My Turbo EL
Goto page 1, 2, 3 ... 17, 18, 19  Next
fritzz
PostPosted: Sat Nov 26, 2005 10:15 pm    Post subject: My Turbo EL Reply with quote
its a 97 el falcon with 4l and 4spd auto
ok heres wat i got
nizpro intake plenum
6boost manifold
600x300x76 bar plate intercooler
tial 44mm wastgate
turbosmart bov
irdium plugs
9mm spiral leads
3.5" dump
3.5" s/s cat
single 3' all the way with 1 stratthu muffler
ok heres the big shock, use guys will hate me for this i know. but i got a super t70 turbo of ebay.
got it ruinning and when for a drive, and it goes a heap better but i can only use no more than 1/2 throttle because the map sencer is going crazy. it will come on boost but when it gets to about 4000rpm it cutts out quit harshly. any one had this prob??
any way it blew out the head gasket on num 5 after about an hour of driving, so its going bak in the shed to get a au steel 1 put in.
i will also put in my 440cc fordmotorsport injectors, malpasi reg and walbro 600hp pump.
SVO XR6
PostPosted: Sat Nov 26, 2005 10:16 pm    Post subject: Reply with quote
what ecu?
fritzz
PostPosted: Sat Nov 26, 2005 10:20 pm    Post subject: Reply with quote
standard
SVO XR6
PostPosted: Sat Nov 26, 2005 10:32 pm    Post subject: Reply with quote
theres your problem
fritzz
PostPosted: Sat Nov 26, 2005 10:38 pm    Post subject: Reply with quote
yeh tru but i thorght it would be ok running only 5psi
SVO XR6
PostPosted: Sat Nov 26, 2005 10:41 pm    Post subject: Reply with quote
wont be if your goin to upgrade the fuel system.
IMO, the std ecu isnt goin to work efficently/well with any boost, its just not tuned/designed for it.
to save you time, money and to get more power eaisly, get a after market chip/ecu to do the job
fritzz
PostPosted: Sat Nov 26, 2005 10:47 pm    Post subject: Reply with quote
yeh i will be getting a wolf 3d v4 or a ems 8860. chef had his running on standard ecu i think. and some bloke clams he got 310rwkw with the stock ecu
EDXR8
PostPosted: Sat Nov 26, 2005 10:50 pm    Post subject: Reply with quote
Your EEC is going ot have a heart attack with the 440cc injectors, I doubt it will even start not to mention idle, you are going to need a chip at least. It is wise to look for an aftermarket computer with any amount of boost IMO but a chiptorque or unichip should be able to provide enough tuning for low to mild boost levels.
SVO XR6
PostPosted: Sat Nov 26, 2005 10:55 pm    Post subject: Reply with quote
there is no way the ECCV will run thoes injectors
i strongly reccomend getting a aftermarket ecu, or at the least, a chip to run this
bit of a waste spending all that money on a awsome setup and not having gear to run it
with turbo stuff, timing and fuel is important for spooling and you wanna make sure your running the rite amout of fuel!
fritzz
PostPosted: Sat Nov 26, 2005 10:56 pm    Post subject: Reply with quote
the injectors are high impedance so it should run them
SVO XR6
PostPosted: Sat Nov 26, 2005 10:57 pm    Post subject: Reply with quote
it will run them, but you will have huge over fueling problems!
fritzz
PostPosted: Sat Nov 26, 2005 11:00 pm    Post subject: Reply with quote
yeh i thourght that may happen of boost. anyway i should have a ecu soon ill just baby it around till i get it
SVO XR6
PostPosted: Sat Nov 26, 2005 11:01 pm    Post subject: Reply with quote
hmm, i wouldnt drive it much ay
basicaly every time you hit boost your risking running lean
ka-pow!
EDXR8
PostPosted: Sat Nov 26, 2005 11:04 pm    Post subject: Reply with quote
Exactly, electrically it will run them but they will instantly flood the engine. The EEC can only compensate +/-10% in fuel change so you can normally go from the standard 19lb to aroudn 21lb without a major issue but it will not run the 42lb injectors.
fritzz
PostPosted: Sat Nov 26, 2005 11:14 pm    Post subject: Reply with quote
maybe i just put the reg in and put the fuel pressure up but leave the standard injectors in
SVO XR6
PostPosted: Sat Nov 26, 2005 11:16 pm    Post subject: Reply with quote
the only way to use a reg on a turbo, is a high ratio reg. you wuill have to get it on a dyno to see how the AFR is
EFFalcon
PostPosted: Sun Nov 27, 2005 8:52 pm    Post subject: Reply with quote
stop f**k around and just get an aftermarket ECU.
fritzz
PostPosted: Sun Nov 27, 2005 9:58 pm    Post subject: Reply with quote
i am need more money. just had to pay 1700 for insurance, i rang every insurance place and the only place that would do it was "justcars" they are great!!
EFFalcon
PostPosted: Sun Nov 27, 2005 10:10 pm    Post subject: Reply with quote
aah.. just cars generally won't touch it unless its legal
kermey
PostPosted: Sun Nov 27, 2005 10:17 pm    Post subject: Reply with quote
turbo off ebay? how much???
Page 1 of 19
[47 queries :: 0.04809 seconds ]
