My Turbo EL
Goto page Previous  1, 2, 3, ... 17, 18, 19  Next
rusty_ute
PostPosted: Sun Nov 27, 2005 10:25 pm    Post subject: Reply with quote
she'll run pretty lean on standard ecu, wont take much to destroy itself
fritzz
PostPosted: Sun Nov 27, 2005 11:29 pm    Post subject: Reply with quote
got the turbo for 360. its got a .84 trubine housing and .70 comp with a 66mm wheel. at 1/2 throttle it starts spooling at 2000 and starts to com on hard at 2800. there has been no detionaton or pinning so far. its just the map sencer doesnt like the boost to much
EDXR8
PostPosted: Sun Nov 27, 2005 11:35 pm    Post subject: Reply with quote
The MAP sensor doesn't read boost at all, only vac. A higher rate rising rate reg may help richen up the mix under boost, either get one of them and back off the timing a bit or keep off the boost until you get the aftermarket computer, otherwise you will get really good at replacing head gaskets.
EFFalcon
PostPosted: Sun Nov 27, 2005 11:40 pm    Post subject: Reply with quote
not to mention an AU headgasket raising compression, increasing the likely hood for pinging.
fritzz
PostPosted: Sun Nov 27, 2005 11:44 pm    Post subject: Reply with quote
ok cool thanks for your help anyway. ill let yous know how it goes when i start mukin around with a few things
South
PostPosted: Mon Nov 28, 2005 11:58 pm    Post subject: Reply with quote
Let me get this right, you spent roughly $1200 on a manifold, $1500 on an upper intake plennum and thousands of dollars more on the associated parts, and you slapped on an el cheapo turbo from ebay?
You also have hoses as injectors and standard ecu running all of this? Im calling BS on this!
pyroay
PostPosted: Tue Nov 29, 2005 7:39 am    Post subject: Reply with quote
Dont want to sound harsh man but i believe right now this turbo is going to cost you $6,000 more to get running properly. Let my comments sit here and in 6 months come back to them and look at the figure i've outlined...
I have stated many time before dont start a turbo project unless you have $12,000 to play with.
AKO
Location: Mackay, Far North New South Wales. QLD, Australia
PostPosted: Tue Nov 29, 2005 4:23 pm    Post subject: Reply with quote
The engine cutting out is due to lean out. The ecu see's lean fuel burn and cuts the spark. Take it fom someone who f**k around with standard ecu, walbro pump and 12:1 rising rate reg, get bigger injectors and a Wolf 3D or EMS 8860. After 4 blown head gaskets and 1 destroyed motor I finally had the EMS and 42 lb Ford Motorsport injectors fitted and tuned (the silly thing is I already had them but was too lazy to have them fitted icon_redface.gif ). The AU head gasket will only prolong the inevitable.
Steady ED
Fordmods Addict
PostPosted: Tue Nov 29, 2005 5:38 pm    Post subject: Reply with quote
EFFalcon wrote:
aah.. just cars generally won't touch it unless its legal
That insurance money you just spent Fritzz is going down the drain.
Unless you've got it fully engineered and EPA approved.
I'd cancel that policy, get the refund, leave the car in the garage till you can get a proper ECU and can afford to get it tuned.
It will save you money in the long run.
ebs_4l
PostPosted: Tue Nov 29, 2005 5:39 pm    Post subject: Reply with quote
i couldnt agree more with that comment, im doing my setup myself, and although i have gone fairly overboard on things considering my hp level i want, ive spent around 12k already.... MAN, i wish i knew where it all went.... i would have never previously thought possible for it to cost that much, but it does
fritzz
PostPosted: Tue Nov 29, 2005 7:57 pm    Post subject: Reply with quote
the only things i need for it to be good is a ecu and a new trans later on. and about the enginers cert let just say i have good contacts. i recon i will end up spending another 8 - 10 k.
EFFalcon
PostPosted: Tue Nov 29, 2005 8:00 pm    Post subject: Reply with quote
i hope you mean a vic roads approved engineer thats willling to sign off on a non emmisioned car, if so then good on ya icon_razz.gif
fritzz
PostPosted: Tue Nov 29, 2005 8:07 pm    Post subject: Reply with quote
vic roads i live it wa
EFFalcon
PostPosted: Tue Nov 29, 2005 8:53 pm    Post subject: Reply with quote
Good luck!
CHEF
PostPosted: Tue Nov 29, 2005 9:37 pm    Post subject: Reply with quote
Well done getting a turbo on your car but that cheap turbo will most likely give you dramas, but your up and running anyway... just expect to have to buy a real turbo at some stage.
Dont try to run those big injectors off the EEC, it wont even start.
Get yourself a good ecu, install it, put your injectors and pump in and get it on a dyno opperated by someone who knows the ecu well.
I ran mine on eec for ONE day without anyboost, and nobody has ever got 300wkws from an unmodified eec.
Have fun
Southy
PostPosted: Tue Nov 29, 2005 10:00 pm    Post subject: Reply with quote
can you post up some pics frittz?
EBXR8380
PostPosted: Tue Nov 29, 2005 10:27 pm    Post subject: Reply with quote
Pics
 Description:
 Filesize:  4.6 KB
 Viewed:  2088 Time(s)
SVO XR6
PostPosted: Tue Nov 29, 2005 10:28 pm    Post subject: Reply with quote
hahaha
fritzz
PostPosted: Tue Nov 29, 2005 10:40 pm    Post subject: Reply with quote
lol yeh ill get some pics up when i get the head back on and all together. i must admit the nizpro plenum looks aws
TerroristGHIA
PostPosted: Tue Nov 29, 2005 10:47 pm    Post subject: Reply with quote
I call shenanigans on this running with big injectors and stock EEC. Spend the cash a get a quality aftermarket ECU, there is no other way around it. Sorry
Brett
Page 2 of 19
[50 queries :: 0.07968 seconds ]
