Age:54 Posts: 2407 Joined: 07 Nov 2004 Location: Penrith NSW, Australia
Posted: Sat Mar 05, 2005 11:53 pm Post subject: MX6 turbo dyno tune taday... |
Yep after blowing the legs out of the 2.5 24 valve V6..We decided to build a tough Leon [the owner] Proof.With taftrided crank, and flywheel, H bean eagle rods straight from the 5.4 inch Windsor Eagle rod and some custom C.P 7.8 comp pistons..We then added a block saver that fits between bores aqnd outer block as these engines like Honda's/ WRX etc don't have a solid deck.This prevents bores walking around under high boost..Michael and I made up the exhaust manifolds to fit one GT30/27 turbo...63 rears and .75 front ball bearing turbo...Twin plate ceramic clutch..E boost controler..880 cc injectors, 255 Walbro iontank pump..Again Michael and I made up injector bosses to fit these Rochester squarters etc..EMS 8860 and MSD ignition was fitted..
183 wkw and 630nm torque...In our 1/4 private road [don't believe it?] we got to 175 kph so its got some get up and go..Max boost on P 3 is set at 15 lb... 350 two piece rotors and 4 pot A.P calipers...
Posted: Sun Mar 06, 2005 2:12 pm Post subject: |
Sounds great, any pics of the motor?
And can others play on this private road too?  |
Trick Flow EL Fordmods - Smokin em up
Age:39 Posts: 223 Joined: 05 Nov 2004 Location: Sydney NSW, Australia
Posted: Sun Mar 06, 2005 2:39 pm Post subject: |
| Any added roundabout signs with this upgrade? |
Posted: Mon Mar 07, 2005 7:32 pm Post subject: |
Mate you want to see the brakes on this car !!! Needs 18 inch wheels to fit them inside..
Driving this car though you know what torque steer is...
I could be wrong with torque numbers too..Its over 600 nm ...[Thats more than a BA XR8]
4.9 EF Futura Moderator
Posted: Tue Mar 08, 2005 8:27 am Post subject: |
Haha - that sounds awesome. You guys certainly know how to have fun.
Engine sounds tough enough to survive a nuclear holocaust.
880cc injectors?!?!?! I guess there's only 6 of em. |
Age:24 Posts: 2163 Joined: 07 Feb 2005 Location: melbourne VIC, Australia
Posted: Tue Mar 08, 2005 8:47 am Post subject: |
Sounds like a weapon!! I am interested why the big injectors and only 180rwkw? Is there lots more to come??
Do you have any pictures of the car? |
Posted: Tue Mar 08, 2005 11:47 pm Post subject: |
| Dansedgli wrote: | Sounds like a weapon!! I am interested why the big injectors and only 180rwkw? Is there lots more to come??
YES but that 630 nm realy hauls some wheelspin!!!
This engine has only done 1200 klmrs it's still tuned safe...
But to be honest in front wheel drive car weighing 1100kg it's bloody fast!!! Yes 880 injectors...They are $10 more than 500cc so he got them...The silly part its still runing a 2 to 1 rising rate fuel reg...I want to use the Sard 1.1 reg...Pictures comeing soon...
The gearbox has close ratios... |
Posted: Wed Mar 09, 2005 7:43 am Post subject: |
| haha I didnt realise it was front wheel drive. That would be fun to drive!! |
Posted: Wed Mar 09, 2005 2:22 pm Post subject: |
| I remember them called "pole magnets" when I was a younster... we can thank the EXA, ET and horrid Cordia for that term too |
