NC 5.0 Won't Start
BlownNc
PostPosted: Fri Jan 21, 2005 8:40 pm    Post subject: NC 5.0 Won't Start Reply with quote
Sure it cant be much...fairlane wont start, it acts like its in a gear on the auto, it lights up all the warning lights but wont start....no signal on the wire leading to the solenoid on starter. Any ideas? The car has a vision CL2000 alarm fitted and im beginning to think the alarm is sus, but could there be something else sus thats causing it?
teeys
PostPosted: Fri Jan 21, 2005 8:48 pm    Post subject: Reply with quote
my auto stick in my NC is loose... i have to hold the stick firmly forward and to the left in park. else it does the same thing.. lights up.. no action.
i think this is due to the inhibitor switch as well as being a loose stick
BlownNc
PostPosted: Fri Jan 21, 2005 8:54 pm    Post subject: Reply with quote
Ran out and checked....no luck. Shifter is nice and tight, tried it anyway, to no luck. Maybe inhibitor switch? or could there be a relay, wire, etc that im missing? if anyone could tell me whats required for the car to start and i can start looking one by one thatd be wikid
Mitch_
PostPosted: Fri Jan 21, 2005 8:59 pm    Post subject: Reply with quote
tryed starting it in N?
EBXR8380
PostPosted: Fri Jan 21, 2005 11:34 pm    Post subject: Reply with quote
Try bridging the inhibitor wires if this works the swotch is suspect ..Don't leave like this though its too dangerous...My guess is inhibitor switch is deffective or out of adjustement..
Check that switch wire that connects to starter motor also...The thin one..Check its connection try cleaning and re connecting with some graphite grease on contacts?? Check that all battery connections are tight, including earths from body to engine....
BlownNc
PostPosted: Sat Jan 22, 2005 4:09 pm    Post subject: Reply with quote
ok...tried the inhibitor switch, tried the shifter, tried cleaning terminals...nothing. As far as i can see, power goes from the ignition switch - car alarm - relay - solenoid. Theres power at the ignition switch, but not at the Relay. Is there something else, like a fusible link? How can i test the alarm? Its a vision CL2000
philaddis
PostPosted: Sun Jan 23, 2005 9:52 am    Post subject: Reply with quote
Does your car have smartock?
If yes it could be a dodgy BEM not recognising the codes from the ingnition barrel or being just plain broke!
You have not done any work to the car recently?
BlownNc
PostPosted: Sun Jan 23, 2005 10:07 am    Post subject: Reply with quote
No smartlock......
Electroboy
PostPosted: Wed Jan 26, 2005 8:45 am    Post subject: Reply with quote
One way to check if your alarm is at fault , see if you have power at the inhibitor switch on the trany, if you do the alarm is fine, if not the alarm is at fault.
EB XR8
PostPosted: Thu Jan 27, 2005 10:00 am    Post subject: Reply with quote
I had something similar in my XR8 the other day - although my car is a manual. I went to start it after driving and there was nothing, not even a kick over or that ticking sound when the battery is too f**k to turn the starter motor. I tried a couple of times and there was nothing. Good thing my car is manual so i thought f**k it, and just roll started it. When i got home i parked on a hill just in case it did it again but it started fine and have not had the problem since. Wierd!!
[37 queries :: 0.03599 seconds ]
