My results of HHO on a 2006 KIA Sorento w/ a 3.5L V6.
zowwie438
PostPosted: Sat Apr 12, 2008 8:39 am    Post subject: My results of HHO on a 2006 KIA Sorento w/ a 3.5L V6. Reply with quote
All,
First of all I love this HHO stuff. And I am SOOO sick of hearing people put it down by saying things like "the amount of energy consumed to produce HHO from the electrical system consumes more than what you get out". To people who think that way... let me explain the economics to ya:
1) I was spending 400 a month on fuel.
2) My first HHO cell has boosted my city milage from about 12 MPG to 26.6 MPG.
3) My unit consumes just under 10 amps during normal operation but may peak to 20 amps on a really hot day stuck in traffic with no air flow.
4) Even if I have to buy a new batter every three months... they cost about 50 dollars. I am saving almost 200 per month in fuel. So 200 X 3 months = 600, minus the cost of a new battery 50, minus my time and labor to replace it... i am still way out in front.
My first unit utilized 5/16" thread-all that was attached to a smooth surface PVC endcap on 4" pvc with a tube that was about 2' in length.
Each thread-all had approximatley 21 304 stainless steel 2" washers on them and the two rods intersected to where they almost touched. My polarity was +-+-+-+-+-+-.
I am VERY happy with the results considering the cost invested. Yes, my unit doesn't put out 1 liter a minute like most advertise... Prob only about 500ml a minute. However too much HHO scares me because I don't want it popping holes in my pistons and/or resulting in a retarded inginition inside the chamber that would counter-act my gains.
As fas as those of you who say... OMG, you put that on a new vehicle that is still under warranty? Yeap, I sure did! And it's all zip ties and can be totally removed in under 10 minutes. Trust me, if I pop the engine... it will be going in for service and if they don't want to fix it... Then I will get the lawyer and the warranty information and pick apart every english word and it's definition.
For those of you who have taken the time to post your findings, your plate designs, your failures and successes... i can't thank you enough! you have probably saved me hundreds of hours and thousands of dollars!
My most recent design is cells made from a martha steward steamer that can be found at kmart for 6.99. TAKE A MAGET WITH YOU!!! The sets available vary in their quality of stainless. Test each set on the shelf and buy the one with the least pull on the magnet.
Each plate is about 2X3 inches and there are small tabs on the end to attach stuff. Each tab is also perforated and really pumps out the HHO!
I myself welded tabs on the the cells I wanted to use to result in a:
+n-n+n-n+ configuration. Consumes less about 5 amps and outputs over 100ml per minute. Even when wired in series with other units... I can get the amperage down to almost 2 amps with about 200ml of output per minute.
So I figure I will keep building them so I will end up with about 4-5 cell packs... Each that consumes about 2 amps. They ride VERY cool, don't overheat and remain stable for 5 hours at a time.
I also don't use copper inside my cell anymore! I use stainless steel wire from ace hardware... And I just place it inside a tube to help insulate it from shorting out.
Good luck to all!!! i will post some pics one of these days.
==Zow
Disco Frank
PostPosted: Sat Apr 12, 2008 10:44 am    Post subject: Reply with quote
cheer man for the info
pics would be great!
zowwie438
PostPosted: Sat Apr 12, 2008 12:11 pm    Post subject: pics... Reply with quote
Sorry guys, it's just such a pain to get pics. Have to take them with the phone, them remove min-mem card, insert into coverter, place it into the PDA... YUK!
I will see if I can get the cam corder fired up this weekend.
Here in an hour I am going to try and retro fit the martha steward plates in an enclosed PVC tube... But to be honest I want to wait until I get my plate design just right.
One other thing to note... I have a 15 gal tank and tonight I watched it like a hawk. 104Miles out of a 1/4 of a tank. That is basically 104 miles from 3.75 gal. Not very impressive, but consider the factory rating for my vehicle is only 15mpg city and 22 mpg highway.. I am VERY happy.
==Zow
garthr
PostPosted: Sat Apr 12, 2008 9:50 pm    Post subject: Reply with quote
Hi Zowwie,
thanks for posting, it is all good info.
will probably try building something like yours for my next cell.
And you're right, - too many people knock this idea without even knowing what it is all about.
