blue_falcon Fordmods Newbie
Age:20 Posts: 10 Joined: 16 Jan 2008 Location: melbourne VIC, Australia
Posted: Fri Jun 27, 2008 11:01 pm Post subject: msd coil |
i got a new blaster 3 coil and on the instructioms it says if using with a points or stock style distributor i need to use a ballast resistor
what kind of ignition does an el i6 have and is a ballast resistor needed |
blacksabbath189 Fordmods Tyre Shredder
Age:20 Posts: 372 Joined: 30 Apr 2006 Location: albany WA, Australia
Posted: Sat Jun 28, 2008 12:05 am Post subject: |
el i6's have distributor + coil on plug
no idea about the ballast resistor?
i'm pretty sure you don't need one if its electronic ign though? can anyone confirm.. |
Disco Frank Fordmods Junkie
Age:29 Posts: 13093 Joined: 05 Nov 2004 Location: Perth WA, Australia
Posted: Sat Jun 28, 2008 12:13 am Post subject: |
| blacksabbath189 wrote: | el i6's have distributor + coil on plug
no idea about the ballast resistor? sorry i couldn't be anymore help mate. |
NO E series cars run coil on plug only ba/bf/fg 96 run coil on plug
ef/au run coil pack= no dizzy
el run dizzy with coil and they are an electronic dizzy hence no points are inside teh dizzy
a ballast resistor is a large ceramic resistor to reduce the voltage going to the ign system i doubt it would be needed on the el |
Posted: Sat Jun 28, 2008 12:17 am Post subject: |
i meant dizzy and coil.. the on plug just appeared...
it was jesus  |
low_ryda Fordmods Stock as a Rock
Posts: 168 Joined: 03 May 2007 Location: south coast NSW, Australia
Posted: Sat Jun 28, 2008 5:14 pm Post subject: |
i run one on my ea.
*without a resistor* straight plug n play
Posted: Sat Jun 28, 2008 6:39 pm Post subject: |
| what would happen if i dont run a ballast resistor |
DA22LE Fordmods - Smokin em up
Age:41 Posts: 210 Joined: 06 Aug 2007 Location: Kellyville NSW, Australia
Posted: Sat Jun 28, 2008 7:26 pm Post subject: |
Hey,
The ballast resistor is only for points distributors. I would expect that using the ballast would result in a piss-weak spark.
Daz  |
Posted: Sat Jun 28, 2008 7:32 pm Post subject: |
ok i will try putting it i n tomorow
thanks |
biggav Fordmods Tyre Shredder
Age:28 Posts: 375 Joined: 06 Nov 2004 Location: Edgewater WA, Australia
View User Gallery (20)
Posted: Mon Jul 07, 2008 11:42 am Post subject: |
| is this the transformer coil type or a GT40 style as i was looking at the rocket catalog at work and could only find a transformer type coil that suited a dodge with would work but the plug was different. |
