that the faster the engine runs, the more advance you need.
So @ cruise, you might need 20 BTDC @ 1500RPM increasing to 40 BTDC @ 5000RPM.
@ stoch, you might need 10 BTDC @ 1500RPM increasing to 20 BTDC @ 5000RPM.
@ rich, you might need 0 BTDC @ 1500RPM increasing to 10BTDC @ 5000RPM.
Those are just figures I plucked out of my head, but it demonstrates what your spark map should look like.
The main view on spark advance is that 1 or 2 degrees retarded of pinging is the sweet spot.... WRONG!!! Pinging can be affected by a number of things. High compression, inlet air temp, fuel octane, fuel quality etc etc.
If you've got cold air, low compression, high octane and good quality fuel, you might be able to run 50 BTDC advance without pinging, but the correct timing might be 20 BTDC. Just because you're not getting pinging doesn't mean you need to crank more in.
Alternatively, if you've got very high compression, hot air, low octane fuel and low quality fuel, you might have to run 15 ATDC to stop pinging. Obviously this would be far less than ideal.
So, I hope that sheds some light on ignition timing. Ignition timing is far harder to tune than fuel because there are no cheap sensors available to tell you what spark gives you PCP @ 15 ATDC, unlike fuel where you have your oxy sensor that tells you exactally what's going on. |
Posted: Thu Apr 14, 2005 1:29 am Post subject: |
that is a good general look at things but every motor is different
i found the 4L likes to run a lil leaner then most at high loads and loves a heap of timing. I was running 12.5:1 at high rpm/load(this is a safe A/F) and it was ok. now im running 12.8-13.1 at high loads and you can feel the difference. Same with the timing, i had a safe setting and now have advanced around 6 deg all over the map and it is a heap more responsie and tourquier
also to obtain a smooth cruise with a lumpish cam, i recomend to run a lil richer.
it wont make tooo much of a difference to eco, but will drive alot smoother. This also depends on your timing too
i dont know about other motors, but the 4L respond to small changes is fairly large, so take your time getting it rite, and dont be shy trying stuff |
[47 queries :: 0.80911 seconds ]