(did anyone mention that pics would be good tho?)
garth
Damo
PostPosted: Sat Apr 12, 2008 10:01 pm    Post subject: Reply with quote
lol
garthr
PostPosted: Tue Apr 15, 2008 9:14 pm    Post subject: Re: pics... Reply with quote
==Zow
have u done anything with the tuning of the motor (EFIE or such) or is it still completely standard?
gogetta
PostPosted: Tue Apr 15, 2008 9:18 pm    Post subject: Reply with quote
what is HHO?
garthr
PostPosted: Wed Apr 16, 2008 7:43 am    Post subject: Reply with quote
gogetta wrote:
what is HHO?
it is the mixture of hydrogen & oxygen gases that you get when you split water in an electrolyser
Hoozadoctor
PostPosted: Thu May 01, 2008 11:55 pm    Post subject: Reply with quote
Hi Zow and all
I have just added Hydrogen to my V8 ghia lpg, I have no idea yet about economy as I have only done 100ks and a lot of time with the car stationary. I have added an oxygen sensor enhancer, although I am unsure how much the oxygeb sensor come into play with LPG anyway. I have also added a thermo coupler and thermometer to the exhaust system tpo monitor the heat. and a fuel mixture meter so I can see the actual fuel mixture.
I have never owned a car with efi before so have no idea how to adjust the timing but beleive I will get better resukts with the timing closer to TDC.
I used several 12mm stainless steel rods in my pvc pipe (Electrolyzer), the original plan was to use carbon rods but the only source of carbon rods we could source were gowging rods and we found it was easy enough to remove the copper but the rods were of poor quality and deterioated very rapidly.
If anybody know of a source for top quality carbons rods that would be great.
Doc
-GAS-MAN-
PostPosted: Sun Jul 06, 2008 8:08 pm    Post subject: Reply with quote
Can i ask if anyone here has had any luck putting together an EFIE device?
I've just made one of the diagrams on the Water4Gas which seems like it doesnt work.
I've attached the diagram to this post, it is supposed to reduce the amount of current coming from the map sensor, functioning like an EFIE, but the rich setting isnt 'normal' it just enriches the mixture nearly 2.5times, the lean setting has no resistance and operates as per normal.
twason
PostPosted: Sun Jul 06, 2008 8:34 pm    Post subject: Reply with quote
This may work on an AU where the MAP sensor is a linear voltage but E series MAP is a square wave signal varing in frequency depending on the pressure (vacuum).
AFordNZ
PostPosted: Sun Jul 06, 2008 9:41 pm    Post subject: Reply with quote
Go to this site.......www.fuel-saver.org/Forum........you'll be impressed,its just full of EFIE stuff and some good results on HHO.Cheers
-GAS-MAN-
PostPosted: Sun Jul 06, 2008 11:14 pm    Post subject: Reply with quote
Thats good advice thanks!
Do you think people here would all meetup and show off our hho devices, exchange ideas and help each other out?
I've just bought two cell innards and one full cell being delivered this week.
All i need is a working EFIE and ill be pumping out over a litre a minute icon_smile.gif
Is there any benefit to producing 1 litre per minute instead of only 400ml's a minute in the ford 6cyl?
What improvements will i notice, i mean how more economical can it get?
I'd love to show others and explain it to them once ive got it all working.
Matt
-GAS-MAN-
PostPosted: Sun Jul 06, 2008 11:19 pm    Post subject: Reply with quote
Has anyone fitted a pcv enhancer yet?
What about wrapping your o2 sensor in foil just to see if it makes a difference?
Water injection? Lol i did all these in the last few weeks, ordered the three hho cells and tried fitting an adjustable resister to the map sensor, no luck yet but once i get the EFIE and hho working ill be running on water icon_razz.gif
I'm going to document the whole thing too, so more people get into it icon_smile.gif
motortronics
PostPosted: Tue Jul 08, 2008 10:42 pm    Post subject: Reply with quote
Matt
I would be happy to try and get a few people together with their hho's and compare devices share info etc because I think this will be the only way to get some uniformity into the whole thing and probably after a brainstorming session we could all be better off, tempered of course with an ale or two. Remember I will have to come from NSW but keen I am to talk to others etc.
Regards,
Noel
-GAS-MAN-
PostPosted: Tue Jul 08, 2008 10:46 pm    Post subject: Reply with quote
Well we could have different area meets and each group can show off their devices, we could even have an efficiency competition. The cell that uses the least amount of amps, produces the most amount of hydrogen and needs the least amount of maintenance.
A little way off yet, but alot of people will want in once they start seeing more and more people running these systems.
[43 queries :: 0.07718 seconds ]
