Multiple amp query
DMac
PostPosted: Fri Jan 21, 2005 4:38 pm    Post subject: Multiple amp query Reply with quote
Hey guys, i was thinking, what happens when you have like 4 amps. just say two are four channel and two are 2channel( for subs). how do you run them through RCA's when the HU only gives 3 pre-outs and you have six RCA's to fill. ANd you dont wanna split the rcas.
twr7cx
PostPosted: Fri Jan 21, 2005 5:54 pm    Post subject: Reply with quote
Well, you open up your headunit and do fancy modifications to produce more RCAs.
Or you buy a new headunit with more RCA outputs.
Or you just use splitters.
Or buy the amps that have RCA inputs and RCA outputs!
Or you get rid of some of the amplifiers!
DMac
PostPosted: Fri Jan 21, 2005 7:10 pm    Post subject: Reply with quote
what do you mean buy opening up the head unit to get more rcas
twr7cx
PostPosted: Fri Jan 21, 2005 7:32 pm    Post subject: Reply with quote
Well, if your some fancy technical electrican person you might somehow, someway (highly unlikely) be able to modify your headunit to provide more RCAs.
data_mine
PostPosted: Fri Jan 21, 2005 7:44 pm    Post subject: Reply with quote
But that'll provide the exact same result as use RCA splitters, for 4x the cost, and 20x the effort.
Just use splitters.
DMac
PostPosted: Fri Jan 21, 2005 7:55 pm    Post subject: Reply with quote
yeah i think that would be the go. But so i don't lose the voltage drop i would probably buy amps with rca Out.
Tanks for the help
Interceptor
PostPosted: Fri Jan 21, 2005 8:10 pm    Post subject: Reply with quote
wtf are you being this anal about the RCA's for? the change in signal voltage from using a splitter to drive 2 amp channels wont be noticeable, but if you're that picky, you'll be better off buying some line drivers to bump up the RCA voltage anyway
as it is, the SQ will be affected a greater amount by bridging a 4 channel amp to 2 channels than by using a splitter
a smarter way would be to use either 2 bigger 2 channel amps for fronts and rears (IMO not really worthwhile amping the rears anyway) and a pair of monoblocks for the subs, or a BIG 4 channel and a pair of monoblocks
dunis
PostPosted: Mon Jan 24, 2005 11:58 am    Post subject: Reply with quote
with four amps.... you have a bigger problem to worry about.
Power.
Kenwood Maverick
PostPosted: Mon Jan 24, 2005 12:45 pm    Post subject: Reply with quote
Power.
So true.
big fuses icon_lol.gif , and
2 heavy current drawing amps icon_twisted.gif .
either way u have two optons
1. Use y adaptors for the rca lines. (i recommend this)
2. Use RCA outputs form the amp. (some older amps lost the voltage in the rca lineouts thus making other amps work harder)
If going with one, choose most suitable spot to use them to keep them concealed, either off the deck lines or at the amps, remember not to x them over hahaha
[36 queries :: 0.04075 seconds ]
