MoTeC is going in this weekend! [MoTeC is IN!]
Goto page Previous  1, 2, 3, 4, 5
Punnisher_42
View User Gallery (26)
PostPosted: Sat Apr 16, 2005 9:24 pm    Post subject: Reply with quote
Waggin wrote:
Yeh, not sure why they look purple.. but they were glowing the brightest red/orange you could imagine..
Was the flash on? Tends to do that to things that are glowing when the flash is on.
neil101
PostPosted: Sun Apr 17, 2005 11:22 am    Post subject: Reply with quote
Can I ask what is MSII? and where do i find info on it?
Neil
unclewoja
PostPosted: Sun Apr 17, 2005 8:25 pm    Post subject: Reply with quote
Neil
MS-II is a DIY Ecu and info can be found here
Waggin
Site Admin
PostPosted: Mon Apr 18, 2005 11:38 am    Post subject: Reply with quote
Hyena wrote:
ReGiE wrote:
130 was the max for the night. and that was in 4th gear pulling only about 3500rpm icon_biggrin.gif
Did you run teh waggin on that dyno prior to fitting the Motec Brad ?.
Yeh.. previously she's run 109RWKW. Running so rich that the unburnt fuel was causing the AFR to read 16:1 icon_smile.gif Tip - Never run 24lb/hr injectors on an EEC in a 4L icon_smile.gif
In other news, I exceeded 90% duty cycle on the injectors on the weekend. Grr.. need bigger injectors!
PostPosted: Mon Apr 18, 2005 11:48 am    Post subject: Reply with quote
LMAO... i bet she idled a treat huh?
Ouch. Was that WOT/high revs with a good afr? ...any scope to up fuel pressure? Better safe than sorry i suppose.... must be making impressive amounts of torque...
Waggin
Site Admin
PostPosted: Mon Apr 18, 2005 12:15 pm    Post subject: Reply with quote
running a bit lean at 5989rpm, WOT.
Using seat of the pants, you can definantly feel it dropping off power toward 6000rpm. I assumed it was just running out of breath, but it seems to be fuel related icon_smile.gif
I'll probably just rev limit her at 5800rpm and wait til the turbo goes on, unless I can find some VERY cheap 32lb/hr injectors for the mean time.
unclewoja
PostPosted: Mon Apr 18, 2005 2:02 pm    Post subject: Reply with quote
Was it running lean, or were you getting a rich missfire?
Both will give you a lean reading. Rich missfire is like the name suggests. A missfire because the mixture's too rich. That gives you a lean reading because none of the fuel gets burnt so the exhaust fills with oxygen. Voila! There's you lean reading but you're actually running incredibly rich.
Also, spark timing will have an effect on AFR. If the spark is too retarded and teh charge in teh cylinder doesn't have enough time to burn completely, it will give you a leaner reading.
Waggin
Site Admin
PostPosted: Mon Apr 18, 2005 2:03 pm    Post subject: Reply with quote
Rich Misfire would've best describe the condition. Thank god that is all a thing of the past now icon_smile.gif
Page 5 of 5
[35 queries :: 0.04115 seconds ]
