my ef 4.0L
crispykman
PostPosted: Sun Jun 22, 2008 12:13 pm    Post subject: my ef 4.0L Reply with quote
anyone know if you can get straight cut gears for a worked ef 4.0L engine
Xflow
PostPosted: Sun Jun 22, 2008 6:56 pm    Post subject: Reply with quote
what straight cut gears for timming???
if so how do you plan to get that to work? it timming chain
see pic
 Description:
 Filesize:  62.32 KB
 Viewed:  383 Time(s)
krisisdog
PostPosted: Sun Jun 22, 2008 6:59 pm    Post subject: Reply with quote
Either that or for the 'box.
crispykman
PostPosted: Thu Jul 03, 2008 2:06 pm    Post subject: Reply with quote
well i dont know thats why i`m asking to see if any one makes straight cut gears to replace the chain. Just like v8`s go straight cut gears so you have no timing chain
XR6EB
PostPosted: Thu Jul 03, 2008 6:13 pm    Post subject: Reply with quote
I've been looking for years, and have never found any.
Krytox
PostPosted: Thu Jul 03, 2008 6:55 pm    Post subject: Reply with quote
Thats because no idiot would make them.
Think about it, the front end would end up looking like a Lucas Oil Stabiliser Display.
You'd be better off with a belt setup. but once again, what for and no-one would and too much work for a aussie engine.
 Description:
 Filesize:  20.49 KB
 Viewed:  273 Time(s)
XR6EB
PostPosted: Fri Jul 04, 2008 10:36 am    Post subject: Reply with quote
Running a Jim Mock DEV 5 cam, I "stretched" the timing chain and broke the chain guides TWICE in the first 11000km of my rebuild!!!! Straight cut gears would have eliminated this issue and saved me $2000 in repairs [the second time a pieces of the chain went into the sump and destoryed the oil pump as well. The car stopped in the middle of Liverpool. $$$$ expensive trip getting it towed home + the time off work with no car + cancelling my holidays because I used up the money on the repairs !!!] And yes, I did realise that it would end up looking like a Lucas Oil display, but I wasn't concerned if it resloved my issues!
Anyway, thats just my feedback. Hopefully others can learn from my experiences.
fiftyone
PostPosted: Fri Jul 04, 2008 11:26 am    Post subject: Reply with quote
how often do the chains on an i6 need replacing, if at all?
FairmontXR6
PostPosted: Fri Jul 04, 2008 6:22 pm    Post subject: Reply with quote
I had the same issues with my dev5 cam/head kit. I had the chain and gears and guides replaced the next day after we fitted the kit. Cam stretched the chain again, took the cam back out 4 weeks later and put in the stock xr cam, then put in a billet from surecam - no problems since. I wouldn't mind the straight cut gear setup, even if it is a bit noisy. Once I get the block rebuilt, a new chain will go in again.
As quoted, I hope ppl learn from my experiance as well.
tickford_6
PostPosted: Fri Jul 04, 2008 8:18 pm    Post subject: Reply with quote
it'd be easier and cheap to just buy a different cam. the cam is the problem, not timing chain.
Nigel
PostPosted: Fri Jul 04, 2008 8:25 pm    Post subject: Reply with quote
I had similar issues on a 4.1 engine I had rebuilt. The combination of Stage 4 cam and high volume oil pump did the damage - but on that car it was the dizzy drive gears that got munched. Apparently if you had big valve springs the cam would flex as well causing a poor fit to the oil pump gear.
Some very very carefull thought is required for big cams.
[42 queries :: 0.06064 seconds ]
