my ef v mates vs ute
Goto page 1, 2, 3  Next
wild_ef
PostPosted: Thu Dec 13, 2007 1:15 am    Post subject: my ef v mates vs ute Reply with quote
going down to perth motorplex on wednesday night to give my mate a run in his vs ute.
my ef has done 190 000kays got exhaust extractors 3inch air intake
and his ute has done about 290 000 kays and all its got is a cat back exhaust.
both cars are auto
how do you rekon ill go? im assuming he's gonna rape me off the line but im hoping ill catch him down track?
ELGT
Location: Brisbane, 444 cu in diesel boulevarde QLD, Australia
View User Gallery (16)
PostPosted: Thu Dec 13, 2007 6:20 am    Post subject: Reply with quote
Sell your a*** for a night to raise the coin needed to buy and install a nitrous kit, and keep it under your hat.
Should give him a shock.
KTASTRPHE
PostPosted: Thu Dec 13, 2007 7:22 am    Post subject: Re: my ef v mates vs ute Reply with quote
thats what i reckon will happen. too close to predict and depends on driving style
GeZza200
PostPosted: Thu Dec 13, 2007 7:29 am    Post subject: Reply with quote
what?? you will beat that vs ute from start to finish, it wont have a chance
MooseMan
PostPosted: Thu Dec 13, 2007 7:57 am    Post subject: Reply with quote
THey go pretty hard those utes. If both are auto he will just win if either is manual then that will win.
krisisdog
PostPosted: Thu Dec 13, 2007 9:29 am    Post subject: Reply with quote
take out your sub/spare wheel n whatever else you have removable.
It should be pretty even, and like you said I'd expect it to jump you off the line, but the commo auto's arent too flash, but by the time your at the top end of 1st you should be in front, and pulling away slowly.
GeZza200
PostPosted: Thu Dec 13, 2007 9:47 am    Post subject: Reply with quote
i still dont think his will have a chance off the line i reckon you will beat him quite easily
4dlvr
PostPosted: Thu Dec 13, 2007 9:58 am    Post subject: Reply with quote
what??? ive never bean beaten by a holden v6 with my mildly workd ef, or even my old au(stock) its usually pretty even on take off and when the good old btr hits second youl rape him. ild expect you to run high 15's and the vs a mid 16 if lucky.
either way let us no how you go
4dlvr
PostPosted: Thu Dec 13, 2007 10:19 pm    Post subject: Reply with quote
results??????
wild_ef
PostPosted: Fri Dec 14, 2007 1:39 am    Post subject: Reply with quote
ohk cheers boys, gave him a run to the 100 kay speed limit last night and he just had me,
im abit more experianced than him though so im hoping that will play a part.
it will be my first time racing, wat speeds do u rekon ill be getting by the line assuming its a dry track.
not racing until wednesday night or the next wednesday, ill keep ya's posted
Steady ED
Fordmods Addict
PostPosted: Fri Dec 14, 2007 6:37 am    Post subject: Reply with quote
Around 85-90mph
krisisdog
PostPosted: Fri Dec 14, 2007 8:14 am    Post subject: Reply with quote
was that with all your extra weight of sub n spare? Really you should have just passed him at 100. did you stall it up (well as much as you can ), or just boot it from idle?
Gregg_13
PostPosted: Fri Dec 14, 2007 8:25 am    Post subject: Reply with quote
Reduce the pressue in your tyres a bit, take em down to like 26psi, will reduce your wheels spin and help keep on the track.
wild_ef
PostPosted: Fri Dec 14, 2007 12:17 pm    Post subject: Reply with quote
yeah that was with everything in my boot, aswell as 2 of my mates, where he ad an empty ute tray and only one passenger, n he was only just infront, i didnt stall it up that time either.
also 26psi? u sure? that seems pretty low
Gregg_13
PostPosted: Fri Dec 14, 2007 12:22 pm    Post subject: Reply with quote
Ash scaffy and XH5LWPN, but Im pretty sure last I was at Woopass with em, they were both around that level, just head to the servo right around the corner there on the front, they got a digital air unit, so easy to do before you race and go back and fill em up after ward
Steady ED
Fordmods Addict
PostPosted: Fri Dec 14, 2007 12:30 pm    Post subject: Reply with quote
You won't need to touch tyre pressures with a stockish auto 4L.
Run the pressure you run with on the street, reduce rolling resistance.
Steel rims are a good idea, as long as the tread on them is half decent, they weigh less then alloys.
I'm not a fan of stalling up with stock stalls (unless boost is involved).
With 4Ls I stay on the brake, tramp it, and a fraction of a second after I get off the brake, so it "flashes" the stall.
GeZza200
PostPosted: Fri Dec 14, 2007 12:59 pm    Post subject: Reply with quote
what do you mean flashes?
Steady ED
Fordmods Addict
PostPosted: Fri Dec 14, 2007 2:05 pm    Post subject: Reply with quote
It hits it harder and shocks the stall point up a bit more, as opposed to sitting on the brake at the stall point and heating up the trans fluid.
I think with stock convertors because they are so tight, stalling them up does 2 tenths of f**k all.
Give it a crack.
schnoods
PostPosted: Fri Dec 14, 2007 6:47 pm    Post subject: Reply with quote
The track at the motor plex is very good, traction wont be a problem if your running a near standard 6. Especially in a BTR auto.
I'd leave it around 30 if you have good rubber, a tad less it you have large rims.
No big burnouts with standardish tyres, a quick blast to get the water off and get em warm is fine.
Might see you down there.
james88
PostPosted: Sun Dec 23, 2007 8:05 pm    Post subject: WAT Reply with quote
what a commy ute beatin a falcon haha. i have beaten 5 litle vts with shiftkit in my falcon so i dont think you will have any problem
Page 1 of 3
[47 queries :: 0.05437 seconds ]
